Here's My Laundry List of Problems - Please Post Yours
Old Nov 17, 2007 | 12:43 PM
  #51
kimmc's Avatar
kimmc
Originally Posted by lacning74
Well, I got my car back from Mini of Manhattan after two days. They could not replicate the driver door noise or the squealing sound at idle, so they didn't look into it. The SA told me to bring in the car again and drive it with the foreman. They tested it on the West Side Highway, which is a little too congested to appreciate the door wind noise. The SA told me the place is pretty strict about service since it is a BMW corporate facility, not a franchise.
The service in Manhattan is really bad. You'll be much better off going to Morristown where they actually spend time trying to find and fix your problem. In Manhattan you have to wait in line just to quickly tell someone what is going on, then they just ignore what you told them. Morristown isn't that far away if you go during non-rush hours and you have EZ Pass to get back through the tunnel.
Old Nov 22, 2007 | 01:21 AM
  #52
leongk's Avatar
leongk
my list/issues
I have 2003 MC prem pkg 58k miles, 5spd manual,had for 6 mths
-Window works off and on, knock above speaker keeps it working
-Rusting of edge seam at bottom of door jamb seal/weather stripping
-runs better in cooler weather
-AC doesn't keep up after the air temp is above 90
-no automatic up on the windows
-expensive key replacement
-ease of dirt/dust buildup in engine compartment
-31-34 mpg was hoping to get more
-a 6th gear for above 65 mh would be nice
-small visor
-glove compartment dumps when opening
-Winey belt when turning tight from parking.
-easy to hit the wiper switch/lever.
-can't get use to horn button location
-hot temps window squeeks when opening
- do love this car though
Attached Thumbnails Here's My Laundry List of Problems - Please Post Yours-p1030008.jpg
Old Nov 22, 2007 | 07:16 AM
  #53
Birdman's Avatar
Birdman
The Navigation system doesn't work!!
https://www.northamericanmotoring.co...d.php?t=120551
Old Nov 22, 2007 | 10:13 AM
  #54
Joey D's Avatar
Joey D
I have issues with a knocking noise while sitting at idle, although it might be my phone screwing with the hi-fi system. I don't know, the dealer said they would look at it. Also my rear fog light stopped working, but that is being fixed by the dealer as well, I think it was just a faulty bulb from the factory.
Old Nov 22, 2007 | 04:32 PM
  #55
daffodildeb's Avatar
daffodildeb
Is that knocking noise in the engine? Could be just the direct injectors--designed that way...
Old Nov 23, 2007 | 06:23 AM
  #56
Bishamon's Avatar
Bishamon
Does the knocking go away if you press down on the clutch? If so, then it is likely the dual-mass flywheel. I have the same noise, and from what I have read, it was an issue on earlier models as well, and even after replacing, the sound could return. Others have reported this same sound with their R56 models. I'm not concerned about it at this point.
My only real issue at present is with the environmental controls for the vents in the car. They seem to have a mind of their own, and while I can change which vents are active, it never seems to correspond to the pictures on the dial, and getting the heat to come full out of the dash vents is damn near impossible.
Old Nov 23, 2007 | 06:36 AM
  #57
Joey D's Avatar
Joey D
It's not the injectors, that noise sounds different and this knocking is coming from the rear (possible passenger side). Also my Cooper is an auto. I'll be curious to see what the dealer has to say.
Old Nov 23, 2007 | 06:54 AM
  #58
lacning74's Avatar
lacning74
What is the noise like? Mine is a low thumping sound every 5-10 seconds. As per this thread and others, it may be the sound of the fuel tank venting pressure.
Old Nov 23, 2007 | 02:42 PM
  #59
Joey D's Avatar
Joey D
That would probably be it.
Old Nov 28, 2007 | 07:04 AM
  #60
MiniStupidfun's Avatar
MiniStupidfun
You can fix the sunroof rattle by putting the fluffy side of velcro onthe two wind deflector flaps It will stop the plastic to glass contact which will end the rattle.
sevin
May 2, 2026 06:11 AM
Kimolaoha
Jul 5, 2023 01:04 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
minipopkart
Aug 13, 2015 05:22 AM
