R56 DIY A-pillar rubber replacement?
Old Oct 27, 2018 | 05:01 PM
Nui's Avatar
Nui
It seems a shame not to mention expensive to replace good A-pillar covers just to get the weather stripping. Mine are fine but the weather stripping has atrophied badly.
Does anyone have a method to just replace the weather stripping and not the entire A-pillar cover?
Old Oct 29, 2018 | 08:43 AM
mkov608's Avatar
mkov608
The A-pillar cover and the door seal are separate parts, and the seal lip covers the A-pillar cover. All you have to do is pull the door seal off and replace it.
Old Oct 29, 2018 | 09:10 AM
Nui's Avatar
Nui
Its the lip on the A-pillar cover. Not the gasket below it.
Is there a way to just replace th lip seal?
Can't seem to upload the image for some reason. But its the A-pillar where the seal rests on the windshield
Old Oct 29, 2018 | 09:15 AM
mkov608's Avatar
mkov608
Post a picture, and the last 7 of you VIN.
Old Oct 29, 2018 | 09:45 AM
Nui's Avatar
Nui
Here's a pic from our former '07 - its the same. Last seven - T391499
Old Oct 29, 2018 | 10:07 AM
mkov608's Avatar
mkov608
Oh! That's the exterior A-pillar cover; I though you were talking about the interior cover. Here's the part number ... 51137272583
Here are the instructions for removal/replacement: https://www.newtis.info/tisv2/a/en/f...dow/1VnXzQ21K8
Old Oct 29, 2018 | 10:19 AM
Nui's Avatar
Nui
I'm very comfortable working on these things. The problem I initially mentioned is I hate to spend $120 for a pair of A-pillar covers just to get new rubber. There's nothing wrong with the cover itself. Just the rubber.
Thanks for the links!
Old Oct 29, 2018 | 01:26 PM
mkov608's Avatar
mkov608
Sorry, the first instruction link I posted was wrong; that is for replacing the actual metal A-pillar.
Here are the steps for pulling the exterior A-pillar cover: https://www.newtis.info/tisv2/a/en/f...dow/1VnXzQ21K8
ECS had the foam piece for $21 + shipping.
https://www.ecstuning.com/b-genuine-...t/51337146095/
Old Oct 29, 2018 | 01:36 PM
Nui's Avatar
Nui
Thanks again for the link. I've seen how to do it also on YouTube. Still my original question holds - I just want to replace the rubber seal. Seems costly and a waste to through away good A-pillar covers just because the seal is bad.
Old Nov 24, 2018 | 03:11 AM
S-2013's Avatar
S-2013
I'm in the same predicament and went ahead and ordered both A-pillar gaskets from the link above. Thanks mkov608 for the ECS link.
Old Nov 24, 2018 | 05:20 AM
Nui's Avatar
Nui
But the gasket won't fix what I asked. They sit below the A-Pillar.
Old Nov 24, 2018 | 06:40 AM
S-2013's Avatar
S-2013
So you are stating that there's an additional rubber piece besides the gasket underneath the A-pillar cover? I looked at another Mini with a good gasket and can't find what you're referring to. This is mine below:
Old Nov 24, 2018 | 08:49 AM
I like mini clubman's's Avatar
It's not very clear from the pictures from ecs, so the foam has a rubber stip that seal to the window?
Old Nov 24, 2018 | 08:54 AM
it appears the rubber seal is not connected in any way to that foam piece. As the original posted asked and stated it's connected to the a-pillar panel. His original post was very clear to me, can the rubber strip connected to the a-pillar piece be bought separately?
Old Nov 24, 2018 | 05:15 PM
Nui's Avatar
Nui
Correct!
Old Jan 5, 2021 | 07:21 AM
Josh Falk's Avatar
Josh Falk
Nui, did you ever figure out how to replace just the rubber weather stripping on the A Pillar trim? I've got the same issue.
Old Jan 5, 2021 | 07:30 AM
Nui's Avatar
Nui
A driver did a u-turn right in front of the car from the curb and destroyed the car. So no, sorry.
Old Jan 5, 2021 | 07:44 AM
Josh Falk's Avatar
Josh Falk
Ok that's good to know. I'm going to ask the parts folks at the dealer but my feeling is they'll want to replace the whole trim panel. Mine's just cracking and haven't lost any pieces yet, so I may try some silicone filler as a stopgap.
Old Jan 5, 2021 | 08:37 AM
That rubber is part of the a-pillar and not a separate part:
Set Of 2 R55 R56 R57
https://www.ecstuning.com/b-genuine-...51137272583kt/
perryinva
Jul 11, 2016 10:50 AM
-=gRaY rAvEn=-
Jan 20, 2013 09:25 AM
ckees831
Feb 27, 2009 11:29 AM
windman
Feb 13, 2009 10:22 AM
ImagoX
Classic Mini Talk
Jul 13, 2007 06:43 AM
