R56 Things you didn't know about your R56 MINI
#1153
I don't get this. The a/c has it's own switch. You can run the fan without ac with the auto system. Recirc is also separately controlled. Leave recirc off, a/c off and fan on whatever speed you want.
#1154
I can see the point being made. My Integra allowed fresh air to come through the vents without the fan. At 45+ mph you got a good draft without using the fan. With the MINI you seem to have to have the fan on to get fresh air, even if the AC is off.
#1155
#1156
#1158
on
EXACTLY! It has worked this way on every other car I've ever owned (and I've had quite a few over the past 40 years). I don't know why no one can understand this--I've mentioned this on a few threads before this. Guess I can't explain it as well as you did. Thanks!
#1160
If the brake light turns red and stays on it means the OBC thinks your past due on your brake job(either front or back).You can tell by the red MINI pic w/circle above(either front or back) on the tach when you startup.I had that light on for a week until last night I found out how to reset all service lights and got rid of it since my front brakes were NOT in need of changing.
#1163
I'm guessing orange is the normal "checking all indicator lights" you get when you turn on the car and red meaning I have the parking brake on. I'll have to try it without the brake on.
#1164
I like leaving the recirc on auto as sometimes, like now during pollen season, when I don't want outside air getting in but still want air circulating. Hit auto air, auto recirc, and turn off the a/c and I'm good to go motoring.
#1165
Okay, I get it. But that means there is no way to stop the air from coming in. Why would you want that? I like Mini's way better. You want air, put on the fan; you don't turn it off vs. You don't want air, tough.
#1166
Actually in this case you can switch to recirculate and it will stop the air flow. Every car I've had since the 70's has allowed for fresh air to come through without a fan on like Robin mentioned. My MINI is the first that has needed a fan.
#1167
Yeah, but I would like to allow outside air to seep in without having it blow on me, if I choose. With recirc on, the windows sometimes fog up.
#1170
on
I think that's the key--at least it is for me--the fan is noisy (and interferes with my audio-book). Besides, I see dollar bills flying away when I think of repairs. As for not having the air come in, I just twist the vent **** shut. In my last car, a '94 BMW 325i, I could hear the damper open or close when the outside vent vs. air conditioning control was manipulated.
#1171
on
I think that's it, too. I remember when the SZL went out last year the yellow brake light stayed on (red, if the brake was engaged). It was telling me all was NOT well with the system, in addition to the other failure items.
#1172
Hi guys, finally got my MINI "Horse" on friday and it was love at first sight.
So yesterday my girlfriend parked the car near the park to go for a run. She didn't want to take her whole keychain so she just took the keyfob off of the emergency spare key (I got convenient access), and went to close the trunk. But the trunk kept popping back open and she realized that the whole keyfob had to be together because the car wasn't going to let her lock any part of her keys in the car.
Just one of many cool things we've discovered so far over the first few days.
#1173
With comfort access, your car won't lock if the fob portion of the key set is left inside. I officiate a lot of softball games and I don't want all of my keys with me. I disconnect the key set and take just the fob portion with me. That does the trick.
#1174
Congratulations on receiving your new car.
That's actually what she was trying to do. She had the fob part in her pocket but the emergency key was in her backpack attached to her keychain in the trunk. Do you have comfort access? I thought maybe this was some safety measure on the mere chance that her fob would run out of batteries and she would need the emergency key to get in the car? It seemed as if the key had to be in the fob to lock the car with comfort access, let me know if this is incorrect.
#1175
Is the spare fob (your second vehicle key) inside the backpack left in the trunk? If you have either fob inside the vehicle, the car will not lock. Basically, it's made so that you can't lock your keys in the vehicle.
