Here's My Laundry List of Problems - Please Post Yours
Old Oct 11, 2007 | 01:03 PM
lacning74's Avatar
lacning74
Here is a list of problems I plan to attack with my my dealer when I can get a loaner car.
-Persistent driver door/window wind noise after dealer had already adjusted window
-Door front edge chip (from rubbing with inside of frame)
-Misaligned driver door/beltline trim (possibly also related to above problem)
-Headlights aiming too low (standard halogens)
-Intermittent check engine light indicator
-Old software (hopefully an update will fix above problem)
-Rear car knocking sound when idle
-Loose rear tow hook cap
-Loose cup holder ring
-Sunroof noise (I will probably wait first to fix the driver window noise)
Falling in love (with my car of course) has made me OCD. Please post your own lists to help me feel better.
Group therapy is effective.
Old Oct 12, 2007 | 11:57 AM
andyde's Avatar
andyde
I just got my sunroof and driver's side door wind problem...
see my post here..
Old Oct 17, 2007 | 07:55 PM
Its311pete's Avatar
Its311pete
Not knocking you but is "old software" really a valid complaint.
I mean come on it is a 07'.
If you believe you SES has issues to software you may or may not be correct. there is a ton of things that can set off the SES.
Old Oct 18, 2007 | 03:59 AM
lacning74's Avatar
lacning74
Fair enough. Only found out about the SW update based on prior threads on this issue with the engine light coming on especially in R56 MC automatics. I agree something else may be going on.
I'll let yall know how my service trip goes next month.
Old Oct 18, 2007 | 04:08 AM
rockridge's Avatar
rockridge
only problems so far are the missing lower door seals, and with comfort access not working the way it should. Plus that old big rear view mirror.
Old Oct 18, 2007 | 07:58 AM
jw34's Avatar
jw34
This can be adjusted by the dealer. I had mine done and it makes a big difference.
Old Oct 20, 2007 | 10:12 AM
miniemee's Avatar
miniemee
You can adjust the xenons yourself. There are posts that tell you how. I adjusted mine 3/4 of a turn clockwise.
Old Oct 20, 2007 | 10:37 AM
gokartride's Avatar
gokartride
I had the software upgrade for the CEL, a fuse upgrade (cooling fan?...I forget, dealer just did it based on a service bulletin they had), and a piece of delaminating (rubber from chrome) beltline trim replaced. I'll get a new SZL sensor this week...that should bring me up-to-date on the mechanical fixes. Got a mild door-ding PDR'd away yesterday, so I'm good there, too. All this has in no way encumbered me from enjoying and exploring the drivability of my Cooper, though...I'm constantly delighted by the subtle nuances that distinguishes this car from my '03 (which I still have). Just lots of very little things that add up to make this a whole different kind of MINI. Better overall and I'm smitten...however if you plopped me back in my '03 and gave me a few hours, I'd probably fall in love w/ it all over again!!!
Old Oct 25, 2007 | 12:41 AM
coopselt's Avatar
coopselt
From: Camano Island, WA, but wish was still Oahu, Hawaii
Funny...
I just posted my laundry list on another post. Should have done it here.
Mines way bigger than your's though.
For anyone having engine drivability/hesitation/service engine soon lights, ... Change your gas station. That has cured mine!!
Old Oct 25, 2007 | 07:28 AM
CC's Avatar
CC
My driver's side visor mirror light doesn't work. I will retain this problem however, for as long as possible, so that I can have some input on this forum. Other than that, I have nothing further to add to this conversation.
Old Oct 25, 2007 | 09:47 AM
ExpatBiker's Avatar
ExpatBiker
my **** is beginning to be reshaped by the recarro-clone seats. i don't think american ***** fit very well in british bolstered seats. i've resorted to a pillow, but my colleagues cruelly point and laugh when they see me arrive at work with a sadly misshapen ****.
Old Oct 25, 2007 | 08:30 PM
going4speed's Avatar
going4speed
He said...
He said ****
I don't get out much...can you tell...
Old Oct 26, 2007 | 07:13 AM
CC's Avatar
CC
Dang, now I'm checking my **** in every mirror I walk by.
Old Oct 28, 2007 | 02:41 PM
investigator's Avatar
investigator
The only problem I've encountered with my MCS is the speed. It is almost as quick as my 335i. What a blast !
