R56 Software changes/fixes needed thread
Old Feb 13, 2008 | 03:28 PM
  #126
ultimatebob's Avatar
ultimatebob
How about fixing the Radio Data System (RDS) so it actually shows the right genre for US stations? On mine, it shows "Drama" for Classic Rock stations and "Weather" for R&B stations :(
Old Feb 13, 2008 | 06:45 PM
  #127
Minidrivr's Avatar
Minidrivr
The RDS data is broadcast from the station. It's the stations that are not giving the correct information for the radio to display.
Old Feb 13, 2008 | 09:44 PM
  #128
oldopelguy's Avatar
oldopelguy
Originally Posted by Modnar
You've got the Nav, so you get CD-Text, but on cars w/o the Nav it doesn't display on the head unit.
I've tried it w/ discs I know have CD-Text (store bought, and burned) and nothing displays on my Navless MCS. See about halfway down this thread.
Mine shows the name and artist, on all the MP3 cd's I play as well, and I have standard radio without Nav. It's not the default display, you have to select "List" to get there, but it will display them.
Old Feb 14, 2008 | 06:16 AM
  #129
Modnar's Avatar
Modnar
I get info for MP3 CDs fine. I'm talking about regular audio CDs.
Old Feb 14, 2008 | 07:20 AM
  #130
jggimi's Avatar
jggimi
A software pet peeve that no one else has mentioned.
When you open either door, the window opens slightly, so that the doors close without air pressure problems, then the windows slide back up. Nice.
I'd like that same feature for the rear hatch. Crack either (or both) human doors when the hatch is opened, so the damned hatch closes easily without having to be slammed down to accomplish this. How many of us have had to stop after first starting out, to get out and re-close the damned thing? I'm betting .... all of us.
Old Feb 14, 2008 | 07:42 AM
  #131
ColinMc's Avatar
ColinMc
I do like the windows cracking a little...most times. But I wish I could disable it in winter months. Or when i'm washing the car...it gets annoying with water, snow getting in the car more easily when the windows open that crack right away.
Old Feb 14, 2008 | 05:31 PM
  #132
grodenglaive's Avatar
grodenglaive
I think the windows have to snick down a bit, or you couldn't open the door - wouldn't the window catch on the door frame?
Old Feb 15, 2008 | 07:12 PM
  #133
ultimatebob
Actually, the station is sending the right RDS data. The Radio in my MINI was mistakenly programmed with the UK RDS codes, though, so it decodes the station categories wrong.
I was able to figure out the problem thanks to this Wikipedia site:
http://en.wikipedia.org/wiki/Radio_D...#Program_Types
Notice that the "Classic Rock" US RDS code matches the "Drama" UK RDS code? That's why the local rock station is showing up as "Drama" on my radio :(
Old Feb 15, 2008 | 08:12 PM
  #134
jw34's Avatar
jw34
I don't think this has been mentioned but I wish the DRLs would turn off if you use the hand brake. If you have the DRLs set to be on and are waiting outside in the car with it running, at night you can't turn the headlights off! Kinda stupid. I read somewhere where in the pre-56s you could turn the DRLs off by setting the hand brake.
Old Feb 15, 2008 | 09:06 PM
  #135
Minidrivr's Avatar
Minidrivr
I was told by my MA that this is a common thing in BMWs. It allows frame less windows to achieve a better seal due to it being under the upper portion on the car. Supposed to make it quieter and less likely to leak.
That's interesting. Why wouldn't they change US bound/ordered cars to US RDS codes? Seems like it would be easily adjustable though a software update/setting when the car arrives at the US port.
Old Feb 16, 2008 | 04:45 PM
  #136
r56mini's Avatar
r56mini
Mine says "Education" for everything. It is retarded.
Old Feb 20, 2008 | 04:34 PM
  #137
jmatero's Avatar
jmatero
Tilt passenger side view mirror down when car is shifted into reverse (like all BMW's)
Old Feb 26, 2008 | 11:17 AM
  #138
Birdman's Avatar
Birdman
So to re-cap the latest posts:
1. RDS does work. No changes needed.
2. The windows go down when doors open/close for a physical reason (so they don't get caught on car frame and break).
3. I have never had to "slam my hatch", it closes just fine. ?? I also have never herd anyone complaing about this before either.
