R56 Things you didn't know about your R56 MINI
Old Mar 13, 2008 | 07:13 PM
  #876
Msteadman's Avatar
Msteadman
Yea, as to your first question I'd get that checked out. Definitely a malfunction of some sort.
To your second question, for security/precautionary measures the doors must be unlocked either by hitting the interior switch or the button on your remote in order for the boot to open (unless of course you just hit the actual boot button on your remote). I believe with comfort access, I don't have it but I'm sure others will confirm, the boot can be opened regardless by simply pressing the 'handle' above the license plate.
Old Mar 13, 2008 | 08:31 PM
  #877
Minidrivr's Avatar
Minidrivr
Exactly. Walk up to my locked Mini, press the boot handle and it opens. When I close it, it relocks, assuming I didn't set the key in the trunk, not that it ever leaves my pocket. But I can see where a woman carrying a purse who might set it in the trunk could be in this situation.
Old Mar 14, 2008 | 05:20 AM
  #878
acebutt's Avatar
acebutt
Originally Posted by Black&Gold
Why does my one "key remote" not open my hatch? (The one I use regularly does)
Why can't I open my rear hatch after I get out of the car if I don't hit the unlock on my remote? even with the drivers door is open.
Might be that each key needs to be programmed with your preferences as to lock/unlock , single/triple blink, & radio presets.
Old Mar 14, 2008 | 09:05 AM
  #879
Wolfgang80's Avatar
Wolfgang80
Heated Mirrors
The heated mirrors that are part of the cold weather package do not have a switch. They heat automatically when they get below a certain temperature.
How I found this out: After parking my car outside overnight for the first time, I came to the car and it was covered with dew. One of the reasons I got the CW pkg was for the possibility that heating the mirrors would remove the dew without me having to wipe it off manually. I looked around and couldn't find anything that looked like a mirror heater switch, so I consulted the manual and the above is what it said. I was disappointed that I don't have control over this function and living in socal, I'm not sure if it'll ever get cold enough to activate these.
Old Mar 14, 2008 | 02:31 PM
  #880
daffodildeb's Avatar
daffodildeb
I don't think hatch unlocking is a programmable feature. I know both of my key fobs are programmed alike in everything except the radio preferences, and one opens and one doesn't open the hatch with the button.
Old Mar 14, 2008 | 07:16 PM
  #881
Minidrivr's Avatar
Minidrivr
I think the programmable feature that is referenced is the fact you can program the trunk to unlock with a single press of the unlock button on the fob, along with the other door. Instead of having to press the unlock button twice.
Old Mar 15, 2008 | 05:07 PM
  #882
geekswrath's Avatar
geekswrath
Found this one out today, if you travel 80 mph and use the windshield wipers you can hear a neat wooshing sound from the air passing over them.
Old Mar 15, 2008 | 05:50 PM
  #883
VelvetFoot's Avatar
VelvetFoot
You can play the radio without a key in place.
Old Mar 15, 2008 | 10:57 PM
  #884
LUCK219's Avatar
LUCK219
Sorry to slightly change the subject, but does anyone know or seen a thread somewhere with a list of programmable options?? I'm picking up my new mini in a few days and would like to know what to ask them about before i motor home.
Thanks.
Old Mar 15, 2008 | 11:21 PM
  #885
daffodildeb
You'll program everything yourself--just get a brief rundown on how to use the computer. The rest comes from the book...
Old Mar 16, 2008 | 06:09 AM
  #886
Auford's Avatar
Auford
Read the manual. You can program the interior lights not to come on.
Old Mar 17, 2008 | 12:26 PM
  #887
Loony2N's Avatar
Loony2N
If you do a search under a category in the Info section of the navigation, the icons for all the places in that category will appear on the screen, unless you go back into info and turn off icons. I searched for a particular campus of U of Md and after I returned to the main map and even with the nav off, little graduation caps appeared all over the map. Caveat: The electronics on my MINI have amind of their own, so I don't know if this is normal or part of the Frankenstein programming my MINI has.
