R56 Software changes/fixes needed thread
Old Jan 15, 2008 | 05:25 PM
  #101
Minidrivr's Avatar
Minidrivr
Originally Posted by Birdman
Added as #22.
Reword it to indicate the storing of HD2 channels in addition to the HD1 stations that are already stored just fine.
Old Jan 15, 2008 | 06:40 PM
  #102
pmmiller's Avatar
pmmiller
Electric Mirrors should fold in when doors are locked and you walk away. (They are not usefully for anything else they so maybe the cool factor of auto folding would do)
Heated mirrors should turn on when the rear defroster is on. (To remove the southern morning dew.)
Old Jan 15, 2008 | 08:42 PM
  #103
Minidrivr's Avatar
Minidrivr
That's an interesting idea. I think I might have even bought the power mirrors if they were configurable to do that.
Heated on defrost sounds good too. Another car I have does this. I've never experienced frost on the Mini's mirrors yet but it's always garaged. One of these days it might get a temporary slumber out in the cool air.
Old Jan 15, 2008 | 11:13 PM
  #104
Eric_Rowland's Avatar
Eric_Rowland
Electric Mirrors should fold in when doors are locked and you walk away. (They are not usefully for anything else they so maybe the cool factor of auto folding would do)...
Not true. I added PFM, and usually only use them when parking in my narrow garage, so I don't run into them when walking past. On occaision I'll fold them in a parking lot, but usually it's not necessary, and certainly not when parallel parking. I have the option to add a module to do that, but haven't found it necessary.
It would be nice to have the program option though.
Agreed. The thought of my mirrors being heated while driving in 90* heat in the summer is ludicrous.
Old Jan 16, 2008 | 05:57 AM
  #105
Rastven's Avatar
Rastven
The heated mirrors only activate when the temp is below a setpoint so they aren't running when you have an ambient in the 90's.
Old Jan 16, 2008 | 08:50 AM
  #106
Eric_Rowland
Is that new for '07+? What is the setpoint?
Per page 36 of my '04MCS manual:
Electric heating*
Both mirrors are heated automatically when the ignition key is in position 2
Edit: It does appear that for the R56 they only turn on below a 'certain limit', though it doesn't say what that limit is.
Old Jan 16, 2008 | 10:11 AM
  #107
Birdman's Avatar
Birdman
Storing HD2 stations fixed.
Old Jan 16, 2008 | 10:25 AM
  #108
gokartride's Avatar
gokartride
I think it'd be interesting if, in the readout located in the speedomoter, you could display other info in addition to the great OBC info already available. There are even a few empty slots when you flip to that section. So what if you could display water temp, oil pressure, or other items (that we commonly use gauges for). I mean...that info is in the ECU somewhere, what if you could get it to come up in the speedo readout? And......what if you could toggle (even at a selected duration) between critical readouts of choice. A feature like this could be offered as an option...lots of folks would probably be very interested.
I know lots of folks think of this as the radio and complain about the R56 head-unit being in the speedo. It's not that way, though...I display OBC info there all the time as I have a preferred setting for the tach display for primary info. The secondary display/readout is brilliant and, imo, could be put to even greater use.
Old Jan 16, 2008 | 03:56 PM
  #109
Minidrivr's Avatar
Minidrivr
How about displaying the actual tire pressures not just a green picture on the Nav?
Old Jan 24, 2008 | 10:57 AM
  #110
COOP310's Avatar
COOP310
I would like to be able to turn the Auto AC off without having to push more than one button. Previously, simply pushing Auto while on would turn it off
Old Jan 28, 2008 | 08:47 AM
  #111
Birdman's Avatar
Birdman
You can turn the AC off, by simply pushing the AC (snowflake) button. I think you mean the auto temperature control... Well, it's not an on/off function, it's on, auto air control, auto temp contol with auto air off, then off. They would have to split those into two buttons to do that.
Old Jan 28, 2008 | 03:42 PM
  #112
ehart13169's Avatar
ehart13169
You can turn it on with one push of one button (the one marked "Auto"), I agree that it would be nice if you could also turn it off with the push of one button.
A couple of other things to make life a little nicer....temperature gauge, oil pressure gauge, both can be included in the OSD if necessary. Would also love it if I could adjust the delay on the intermittent wipers. When it's just a mist, either the wipers chatter because the windshield's not wet enough, or you need to keep turning them off and on.
