R56 access to foglight bulbs
Old May 23, 2025 | 03:08 PM
cciman's Avatar
cciman
How do i open the foglight housing to reach the bulb?
Can the bulb be replaced with LED, or will they flicker? Can the front lens be replaced, it is very cloudy and seems to be on the inside.?
Old May 23, 2025 | 05:40 PM
Seaswood's Avatar
Seaswood
Those look aftermarket you can look realOEM.com
Old May 24, 2025 | 07:26 AM
cciman's Avatar
cciman
The mini logo is on the inside of the glass, so that's unlikely.
They don't look aftermarket. The bracket and the wiring look natural to the car. The previous owner was not mechanical.
I don't see a way to get the lens off the lamp, and there's no opening in the back.
Old May 24, 2025 | 11:07 AM
Gubi's Avatar
Gubi
Those aren't fog lights, those are the optional driving lights. Here's a link to the install manual and it has instructions on how to change the bulbs:
https://motoringfile.com/files/R56_aux_lights.PDF
Old May 24, 2025 | 01:41 PM
cciman's Avatar
cciman
Very helpful, Thanks,
I'm new to this car, and resources.
I see that there's a huge collection of pdf files on that link. Is there a searchable interface to look for other files for future projects, and problems. (ie, how did you drill down to that pdf?)
Old May 24, 2025 | 01:49 PM
Gubi's Avatar
Gubi
I searched google for instructions for the light and found a forum post that had a direct link to the PDF.
Not sure if they'll flicker if you put in LEDs. I don't *think* I recall seeing bulb check or warnings for the driving lights in NCS Expert? So they might be okay?
If not you can probably fix that using NCS Expert or Bimmergeeks ProTool.
Old May 24, 2025 | 06:18 PM
Pinky Demon's Avatar
Pinky Demon
How do you like those driving lights? I’m considering adding them onto my car.
Old May 25, 2025 | 08:27 AM
cciman's Avatar
cciman
They look great on the car...I haven't driven in the dark yet to know how well they light up. Aesthetically pleasing, there is a hidden fastener on the bottom of the light, near the mounting arm, that I would not have seen without the PDF above.
Old May 29, 2025 | 05:04 PM
cciman's Avatar
cciman
Either the bulbs are blown, or the switch I've tried doesn't work (the one in the PDF above).
xradman
Electrical
26
Jun 12, 2023 06:51 PM
andysinnh
Sep 6, 2021 01:22 PM
umberto
Jan 21, 2017 01:14 PM
tcowden
Sep 13, 2010 11:48 AM
DjR53
Electrical
Dec 3, 2009 04:05 PM
