R56 Can someone tell me what hose this is pictured? Thanks
Old Oct 15, 2020 | 11:26 AM
C_Heath's Avatar
C_Heath
Fixing multiple items on the R56 this weekend. one question, what’s the name of this hose pictured?
Thanks!
Old Oct 15, 2020 | 12:00 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The "Official" name is "Charge Air Line #9"
https://www.realoem.com/bmw/enUS/sho...diagId=13_1206
Unfortunately, Mini does not sell just that rubber tube on its own.
https://www.ecstuning.com/b-genuine-...t/13712753075/
There are many aftermarket options available:
https://www.ecstuning.com/Mini-2012-...s/Performance/
If you want an OEM replacement, I would go to Ebay.
Old Oct 15, 2020 | 12:02 PM
Jason Cornelius's Avatar
Jason Cornelius
https://www.ecstuning.com/b-genuine-...t/13712753075/ - stock replacement
https://www.ecstuning.com/b-alta-per...pitr352bk~app/ - upgrade and cheaper
Old Oct 15, 2020 | 12:04 PM
C_Heath's Avatar
C_Heath
thank you!
C_Heath's Avatar
C_Heath
Originally Posted by Jason Cornelius
thank you!
Old Oct 15, 2020 | 12:41 PM
Jason Cornelius
Originally Posted by C_Heath
thank you!
no problem if i where you, go with the upgraded piece and ditch the stock stuff, If i didnt pick up the sneed4speed turbo muffler delete for 20 bucks then this would be the route i would go and still might later on.
Old Oct 15, 2020 | 12:46 PM
C_Heath's Avatar
C_Heath
thanks! Im new all this Mini stuff. Its a cool car but dang man!
Old Oct 15, 2020 | 12:54 PM
Jason Cornelius
https://www.northamericanmotoring.co...ed-gen-ii.html - good maintenance routine for these
https://www.northamericanmotoring.co...07-2013-40470/ - how to's for this generation
Keep an eye on the oil, these N14's like to burn it. There are tons of threads on the woes of the N14, i have 152,xxx on mine and she runs like a top, im pretty **** about keeping the oil topped off and changed every 5k. My next oil change, I'm going with Liqui Moly's suggestions, email from one of their engineers, and going to Flush it, then their 5w-40 oil and motor oil saver and a bottle of jectron in the gas tank. I will be doing it 2k shy of 5k due to the fact that it is pretty dark already and she wont be seeing anymore dragon time this year, so this next change will most likely last till spring time.
Old Oct 15, 2020 | 01:13 PM
C_Heath's Avatar
C_Heath
just got this one for my 16 year old daughter. It’s truly a nice car but we have 5 Honda’s man and I’m use to just putting gas in them and maybe a light bulb here or there. I can do a lot of this stuff by myself so that’s a plus. Shy of pulling a transmission or something. Thanks again for the help. I keep the oil topped off. You’re right it does consume it. I had to add a half quart yesterday but it’s due for an oil change which I’m going to to sat along with...
high pressure fuel pump
diverter valve
temperature sensor and lead
oil change
plugs
all 4 coils.
check to make sure all the air hoses are tight. It has a 2885 code. Along with a few others. 🤦‍♂️🤪
Old Oct 15, 2020 | 01:21 PM
Jason Cornelius
diverter valve
oil change
plugs
all 4 coils.
the 2885 might be your DV, and you seem to be on the right track for some of the other maintenance items. Changing the transmission fluid and coolant isn’t too hard and there are videos on how to do. Only fluid I haven’t changed is the brake fluid, which I boiled this last weekend on the Dragon and will be flushing as soon as my power bleeder gets here.
Old Oct 15, 2020 | 01:38 PM
Jason Cornelius
Picking up a scanguage isn’t a horrible ideal either. This will allow you to watch temps that you don’t have a gauge for. Search the classifieds you should be able to find one used for under 100.
Have mine set for intake temp,boost, water and oil temps
Old Oct 15, 2020 | 01:42 PM
C_Heath's Avatar
C_Heath
ive got a hand held. Works good
Old Oct 19, 2020 | 12:11 AM
Minifenrir's Avatar
Minifenrir
Heath the hand held is nice but the scan gauge is for monitoring at all time while you go. The mini does not have a water temp gauge at all just the "you now have a blown head gasket light" It's nice to be able to monitor the life signs of the Mini motor at all times. Early warning can be a life saver.
Old Oct 19, 2020 | 03:00 AM
Jason Cornelius
I have been pretty lucky so far. I had a split in my coolant tank that caused the car to boil and lose coolant, I caught it early enough, but this caused me to buy the scanguage. Keeping an eye on temps eases my mind.
kucils69
Dec 26, 2018 10:31 AM
aznqtboy984
Nov 20, 2012 06:34 AM
TA2DMAC
Classic Mini Talk
Jun 9, 2012 08:40 PM
MSFITOY
Mar 9, 2004 08:08 PM
