Hose from Transmission
Old 04-17-2018, 11:36 PM
Veli410's Avatar
Veli410
Veli410 is offline
Hello all. Did some engine mount replacements on my 2010 Cooper Base today and after putting everything back together the car is much smoother.
I noticed a plastic hose coming from right underneath the transmission mount And leads nowhere, I’m wondering if I snapped something and I’d sonethibg is missing from that hose or is it just like a breather hose or something. I have attached pictures so if you know what that hose is please let me know, I just want to be sure I did not mess something up, I didn’t unplug any hose while removing the old trans mount
It’s simply coming from the tranny and pointing down like it’s a breather or something
Old 04-18-2018, 04:35 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
you are correct. it is a breather and go nowhere...you're good
Old 04-18-2018, 07:44 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Yes it's a breather vent hose, no need to worry about it
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 04-18-2018, 08:05 PM
Veli410's Avatar
Veli410
Veli410 is offline
Thank you all for your quick replies. This is my wife's mini, and our first time owning one and I have a love/hate relationship with the car
I'm just now starting to work on some issues it has, mount is done and now I need to find a whining noise coming from the belt area, I had been convinced it was the friction wheel (from purely readingforums/youtube and speculation, I know, bad idea to conclude without actual diagnosis) until I started working on the mount and decided to do some troubleshooting and diagnosing.
I disengaged the friction wheel momentarily to see if I could isolate the culprit, It wasn't it, whining noise persisted, I have replaced the tensioner pulley before so I know that's not it, It's also not the water pump because when the friction wheel was disengaged the water pump wasn't moving. I think that leaves the AC compressor, Alternator and Crank pulley. I used a stethoscope and it sounds like its coming from the alternator. When I see other mini coopers around, including my neighbors, some have the whine as well. Anyone have an idea or experience with this? Or do these carss just whine? Not sure how I could further isolate it, I've had my fair share of misdiagnosis in the past Will record the whine and post a video.
As always, Thank you all.
Old 01-09-2022, 10:04 AM
Norbert77's Avatar
Norbert77
Norbert77 is offline
My 2009 6speed manual doesn't have that hose, should I be worried? I was looking for the breather to see if it is clear, I have a leaking axle seal and want to see if pressure buildup is the cause
Old 01-10-2022, 06:24 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Manual trannies dont have the breather.
Old 05-19-2022, 02:01 PM
Fastedy's Avatar
Fastedy
Fastedy is offline
Breather hose on auto transmission
I Just broke my breather hose off by accident... Any tips on how to replace it? Does it make it easier to remove the fuse boxes on top? Thanks in advance
Old 05-19-2022, 03:29 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
check it on it ebay. it might it be easy to place it back through the driver wheel well.
Old 05-19-2022, 04:28 PM
Fastedy's Avatar
Fastedy
Fastedy is offline
I broke it from the base 😅
Old 05-19-2022, 04:30 PM
Fastedy's Avatar
Fastedy
Fastedy is offline
So I have to order a new one. Don't want a coolant leak to destroy the transmission. I need to remove it completely to replace it. It's just hard to get to been next to the thermostat.
Old 05-20-2022, 08:43 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Let me check if I have an extra one. You're referring to the breather nipple coming out of the transmission NOT the hose itself, right?
Old 05-20-2022, 01:56 PM
Fastedy's Avatar
Fastedy
Fastedy is offline
Yes I already bought the part. Barely goin to start looking for the best way to reach it and replace it. Is it easy to take off? Use a plier to take off the rest of the hose that broke?
YellowTiger
03-04-2020 05:13 AM
Minmcint
03-02-2019 07:12 AM
txcanuck
06-01-2017 04:57 PM
TrueEddie
02-25-2012 03:06 PM
Quick Reply: Hose from Transmission
