Old Jan 3, 2017 | 05:18 AM
  #18426
Loyal242's Avatar
Loyal242
Originally Posted by Bernard Barbour
Wow, looking great. What do you use to preserve the leather?
Well, the seat back I installed was brand new. Other than that I have not treated the leather seats at all. I do have some leather conditioner that I plan on using soon.
Old Jan 3, 2017 | 06:20 AM
  #18427
Bernard Barbour's Avatar
Bernard Barbour
Originally Posted by Centium
I've been dipping my Minis for 3 years now. I could give you some pointers if you're ever near Des Plaines. Dipping your headlight rings, washer covers, tail light rings, emblems, and grille trim are a great place to get started. After that, check out the Matte Blackout Beltline mod from Outmotoring. I'd probably avoid doing a PlastiDip racing stripe. Buy a real one and have it done professionally if you can. Dipping is best on trim IMHO. Here's the link and a picture of the results of my dipping my Red Pepper...
http://www.outmotoring.com/out-motor...gen2-gen3.html
This is just the rings, grille trim, and beltline. I've already done the washer covers and the license plate cover but it was after this picture. I'll be doing the emblems in the spring.
Thank you for your service!
Old Jan 3, 2017 | 06:40 AM
  #18428
Piano Man's Avatar
Piano Man
Well, the alternator took a poop, so my son installed a new one and our friend has a great shop with a lift, and he only charges $20 to use it! Then, son bought me my first actual mod not counting plastidipping. Got a one ball. Nice new sound and a bit more zip :>)
Old Jan 3, 2017 | 06:42 AM
  #18429
Bernard Barbour
Finally got around to doing some rear hatch and bumper detailing. Whatever glue Mini used to put these quasi fake grill stickers on was a PITA to remove.
Old Jan 3, 2017 | 06:45 AM
  #18430
iwashmycar's Avatar
iwashmycar
Bought another one. '13 R60 All4
Old Jan 3, 2017 | 06:49 AM
  #18431
Bernard Barbour
You gentleman are very fortunate to have a lift available for the low price of $20.00. That's one thing I really miss not being near a military installation that had an autocraft shop (lift, tire changer, paint both, welding etc) for $5.00 an hour and all the tools. Cheers and keep up the good work.
Old Jan 3, 2017 | 06:52 AM
  #18432
Bernard Barbour
Welcome back Adam. Your R60 looks great. Post up more pics and details when you can. Cheers
Old Jan 3, 2017 | 02:49 PM
  #18433
R56BrgMcs's Avatar
R56BrgMcs
Reset my driver side window. It would go down automatically but not up. I used the search button and found out how to reset it! Thanks NAM!
Old Jan 5, 2017 | 07:37 PM
  #18434
Bnourai's Avatar
Bnourai
Another
I took my mini, and bought another,no trade.
Old Jan 5, 2017 | 10:01 PM
  #18435
Neka's Avatar
Neka
R53 Center Console Armrest Fix
When I purchased my R53 last August, the previous owner told me the armrest was broken. The armrest cover that slides open to access the center console storage compartment wouldn't stay closed. Over time, the small tab that provides friction to keep the cover closed either broke or worn down. Every time your elbow rested on the cover, it would slide open. Talk about annoying and frustrating!! I found myself having to close the cover every five minutes while driving to prevent my elbow from going into the storage compartment. :-(
I'm not sure how many have had this same issue but figured there were enough (I watched a YouTube video of a guy using rare earth magnets to fix this problem). After trying the magnet fix, and failing, I tried something else. Since my fix was easier, cheaper and worked really well, I thought I'd share it with the NAM community.
After removing the arm rest, I noted there was an upper and lower track in the lower storage portion of the console. The armrest cover had two sets of short plastic pins on its' underside. These pins snapped into the tracks and guided the cover's movement forward and back when opening and closing.
First, I cut a small piece of masking tape to mark the width and location of the front plastic pins. I noted the pins' forward most position when closed. Second, I transferred the masking tape to the lower console's top track, marking the pin's "closed" position. Then I removed the upper armrest cover. The masking tape markers ended up being about .25" back from the start of the upper track.
Finally, using a shortened wooden kabob stick, I added a large drop of epoxy to each of the upper tracks where the single pin slides back and forth. I hoped adding a little "bump" in the upper track would provide the necessary resistance to keep the armrest cover closed. After the first drop dried for a couple hours, I added a second drop to each track to make sure the bump was large enough to provide the necessary resistance. I waited about 12 hours for the epoxy to fully cure before I tested my fix.
I'm happy to say that my problem is now solved! The cost of my fix was $5 for the epoxy and about a day to remove, repair and replace the armrest. The cost to replace my center console with OEM parts would have been a little over $200 + shipping. I'm including a couple pics to illustrate.
Hope this cheap hack will help someone else.
Old Jan 6, 2017 | 04:32 PM
  #18436
iwashmycar's Avatar
iwashmycar
Bought these "3D Maxpider" floor liners. They seem awesome. Lightweight and more of a soft material. They fit fantastically. Hundred bucks for all 4.
Ive got Husky Liners in my truck and the hard plastic just seemed too brutal for the Mini...since its my wife in heels most of the time....hence the wrong transmission...
Old Jan 6, 2017 | 07:06 PM
  #18437
Ive's Mini's Avatar
Ive's Mini
Today I finished 1/2 of my project. 2 years ago I replaced my leather heated sport seats with a set of heated JCW Lounge leather seats. This was done in the summer, so it was a surprise to me in the winter when I found out the seats I bought were not heated. I disassembled my old seats and removed the heating elements and electronics to install into my new seats. I finally completed that task on the driver's seat. I also added foam to build up all my bolsters. It feels like new! Sunday I will complete the passenger side.