4. Display CD Text for regular audio CD's for vehicles without navigation. ADDED!
5. DRL's: Can't turn them off. Ok, you have a point, but that's getting picky. It is easy enough (with Nav anyway) to go to Setup, Lights, and uncheck the DRL box. The lights go out immediately (don't have to leave menu). When you are done "making out with your girlfriend in front of her parents house", just a click of the joystick would turn them right back on.
Ok. MINI, have you implemented any of these changes????
Old Feb 26, 2008 | 11:22 AM
  #139
ColinMc's Avatar
ColinMc
RDS Doesn't work! My dad's caddy displays the local channels as Rock that I listen to just fine, but my Mini displays them as Education...definitely a programming error between EU and US stuff...has to be switched? Possible to have done at the dealer?
Old Feb 26, 2008 | 11:43 AM
  #140
Birdman's Avatar
Birdman
Mine works fine (for the few stations that broadcast it properly anyway), so maybe YOURS has a setting wrong somewhere? But it's not a general software problem.
Old Feb 26, 2008 | 11:46 AM
  #141
jggimi's Avatar
jggimi
No, the windows don't catch on the door frame. My windows are often frozen shut in the mornings this time of year, and the doors open and close without the window moving.
And it's not the RDS signal that's wrong -- RDS is things like song titles and station name. It's the PTY database that's completely hosed in these stereos. They use European data, but this is North America.
Circumvention: Turn off PTY.
Fix: Buy a newer model year MINI. :( I think, if it were fixable, it already would have been. It's only a guess, but I think the problem is baked right into these stereos and not fixable via a software update at the dealerships. Birdman may just have a newer stereo than the rest of us.
Old Feb 26, 2008 | 11:48 AM
  #142
z3bum's Avatar
z3bum
Sport mode and traction control remember their last settings, on or off.
Improve the throttle response in first gear from a dead stop when not in sport mode.
Key Fob, push and hold when locked to unlock and open sunroof and windows.
Key Fob, push and hold when un-locked to lock and close sunroof and windows
Old Feb 26, 2008 | 11:57 AM
  #143
Birdman's Avatar
Birdman
Gotcha. But it is used to make a better seal, nothing to do with the airtitness another poster was questioning.
Old Feb 26, 2008 | 11:58 AM
  #144
gokartride's Avatar
gokartride
I don't think the windows dip because of air pressure...that's just how they normally seal for water when the door opens or closes. The boot issue may just be a simple adjustmant of the stops...that's all it was on my car and some others I've seen. Twist the rubber stop on each side of the hatch...it's spiral-cut so it can be adjusted. I adjusted mine eight months ago and have not had a problem since. The first gen car was setup the same way and it's boot hatch also required stop adjustment.
Old Feb 26, 2008 | 11:59 AM
  #145
Birdman's Avatar
Birdman
All but the throttle are already on list. If you want a stronger throttle at startup, then use Sport mode. That' the point of it. The rest of us prefer to save fuel at startup.
Old Feb 26, 2008 | 12:23 PM
  #146
Modnar's Avatar
Modnar
Originally Posted by Birdman
So to re-cap the latest posts:...
4. Display CD Text for regular audio CD's for vehicles without navigation. ADDED!...
Thank you, sir!
Too bad there's not much hope that they're going to do anything.
Old Feb 26, 2008 | 12:27 PM
  #147
jggimi's Avatar
jggimi
By the way, the North American PTY codes can be found on page 72 of:
http://books.google.com/books?id=MX0...0Zux0#PPA72,M1
The European table can be found on page 9 of:
http://www.sbsfm.com/download/manuals/fmb10.pdf
And my stereo *definitely* uses the European table.
Old Feb 26, 2008 | 12:29 PM
  #148
jggimi's Avatar
jggimi
Originally Posted by gokartride
...The boot issue may just be a simple adjustmant of the stops...
I'll give that a try, thank you!
Old Feb 26, 2008 | 01:16 PM
  #149
Msteadman's Avatar
Msteadman
I'd really like this feature as well. Granted I do it manually without really thinking about it when I'm parallel parking, but often forget to set them back up to the proper position for driving.
Old Feb 26, 2008 | 01:30 PM
  #150
Birdman's Avatar
Birdman
I'm having a hard time (that's not hard!) trying to figure out why you want the mirror pointing down when your parking?
