R56 R56 excessive sunroof noise
Old Jan 10, 2020 | 06:41 AM
N54's Avatar
N54
So I think this is well documented, but the only responses I've been able to dig up regarding the issue is "take it to the dealer".
I'm driving an 09 MCS so going back to the dealer isn't really an option (unless of course I wanted to throw money away lol). Anyone do any sort of DIY to fix this issue? Seems like something to do with the seals around the sunroof.
Symptoms:
wind noise, no whistling just noisy at high speeds say 60+mph.
Old Jan 10, 2020 | 08:25 AM
Needs adjusted or the sunroof seal is shot. If the roof is flush and matches the gap on all the seams, then its the seal/.
Adjustment: https://www.northamericanmotoring.co...ind-noise.html
https://www.ecstuning.com/Mini-2009-...erior/Sunroof/
Old Jan 10, 2020 | 09:53 AM
N54's Avatar
N54
Yeah roof looks pretty good, it's all flat and the gap seems uniform throughout. You're saying its the linked seal then?
Old Jan 10, 2020 | 09:55 AM
Yep, on my old R56S my seal was cracking from the sun and i used chemical guys VRP to buy some time, but it needed replaced, in the winter it would whistle.
Old Jan 10, 2020 | 09:56 AM
N54's Avatar
N54
Probably best to do both the front and rear while I'm at it. Thanks!
Old Jan 10, 2020 | 03:03 PM
thebombardier's Avatar
thebombardier
For what it's worth mine was making a lot of noise almost like a wheel bearing wearing out or a tire rubbing. The rear pane slider was disconnected from the frame at the hinge, the screw backed it out on the driver's side.
Old Jun 2, 2020 | 04:39 PM
jjcsnlynn's Avatar
jjcsnlynn
ECS,
When I read your descriptions it seems both of the seals you sell are for the rear sunroof pane even though one says front in the title.
Mine will make noise at highway speed when closed at stop and make noise at slow speed when shut at highway speeds. A simple open and close quiets it down...still seals?
Old Jun 3, 2020 | 07:09 AM
Main seal is this part which we dont acrry as its sold by the meter: https://www.ecstuning.com/b-genuine-...f/54109813474/
You will have to go to your local dealer for that. We dont stock and cut these. ^^
Diagram # 6 https://www.realoem.com/bmw/enUS/sho...72#54102755851
#8 is the center front and # 7 is the rear. Both listed above.
If the seal is ok and just off you can have it adjusted, linked above. If its not plush(off a hair) then try gummi Pflege first to try to renew it. https://www.ecstuning.com/Search/SiteSearch/gummi/
I use that on my convertible and door seals.
Old Jun 15, 2020 | 01:28 PM
Hello, did you see my post above?
Old Jun 15, 2020 | 01:49 PM
jjcsnlynn's Avatar
jjcsnlynn
ECS,
I did. We spent a day adjusting the sunroof according to the Bentley and the air is reduced but still there. It was a pain and I’m not sure I want to do that again.
Once I get the gumption up to tackle it, I’ll order your seals.
Old Jun 15, 2020 | 01:58 PM
Ok
Just making sure.
Winn
Mar 19, 2013 10:55 AM
mrod79
Mar 23, 2011 04:48 PM
ELF
Jan 26, 2011 08:43 AM
lathedog
Aug 31, 2010 07:20 PM
Augie05
Mar 4, 2010 06:34 AM
