R56 Car wont start, Shows Key symbol
Old Apr 14, 2017 | 11:16 AM
olson187's Avatar
olson187
Blew a tire and had the car towed home. Went to go start it to drive it today and car wont start. It shows a key symbol followed by an exclamation point...Any ideas? doesn't crank but everything else works...lights, radio, door locks.. battery is fine and juiced up...Please Help!!!
Old Apr 14, 2017 | 02:52 PM
seandallen's Avatar
seandallen
Well, you don't say what model and year Mini you're driving, but my first WA guess is that the battery is dead in your key. Usually an exclamation point in the display indicates that something has failed.
Old Apr 14, 2017 | 04:34 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Battery in key kaput.
Have a 2nd key ?
If comfort access and 2nd gen, battery is replaceable.
Old Apr 14, 2017 | 06:01 PM
olson187's Avatar
olson187
it is a 2007 and what is comfort access?
Old Apr 14, 2017 | 06:15 PM
AZdsrt's Avatar
AZdsrt
Hmm, does the battery in the key really need to be good to start the car? I thought it was something passive in the key like RFID.
Anyways, had something similar a long time ago, finally dawned on me I wasn't pressing the brake prior to hitting the start button, a Duh moment..
Old Apr 16, 2017 | 02:47 PM
seandallen's Avatar
seandallen
Comfort Access is when you can just touch the door handle and the car will unlock automatically as long as it senses the fob nearby.
Old Apr 17, 2017 | 05:49 AM
MiniToBe's Avatar
MiniToBe
the notification came up while the key is in the cradle? if not, did you try it while in?
Old Apr 4, 2025 | 10:38 AM
jo001uq's Avatar
jo001uq
Hello,
It happened to me long time ego. The car will start even if the battery is not working, the anti-theft chip does not draw power from the internal battery but is activated by a radio signal sent out by the car. So, you will be able to continue to use/start the car even with a bad battery in the fob.
The only thing is you will have to use the actual key to lock and UN-lock doors, local electronic shop near me replaced for $65.00 charge in one day.
Good luck.
Michael Ravellette
Mar 5, 2023 03:44 PM
Apexhunter
Jun 20, 2021 07:02 PM
Mini R56
Feb 6, 2014 09:15 PM
2003minicooper
May 11, 2013 01:18 PM
rwkeating
Electrical
Apr 16, 2010 04:19 PM
