R58 2014 R58 JCW suspension question
Old Apr 2, 2024 | 05:43 PM
Bean0709's Avatar
Bean0709
Hello fellow Mini-motor people!
I just bought a 2014 R58 JCW with a lot of miles and it seems to need a new suspension. My question is…I do not like how low the car rides because even the slightest decline you have to be super careful and drive very slow not to scrape. It is not like I weigh a lot, only 135#. Also, I live in Illinois and it can snow an awful lot. I want to know if anyone has suggestions to put all new suspension on the car that will raise it considerably. I know most people like to slam cars, but I am quite the opposite. I do realize it will not handle as well as being low, but I do not care. I like a little higher look.
Old Apr 3, 2024 | 04:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I could make some suggestions, but do you know what it has for suspension already?
If you have the OEM black shocks and springs, for a full refresh, I might start with trying to find a set of JCW red springs, and match them with Bilstein B6/8 shocks. Then finish it off with this install kit:
https://www.ecstuning.com/b-packaged...31306772749kt/
Old Apr 3, 2024 | 04:54 AM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
Regardless of what mods you make with the suspension, you do want to add this to your Coupé:
https://www.ecstuning.com/b-rennline...plate/u03~rel/
This has saved my oil pan and transmission on a number of occasions, judging by the scrapes and gouges it has accumulated over the years.
Old Apr 3, 2024 | 05:27 AM
Bean0709's Avatar
Bean0709
Thank you!
Old Apr 3, 2024 | 05:29 AM
Bean0709's Avatar
Bean0709
Thanks you. Yes, it has JCW parts on it. The previous owner lives to hit Chicago potholes and must have put new tires on 4 times as well as had to straighten wheels. As a matter of fact, I believe one is current bent as there is some feeling in steering wheel when driving.
How many inches higher do you think this setup will get me?
Old Apr 3, 2024 | 05:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If it has the OEM JCW springs on it already, just get the Bilstein B6 shocks and the install kit. You won't get any higher, but it will bring the suspension back up to like new.
Old Apr 3, 2024 | 05:39 AM
Bean0709's Avatar
Bean0709
If I do not get a great suggestion to add some height with quality parts, I will most definitely take the advice.
Old Apr 3, 2024 | 05:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Here are the specs for the R58 ride height. You could go measure before swapping out parts to see how it compares to the OEM height.
Old Apr 3, 2024 | 05:45 AM
Bean0709's Avatar
Bean0709
How did you find this? I was looking everywhere for the ride height. I have owned many R56 JCW Coopers and I was trying to determine if those were higher or lower than the R58.
Old Apr 3, 2024 | 05:55 AM
Bean0709's Avatar
Bean0709
What is “low-slung?” I think I need to find the JCW suspension that is in the middle of the standard and the optional JCW.
Old Apr 3, 2024 | 06:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I am under the impression that the "Low Slung" suspension is the JCW red springs. You can see from the specs that the "Low Slung" suspension drops the car by about 10mm. If your car has the EOM black springs installed, yours would be the "John Cooper Works Standard Suspension" specs.
Those are from the newTIS site. I can send you a PM with instructions for access.
Old Apr 3, 2024 | 06:09 AM
Bean0709's Avatar
Bean0709
That would be great! Thank you.
Old Apr 3, 2024 | 06:35 AM
Bean0709's Avatar
Bean0709
That link worked great. Thanks again.
MiniMaestro
R55 :: Clubman Talk (2008+)
Jun 11, 2014 02:55 PM
j997tt
Feb 22, 2014 09:02 AM
pgrmstr
R58 :: Coupé Talk (2012+)
Mar 29, 2012 10:56 AM
jdurdick
Oct 27, 2011 10:08 PM
