St. Louis MINI Club The St. Louis MINI Club Forums. Visit our club site at www.stlmini.com
Need tires for 18" JCW rims
Old 06-01-2011, 03:30 PM
trbo-4's Avatar
trbo-4
trbo-4 is offline
I need to replace 2 tires on my 03 JCW mini. It has Bridgestone runflats on them size 205/40/18. I only checked with one shop but they want like $300 per tire which seems crazy to me. Do any other brands or sizes fit? I wanted to check with the locals as well as do my online searching thanks.
Old 06-01-2011, 03:35 PM
cristo's Avatar
cristo
cristo is offline
Alliance Member
What are your needs?
Summer, All-season, runflat or nonrunflat?
Summer non-runflat - Yokohama S-drive $139 each
http://www.tirerack.com/tires/tires....omCompare1=yes
Summer runflat - Pirelli PZero RFT $279 each
Change to 215/35/18 and you could pick from these 8 summer and 5 all season tires at Tire Rack from $87 to $167 each - all non-runflat, however
http://www.tirerack.com/tires/TireSe...nSpeedRating=S
Old 06-01-2011, 03:38 PM
trbo-4's Avatar
trbo-4
trbo-4 is offline
This car only gets driven in the summer and the runflats seem to be super harsh and expesive so regular tires are fine.
Old 06-01-2011, 03:55 PM
cristo's Avatar
cristo
cristo is offline
Alliance Member
Keep in mind, though, if you change to 215/35/18, you'd want a set of 4, not just 2.
That would keep the ABS and tire pressure monitor system happy.
Many would balk at mixing 2 runflats with 2 non-runflats, but that depends how you
feel about having tires with different handling properties at both ends.
Old 06-01-2011, 04:51 PM
trbo-4's Avatar
trbo-4
trbo-4 is offline
Correct. After doing some further research on tire rack it looks like 4 summer tires would be cheaper than 2 run flats. I think I am going in that direction but was unsure of the two sizes listed. Do I stay with the same size tire or go with the 235. The suspension is stock.
Old 06-01-2011, 08:27 PM
cristo's Avatar
cristo
cristo is offline
Alliance Member
Could easily go with either. One's a little shorter with a wider tread, and the other's a little taller and not quite as wide,
but they're pretty close to each other. More choices in the 215/35/18. Both should fit fine.
The 215/35/18 is about the same diameter as the stock 175/65/15 or 205/50/16 - a common substitute for the stock 16s.
The 205/40/18 is about the same diameter as the stock 195/55/16, and the stock 205/45/17 is about midway between the two.
Old 06-02-2011, 07:48 AM
cristo's Avatar
cristo
cristo is offline
Alliance Member
For specific recommendations:
in 205/40/18: - UHP Summer - Yokohama S-Drive
in 215/35/18:
- Max perfomance Summer -Goodyear Eagle F1 Asymmetric
-UHP Summer - Bridgestone Potenza RE-760
or BFG g-force T/A DDW2 if you don't mind a noisy tire
-UHP All Season - Conti Extreme Contact DWS
Old 06-26-2011, 04:45 PM
C-Lop's Avatar
C-Lop
C-Lop is offline
Fyi, if you buy your tires online, I went with Discount Tire since they were cheaper, Sapaugh charges $10 a tire to mount and balance best price in our area
07-16-2020 12:54 PM
FLYM1N1
10-13-2015 04:33 PM
gmonde
09-08-2015 06:37 AM
Colt45Magnus
09-07-2015 10:47 PM
nomar116
08-09-2015 09:42 AM
Quick Reply: Need tires for 18" JCW rims