Disassembled
Reassembled
Installed
Old Jan 6, 2017 | 08:16 PM
  #18438
pkunk's Avatar
pkunk
Absolutely nothing.... I spent most of the day plowing out my 1/4 mile driveway after a 18" snowfall so I could drive the Clubman next Tuesday.
Sprung a leak in the plow hydraulics so that fix is in progress before I can finish plowing.
Mini won't go in DEEP snow despite studded snows
Old Jan 7, 2017 | 10:59 AM
  #18439
iwashmycar's Avatar
iwashmycar
Having just bought it with 41K on it I assume oil has only been changed at 15 and 30K miles.
It showed. Dirtiest oil I have ever seen. After I disposed of the used oil this is what the pan looked like. Never seen it cling that black to it before.
Then I checked the air filter. Geesh. Youd think the BMW dealer might just pop their head in there...but no
Aught to run a little bit happier now I hope!!
Old Jan 7, 2017 | 09:29 PM
  #18440
Centium's Avatar
Centium
I bought them recently, but I'm a bit disappointed. I had to cut a 5"x4" section out of the rear floor mat to allow it to fit under the cup holders. The fitment of the passenger seat mat is shoddy. (See attached pic)
How well does yours fit?
Also, I saw your wife on the Countryman Owners Group on FB. Husband is on NAM, wife on FB... typical. lol
Old Jan 8, 2017 | 06:17 AM
  #18441
iwashmycar's Avatar
iwashmycar
Yep thats us!.
My rear mats were separate and fit great on each side of the hump. I heard about having to do that on one-piece designs though.
As far as the pass side one it did slightly bulge but i just yanked it a little towards the console and it went away. Sort of pulled and pushed it under the storage net sort of motion. Hopefully it 'wears in' that way.
Old Jan 8, 2017 | 05:50 PM
  #18442
Snaps's Avatar
Snaps
After abut a month of Egan sitting in my garage, I took him out once again for a little drive, braving the cold temps in the teens. It was certainly nice to drive the Mini again, although I'm afraid he is showing signs of wear. :(
On my way home, I noticed the clutch was slipping in the higher gears (give it some throttle, the revs shoot up, but not much increase in speed). After 160k miles on that clutch, and everything else mechanical, it might be time to do some TLC later this winter season. I already bought a new clutch master cylinder, and clutch slave cylinder (have not installed them yet) and I should also do a brake fluid flush, on top of changing the gearbox fluid as well.
Old Jan 8, 2017 | 07:50 PM
  #18443
Bernard Barbour
It always amazes me. The dealers say they have this 100 point inspection and all that, I don't think so! One time I bought a car and there was no air filter. So from now on I have a to act like a bad guy because I make them put any car I buy on a lift, check everything, make them change the oil if it looks dirty, and fill it with gas before I drive off the lot. If they want my money they will get it but on my terms or I walk. To many times they do this crap and you the buyer end up buying a filter, oil change etc. No more!
Old Jan 9, 2017 | 06:09 AM
  #18444
iwashmycar's Avatar
iwashmycar
Yeah, I had them put this one up on a lift but I was specifically looking for leaky oil solenoids and lines ect. Totally would have thought they would have hit it in that "100pt inspection"...maybe this BMW only had a 90 point LOL
I just wonder, had some 20y/o 'drive-it-like-an-appliance' type-person bought it (probably like the one who maybe owned it), they'd probably have put another 40K miles on that freaking filter.
Old Jan 9, 2017 | 06:12 AM
  #18445
Wow, thats pretty dirty. I dont think that been changed since new on the filter. That oil is pretty dirty also. On the turbo engines the MINI oil gets pretty dirty quick compared to my Gen 1 MINI non supercharged. Glad you got that stuff done.
Old Jan 10, 2017 | 08:29 AM
  #18446
R56BrgMcs's Avatar
R56BrgMcs
I had the CEL come on again today! This is the third time in the last three weeks. Each time it comes on it says P2188 too rich at idle. At first I thought that the cold had been doing it, it's been about 9 degrees f for the last couple weeks. I have checked the connections on all the tubing and it's good. Yay.
Old Jan 12, 2017 | 11:40 AM
  #18447
Loyal242's Avatar
Loyal242
Just routine maintenance: cleaned and oiled the air filter.
This picture is from when I installed the CAI last year.
Old Jan 12, 2017 | 02:29 PM
  #18448
Bnourai's Avatar
Bnourai
Added my wheels and the new C/F VIS hood.
Attached Thumbnails What did you do to your mini today?-20170112_100211.jpg   What did you do to your mini today?-20170112_100203.jpg   What did you do to your mini today?-20170112_100129.jpg   What did you do to your mini today?-20170112_100104.jpg   What did you do to your mini today?-20170112_100111.jpg
Old Jan 12, 2017 | 02:57 PM
  #18449
Bernard Barbour
Oil change, transmission fluid flush and removed the fake sticker "grill" from the rear bumper. Found a busted control arm bushing while I was under there.
Old Jan 13, 2017 | 07:27 AM
  #18450
JABowders's Avatar
JABowders
Veteran: Army
Driving MC40 #24 today such a great running car with only 264K miles.
I cleaned and sprayed the rear brake rotor wheel mounting surface with High Temp (1000 F) silver paint to prevent more surface rust on my R52.
Motor on!
