R56 R56 Auto to manual swap
Old Jan 9, 2023 | 05:08 PM
hunt25's Avatar
hunt25
Has anyone done a auto to manual swap on a R56 base mini? I am trying to figure out all the parts that I will need to do the swap.If anyone could give me a parts list that would be helpful and would I need to reprogram my Ecu?
Last edited by hunt25; Jan 9, 2023 at 05:09 PM. Reason: Needed to add more information
Old Jan 9, 2023 | 06:50 PM
Gubi's Avatar
Gubi
R56 cars are neither rare nor particularly expensive at this point, and a transmission swap on a modern car is not an easy feat. If you have an auto and want a manual, you would almost certainly be much better off just selling your car and buying a manual.
Old Jan 10, 2023 | 09:06 AM
hunt25's Avatar
hunt25
Swap
The issue is that I can’t sell it I’m to far under in it but I am missing having a manual
so that’s why I would like to do a manual swap
Old Jan 10, 2023 | 07:05 PM
Gubi's Avatar
Gubi
So, I'm not your financial advisor, but if you're that far underwater on a car that's 9+ years old I'm not sure you should be putting a bunch of money into modifying said 9+ year old car. It's not a particularly easy or cheap undertaking.
Old Jan 10, 2023 | 07:38 PM
CakeEater's Avatar
CakeEater
Definitely would need to reprogram your ECU, but its def possible. What year and specs mini do you have? Are you familiar with realoem.com?
Old Jan 11, 2023 | 11:10 AM
hunt25's Avatar
hunt25
Swap
It is a 2013 mini hatchback base model
Old Jan 11, 2023 | 12:58 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
With all the sensors and monitors these cars use, I would bet you'd be in a world of hurt trying to get everything to talk correctly without having a host of codes
Old Jan 11, 2023 | 07:06 PM
Ive's Mini's Avatar
Ive's Mini
I am doing a auto to manual swap on a R52 right now. I can tell you, find a parts car for cheap. You will have almost everything you need. You will just need to add a flywheel and clutch. Then whatever programming is needed. That is the way to go.
EchoRabbit
Mar 13, 2023 08:08 PM
mocha7
Dec 28, 2018 02:41 PM
fjarnskaggl
Aug 10, 2018 03:23 AM
Arrfiftysix
Sep 10, 2013 09:48 PM
TheBluePotato
Classic Mini Talk
Nov 24, 2006 09:46 PM