Old Oct 28, 2007 | 06:39 PM
chili_red07's Avatar
chili_red07
I can't tell if my drivers window doesn't quite seal right, or if it is just wind noise. I hear it at around 75mph up. I also get a strange whistle that I think comes from up front... but again, not too sure. Either way, I notice these things because I'm OCD about the car... I LOVE IT!!!
Old Oct 29, 2007 | 09:34 AM
Arnbut's Avatar
Arnbut
1- Splooge stain on wheel arch; prep-tech tried to take it out with steel wool and made a smooth spot.
2- Passenger airbag turns itself off with adult sitting in seat. Often.
3- Smells like a burnt cat when you run it at high elevations, especially over 9,000 feet. You have to run it hard from 4000 to 9000 to get the odor.
4- Makes me giggle every time I romp on the gas peddle. I waste fuel as a result. I'm 6'5"; a man my size shouldn't giggle.
Use the search feature to find out what was wrong with my first R56...
Old Oct 29, 2007 | 10:20 AM
ExpatBiker's Avatar
ExpatBiker
what does it smell like at lower elevations? a cat on a rotisserie? sorry ... had to ask.
Old Oct 29, 2007 | 10:52 AM
Loony2N's Avatar
Loony2N
Um. Okay.
Old Oct 29, 2007 | 10:55 AM
Loony2N's Avatar
Loony2N
I thought it was goat. But, you may be right. Could be cat.
Old Nov 3, 2007 | 08:11 AM
jascooper's Avatar
jascooper
I'm getting a rattle from sunroof. Seems to be coming from the headliner trim and not the sunroof though.
Old Nov 3, 2007 | 08:50 AM
Minidrivr's Avatar
Minidrivr
Not much of a list but,
Scratch on piano black drivers side elliptical ring
Scratch on rear valence (the black piece on the bottom of the bumper)
Passenger side window needs adjustment at rear top edge (sits too low; although the car is dead quiet inside so no wind issues)
Lack of seals on the bottoms of the doors (may have been a mid year change as many don't have them)
Lack of PAINT on the inside of the fog light holes in the front bumper
Dash panel below the steering wheel won't stay clipped in on the right side
All those things except the paint around the fog lights and the dash panel were discovered at delivery.
Everything is being resolved at my dealer with no issues so far.
Old Nov 12, 2007 | 08:07 AM
lacning74's Avatar
lacning74
Dropped off my car and got a MCS loaner
Thanks everyone for sharing.
Dropped of my car at the dealer today. They gave me a BR/W 2006 MCS as a loaner. Wish they didn't. I like the extra HP. At normal speeds though, I like the handling better with my 2007 MC. Besides the steering wheel and rear view mirror, everything is completely different, very disorienting. Also I couldn't fit my daughter's stroller in the boot.
I hope they can at least fix the driver door wind noise. I also started to hear an intermittent squealing sound when at idle only. Wish my car luck!
For now, I will enjoy the MCS.
Old Nov 12, 2007 | 08:44 AM
jascooper's Avatar
jascooper
I'm hoping I can get an MC loaner when I bring my MCS in for service. Like to see just how much difference there really is between the two with more than just a 10 minute test drive
Old Nov 12, 2007 | 10:19 AM
Beijing66's Avatar
Beijing66
Other than the fact that my MINI stalled on me (the dealer couldn't figure out what's wrong and it went away), when I started the car the other day and continued to press on the brake (mine is a MCSa), everything stopped working (the engine, even the radio) for a minute. I had to pull the key out and put it back in and restarted the car. I was able to start it. Last but not least, last time I pumped gas, the nozzle trigger stopped twice before the tank was filled up (what the heck?), and I thought it was filled up, but after only a couple of miles the gasoline indicator meter showed I was already down a notch? What is going on? The first year build I guess, always has relatively poor quality and quirky things?
Old Nov 12, 2007 | 02:04 PM
surfblue's Avatar
surfblue
operator error
There's nothing wrong with your gas gauge. Stick the nozzle all the way in, fill the car with YOU standing right there holding the gas ON. When it clicks off, WAIT about ten seconds to let the gas settle out/level in the tank. Then hit the gas again SLOWLY. When it clicks off the second time, it's really FULL.
Anytime you're pumping gas in at speed, ( handle full on) there's some turbulence that has to go away. This happens with any car to some extent, and can vary depending on how the filler tube is set up.
