R56 '07 MCS Suddenly Dead/Possessed
Old Apr 9, 2018 | 11:17 AM
ioannes79's Avatar
ioannes79
So this came out of nowhere, but drove home yesterday with Cooper seemingly fine . Later I go to leave and my fob isn't working. I used the manual key to get in to find that my battery is apparently toast. I hook up my charger to see if it'll start, but the second I did my lights flash and lock -also locking the keys in the car. Comfort Access and hatch only result in a quiet series of clicks from the RR quarter panel . Disconnected the battery to let the system drain and to charge it over night .Check it again this morning with a topped off battery and still nothing but clicking from the RR quarter .
Does anyone have any idea what's going on?
Old Apr 9, 2018 | 12:14 PM
ioannes79's Avatar
ioannes79
Follow up: Got into it with a coat hanger... Damn that was too easy and thankfully the locks pop with that handle pull. Once I pulled the keys from the slot it turned over without hesitation.
But still, WHY? anti-theft maybe?
Old Apr 9, 2018 | 12:37 PM
DneprDave's Avatar
DneprDave
MINIs do many strange things with a low battery.
How old is your battery? If it is over five years old, it's time for a new one.
Old Apr 9, 2018 | 12:52 PM
MiniToBe's Avatar
MiniToBe
can you turn the radio on or lights, and does it crank? do you have an obd reader?
never mind...didnt see updates lol
Last edited by MiniToBe; Apr 9, 2018 at 12:53 PM. Reason: too late for the show ;)
Old Apr 9, 2018 | 03:03 PM
ioannes79's Avatar
ioannes79
The battery was fine before I parked it. I just charged it for good measure. The battery is three years old.
Old Apr 9, 2018 | 07:15 PM
Rastoff's Avatar
Rastoff
Check the charging voltage. When running, a volt meter across the battery should read about 14VDC. If it's reading 12VDC then your alternator is not charging the battery.
Old Apr 11, 2018 | 09:02 PM
E34M5's Avatar
E34M5
Check for water leaks, just remove your step sills and pull up your carpets a little, make sure there is no moisture it can really cause havok. I had some electrical gremlins turned out previous owner had windshield replaced and they didn't install the exterior A pillar trim clip seals, not a good situation out here in the rainy pnw.
Old Apr 12, 2018 | 11:41 AM
ioannes79's Avatar
ioannes79
Checked. Alternator is charging
jvw
Jun 13, 2019 09:23 AM
RazorV
May 8, 2014 10:25 AM
rodney_kranz
Dec 20, 2013 04:32 AM
RT4
Aug 3, 2013 09:30 AM
fishbert
Jan 6, 2012 01:14 PM
