R56 r56 frame rail measurement request
Old May 21, 2022 | 08:22 PM
mini_me123's Avatar
mini_me123
Normally I can find these measurements in shop manuals (for collision corrections) but not on the r56 manual I found online.
Can someone be able to provide the measurement between the flat vertical surfaces? Basically the dimension closest to one another before the crash tubes. Thank you.
Old May 22, 2022 | 04:05 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
See attached. Does this help?
Old May 22, 2022 | 05:36 AM
mini_me123's Avatar
mini_me123
perfect, how did you find this? Do you have access to r53 too?
Old May 22, 2022 | 10:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That is a page from the NewTIS online manual.
Old May 22, 2022 | 06:32 PM
mini_me123's Avatar
mini_me123
looks like the site got a takedown request and is shut down now. Do you have a link? I'd like to look through r53 frame measurements as well.
again, thanks
Old May 23, 2022 | 08:22 AM
Mnkytweet's Avatar
Mnkytweet
I can't help with the measurements......
Is there an engine swap in the works?!?!
Old May 23, 2022 | 08:12 PM
mini_me123's Avatar
mini_me123
maybe, depending if r56 is any much wider between rails. If not, no point.
Old May 24, 2022 | 03:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Here is the same page from the R53 section. Looks like the R56 has more room between the rails.
Old May 24, 2022 | 04:34 AM
mini_me123's Avatar
mini_me123
cheers, thanks again
It's a bit difficult to tell. The r53 measurement points are a bit closer to the inside than the r56's taken mid-point. The frame rail seems a bi fatter and curving inwards too on the r56. Interesting that the 53's are asymmetrical. I should be able to figure it out given the drawings are to scale
heticor
Aug 24, 2020 08:20 AM
alpinamike
Nov 3, 2007 12:50 PM
Helix13mini
Aug 25, 2007 02:39 PM
chows4us
Jul 3, 2007 12:42 PM
R56MCS
Jan 24, 2007 10:04 AM