Old Mar 17, 2008 | 01:12 PM
  #888
daffodildeb
Ok, I've got a couple:
If you pull the windshield washer stalk partly, you'll get water but no wipers. If you pull it fully, you'll get both, of course.
Also, if you have your door open, click the hatch open, but shut the side door before actually opening the hatch, it will lock again. You have to completely open the hatch before shutting the door. At least that's the way mine works--it's always been a little weird, but maybe this new observation explains it.
Old Mar 17, 2008 | 01:16 PM
  #889
tjtull's Avatar
tjtull
True...I have the comfort package and the radio stays on until I lock the door.
I'm wondering if there's a way to activate the cigarette lighter power without having the engine on. Anyone know? I didn't see it in the manual...I looked.
  #890
Loony2N's Avatar
Loony2N
If my key is in my briefcase in the boot, the car will still start (with comfort access), but if the key is in my coat pocket, just inches from the rear hatch, there is a huge delay from the time I press the hatch button until it unlocks, except for those times there isn't.
Old Mar 17, 2008 | 01:17 PM
  #891
Loony2N's Avatar
Loony2N
Push the start button twice without depressing the clutch.
Is there a way to keep the radio on when the engine is off? Although the radio can be on when the engine is off, it only stays on about 20 minutes, even with the starter in the equivalent to aux position.
Old Mar 17, 2008 | 01:21 PM
  #892
tjtull's Avatar
tjtull
Thanks.
I haven't tested how long the radio stays on yet. I only know it stays on every time I turn the car off...which is a bit annoying at times. Wait, don't tell me...I can push start again without my foot on the clutch and it will stop
Old Mar 17, 2008 | 01:45 PM
  #893
daffodildeb
I'm actually glad that the lighter power goes off when the engine is off--makes it easy for me. I tend to forget pulling power on the radar detector!
Old Mar 17, 2008 | 01:46 PM
  #894
tjtull's Avatar
tjtull
I agree with you there. I was just looking for a way to turn it on without the engine.
Old Mar 17, 2008 | 10:18 PM
  #895
unixgal's Avatar
unixgal
Twisty Road Lover
Has anyone found a way to have the seat lock in a fixed position when the seatback is pulled forward???
I was taking a swaybar to get installed this morning and in order to get the box in the car I had to have the back seats down and front seat tilted forward. What I found TOTALLY ANNOYING is that the seat would continually slide forward and back with any sudden speed change (i.e. stopping/starting). I'm sure it's because of the "memory" feature for the front seat when letting people in the back, but I'd hope there would be a way to stop it.
Any ideas?
Old Mar 17, 2008 | 11:39 PM
  #896
Robin Casady's Avatar
Robin Casady
Any ideas?
Bungee cord from the headrest bars to the bottom of the seat to hold the back tilted forward. Wedge a watermelon behind the seat to keep it from sliding back.
Old Mar 18, 2008 | 05:55 AM
  #897
D-Unit's Avatar
D-Unit
pretty sure you can just turn it on again. i seem to remember doing that on accident once. so i guess it turns off after about 20 mins to stop you from killing the battery, but then you can turn it back on right after for as long as you want until the juice runs out.
Old Mar 18, 2008 | 07:02 AM
  #898
Minidrivr's Avatar
Minidrivr
I would imagine it's the same for non-nav cars but the day I took delivery I spent so much time going through the Nav system the car finally gave an alert and said the voltage was too low. So at least the car will warn you before you run the battery down too far.
Old Mar 18, 2008 | 07:52 AM
  #899
Loony2N's Avatar
Loony2N
This is true. But I don't think there is a way to keep it on. I would like to be able to decide for myself. The car can (be programmed to) detect when the battery is weak, after all.
Old Mar 18, 2008 | 10:31 AM
  #900
CSC.RCC's Avatar
CSC.RCC
Then I must have a weirdo radio, I sat through an entire drive-in movie without having to turn the radio back on last summer. So long as I (and the key) was in the car, it played straight through.
