Radiator fan resistor...
If anyone is looking for a resistor kit for there low speed cooling fan, this is great kit. Fan Relay Kit.
Chad
Detroit Tuned
Chad
Detroit Tuned
Google Mouser. I got a great resistor housed in an finned aluminum cover. You mount it to the aluminum mounts on the drivers side. Tomorrow I can provide the part number of the replacement resistor. Easy to install and works great without buying a whole fan assembly.
Send me a message if you need the part number info.
Good luck
Good luck
Good luck
Good luck
i'd still like to see the finned aluminum part, but a replacement component that looks OEM is $21.79 on rockauto.com
2006 MINI COOPER 1.6L L4 Supercharged : Cooling System : Radiator Fan Resistor PriceNo parts for vehicles in selected markets.ÜRO PARTS Part # 17117541092R Cooling Fan Resistor Repair Upgrade Kit
$21.79
$21.79
did anybody identify the power rating? Here's the Arcol .33Ω resistors:
http://www.mouser.com/Arcol/Passive-...z0vijb&FS=True
And is 100 watt
Note at the fan side you could as easily splice into the wires. I used spade connectors to make replacements a breeze. Turns out the resistor is heavy enough to outlast the car so a quick disconnect is a waste of time.
it can be connected much more elegantly, but this clearly shows the "how to" connect the replacement resistor w/o removing anything: https://www.northamericanmotoring.co...1-post867.html
Thanks for all the info. I cant tell which side of the resistor is A or B? Does it matter? It looks like the wire from the low speed fan wire goes to the "bottom" of the resistor as it's pictured. and the high speed the "top". But the pictures cut off so I'm not sure. Thanks for the help.
Low Speed Fan wiring
https://www.northamericanmotoring.co...esistor-2.html
Excellent
17117541092R
DIY: https://www.northamericanmotoring.co...placement.html
We usually have these in stock.
http://www.ecstuning.com/Search/SiteSearch/17117541092R/
17117541092R
fan lower speed issue ..
hi to you all i have a mini r56 2007 , since i full rebuild the engine i came a cros with a issue with the cooling fan low speed , i chanche the thermo , the thempreture senso and still not working , it gets hot , so i start testing and when i disconnect the plug from the thempreture sensor all works finne , i start the car and the fan low speed work good keeps the turbo cool i drive and in traffic and highway and all it ok , so when i get back to my garage i tun off the enngine , and the fan stay on for arounnd 5 to 7 minits , so it can cool down the turbo so far so the after turn off , but if i plug the thempreture plug back on , the its a problem nothing works ...... but if i unplug it off all work fine no i can drive the car all day with no issue of overheattinng the engine or the turbo , anyone have any experience with this issues , ???
thanks!!!!!!!!
thanks!!!!!!!!
