R56 Replacement battery registration.
Old Jun 9, 2021 | 09:56 AM
tanjg's Avatar
tanjg
Hi all,
I just replaced my OEM Varta (dead) battery with a bigger EXIDEMXH6L348MARATHON MAX AGM by myself. Do I need to register this battery, how do I go about it?
Thank you!
Old Jun 9, 2021 | 09:57 AM
Jason Cornelius's Avatar
Jason Cornelius
Originally Posted by tanjg
Hi all,
Thank you!
on your negative terminal was there something that resembled a fuse? If not then you should be good.
https://www.ecstuning.com/b-genuine-mini-parts/battery-cable-ibs-negative/12427603567~oem/
Old Jun 9, 2021 | 10:00 AM
tanjg's Avatar
tanjg
"Was there?".... Do you mean on the old battery? There is something right in the center that perhaps looks like a fuse, not sure though. The new battery is in now and seems perfectly fine.
Old Jun 9, 2021 | 10:01 AM
Jason Cornelius
Does your negative cable look like this?
https://www.ecstuning.com/b-genuine-...427603567~oem/
Old Jun 9, 2021 | 10:02 AM
tanjg's Avatar
tanjg
As far as I remember, it was a plain vanilla terminal, no electronic component on it. I will take another look though. What if there is a fuse?
Thank you!
Old Jun 9, 2021 | 10:04 AM
Jason Cornelius
Thank you!
if it’s a plain vanilla terminal then you are fine. If it’s like the one from above then you need to register it and I think your foxwell should be able to do it.
Old Jun 9, 2021 | 10:15 AM
Capt_bj's Avatar
Capt_bj
if it needs to be registered (because it has IBS Intelligent Battery System) and you don't do it
your battery won't charge optimally, especially with your having changed the battery capacity
it will work fine for now, but you may experience a shorter battery life due to less than optimal charging
https://www.batterypoweronline.com/a...otive-designs/
Old Jun 9, 2021 | 10:52 AM
Tarponbeach's Avatar
Tarponbeach
If you do have the IBS and need to register it, there is an app for that. Bimmerlink, along with an OBD Dongle will allow you to register the new battery, as well as a host of other things that you can do/view.
https://bimmerlink.app/
Masonotfound
Oct 21, 2021 09:36 AM
lil'valentino
MINI5280
12
Mar 21, 2013 09:59 PM
joltfreak
Classic Mini Talk
Mar 17, 2009 04:09 PM