Old Jan 28, 2008 | 05:44 PM
  #113
Minidrivr's Avatar
Minidrivr
Temp and oil pressure would have been nice. I got the auto wipers just for the reason you mention, intermittent setting is fixed if you don't have the rain sensor. There is a setting in the OBC for the rain sensor sensitivity however.
Old Jan 29, 2008 | 10:36 AM
  #114
COOP310's Avatar
COOP310
I am not sure that I understand.
In the R53 you could turn on the auto climate control system (AC & fan) by simply pressing auto. Turning it off so that you could open the windows was just as simple... you just pressed auto.
In the R56, to turn my climate control off, I seem to have to press the snowflake button, and then turn the fan all the way down. Maybe I am missing something, but this doesn't make sense.
Old Feb 4, 2008 | 01:54 PM
  #115
Birdman's Avatar
Birdman
Yes, that does not make sense. You don't have to press the snoflake button to turn off Auto mode. You just press the auto button, and dependoing on what setting the Auto is currently in, you either press it once, or press it twice to to turn it off. The reason sometimes you have to press it twice is it has 4 modes: On, Off, On with Auto air quality sensing, and ON without auto air quality sensing. So each press of the auto button cycles thru those settings.
Old Feb 8, 2008 | 06:44 PM
  #116
Black&Gold's Avatar
Black&Gold
OK Aaron, it's been more than a couple months since your post on the aftermarket "one touch up windows" software post!
I want it, AND I want it NOW!
Please?
Old Feb 9, 2008 | 09:40 AM
  #117
ClubmanS's Avatar
ClubmanS
My sister has a 2008 Chevy Impala. That car can display actual PSI air pressure readings for all 4 wheels independently on the dashboard. And the system is pretty accurate too.
It puts the idiot light/chime system in the MINI to utter shame
Old Feb 9, 2008 | 09:41 AM
  #118
ClubmanS's Avatar
ClubmanS
Add to that a real water temp gauge.
Old Feb 11, 2008 | 08:44 PM
  #119
ColinMc's Avatar
ColinMc
My car does have one touch up windows...i'm confused...do the 07's not?
Old Feb 11, 2008 | 11:38 PM
  #120
Black&Gold's Avatar
Black&Gold
No, the '07's do not.
Old Feb 12, 2008 | 04:19 PM
  #121
grodenglaive's Avatar
grodenglaive
#7. Actually, I prefer that the wipers revert to "off" when you start the car, at least in the winter. If your wipers are frozen to the windshield when they come on, the link to the wiper motor may break and you will be stranded. That happened with my old civic (fortunately when I was at home), but it was a major pita to fix.
Old Feb 12, 2008 | 04:38 PM
  #122
Modnar's Avatar
Modnar
CD-Text (Artist/Track Names) from Audio CDs when using the Base/Hi-Fi stereo w/o the Nav instead of just the track number.
It shows up on the Nav screen, so the head unit can read it, and you get Artist/Track Names when you put an MP3 CD in, so the head unit can display it. Put the two together and it's Peanut Butter Jelly Time!
Seriously though people, it can't be that hard. My 328i loaner car has what appears to be the same head unit, and it displays CD-Text for audio CDs just fine.
Old Feb 13, 2008 | 08:05 AM
  #123
Birdman's Avatar
Birdman
CD Text DOES display just fine. BUT, not all CD's have CD Text on them!! THAT, is the problem. Why in the world ANY record company today releases a CD without the CD text on it, is beyond me, but they amazingly they still do. It costs nothing, it's a check box when you burn the CD.
Old Feb 13, 2008 | 08:11 AM
  #124
Birdman's Avatar
Birdman
In the winter, when snow ice or rain is coming, ALWAYS park your car with the wipers UP (off the windscreen). Then you never have that "stuck" problem. Makes it easier to scrap and clean the windshield before you take off also. Lasly, you could always shut the wiper off if you want it off when you start it.
Old Feb 13, 2008 | 11:06 AM
  #125
Modnar's Avatar
Modnar
You've got the Nav, so you get CD-Text, but on cars w/o the Nav it doesn't display on the head unit.
I've tried it w/ discs I know have CD-Text (store bought, and burned) and nothing displays on my Navless MCS. See about halfway down this thread.
