Electrical How does the key battery really recharge?
So how does the battery in the key recharge? Looking at the key, it is a metal shaft with a plastic head (handle). To charge I would expect a positive and negative connection, but there looks like there is only one (the metal shaft). Ideas?
Edit: (I am referring to the 1st gen models, like the 2006)
I agree with JustinGTP...Magnetic Induction.
You don't have to actually put the key in the ignition either...just close.
Try opening your drivers door & place the key near the ignition switch. Your car will start beeping as if you had the key in the ignition...Your car knows when the key gets close enough to start the charge.
Did you even read my post? The batteries in the 05-06 are RECHARGEABLE and as I explained, it is done by inductive charging. Geeze.
I think the 05'+ have the newer style key.
This "magic" charging has been around for quite a while...I had a panasonic electric razor that sat on a cradle, with 0 metal to metal contacts...my wifes chepo electric toohbrush has inductive charging...and you can get a reciever, transmitter, and adaptor to make cell phones charge the same way....then you just toss you cell on a tray, no plugs, and it charges wirelessly.
As with anything with a battery, it can age, and fail internaly, resulting in the need for a new battery.
This is correct.
And if you notice the very first post, he is inquiring about a 2006.
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
UncDeo
Nov 4, 2019 04:08 AM
R50/53 What is up with my 2005 r53?
rustof
11
Sep 25, 2015 10:35 AM
daviday
Sep 25, 2015 01:31 AM
