R56 Bov question
Old May 12, 2016 | 02:21 AM
Nick Royer's Avatar
Nick Royer
Bov question
The diaphragm in my stock diverter valve went and I need a new diverter/BOV will this BOV (http://www.forgemotorsport.com/Blow_...uct--1026.html) work or will it throw a cel I have a manic stage 2 mini
Old May 12, 2016 | 07:04 AM
Systemlord's Avatar
Systemlord
Stay away from the DV that vents to atmosphere, it will trigger a unmetered air leak code causing you to go into limp mode. Buy the DV without the air vents, I installed one two years ago and it's the best mod under my hood! Between shifts when you're back on the throttle you'll feel it since this DV dumps less boost than the stock DV, the Forge DV is also faster since it runs off vacuum from one of the MAP sensors.
Old May 12, 2016 | 08:22 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 The Forge DV is really great quality. I've installed many of their products on lots of different makes. If you have an N14 R56, I believe the one you'll want is FM207V, but you can call Forge to confirm. We sell these valves also.
888.280.7799 | 6am - 5pm PST
Old May 13, 2016 | 06:28 AM
BigBoost's Avatar
BigBoost
I've never had a problem with my Forge atmosphere valve! i ran it on my stock cooper s and never had a problem now am runing it on my stage 2 and still no problem's after getting the upgrade spring. "blue"
spring guide line
Green - 5-10 PSI, Yellow - 15-23 PSI, Blue - 23-30 PSI, Red - 30+ PSI.
25%, 50%, 75%, and 100% respectively.
links to the springs
http://www.forgemotorsport.com/Uprat...duct--833.html
Old May 16, 2016 | 08:06 PM
renchjeep's Avatar
renchjeep
Would the spring values for the N18 be the same? I have the FMDVR60A. It has worked flawlessly, no Check Engine light or anything else. But, I do have a fluttering sound, after blowoff, especially after installing an AFE cold air intake. Other mods are in my signature. Ideas, anyone?
Old May 16, 2016 | 09:36 PM
BigBoost's Avatar
BigBoost
does it sound like turbo chirp "turbo spooling backwords " or does it sound' like the vavle is opening post blow off!
Old May 16, 2016 | 09:50 PM
renchjeep's Avatar
renchjeep
Not being totally familiar with turbo engines just yet, it sounds like blowoff happens, then there is a light "chuffing" sound, but only if I let off while in full boost. If I grab the next gear, just the blowoff. Not turbo surge, for sure. Just a louder blowoff, as I am dumping to atmosphere. I need to make a video. It sounds pretty cool, and I have heard large vehicles like trash trucks make the same sound. I have no issues with the noise, just want to make sure it's normal, kinda.
Old May 16, 2016 | 10:18 PM
BigBoost's Avatar
BigBoost
you will have to make a video' when Diesel trucks make that noise thats turbo surge! diesel generally don't have bovs ! do you lose any power when it happen's do you hear a boost leak
Old May 16, 2016 | 10:31 PM
renchjeep's Avatar
renchjeep
I do not lose any power. Our fleet recently consists of mostly CNG heavy duty vehicles. I have heard it on diesels, but not as much as with the CNG rigs. I thought turbo surge was a different deal. This is not under boost, but when letting off from full boost. Like when not changing gears, just letting off from full boost. Like when you are not going to the next gear, just letting off from full boost, then backing down.
Old May 16, 2016 | 10:53 PM
BigBoost's Avatar
BigBoost
so' i drive a 379 pete with a step-deck! some time's when shift eithering going up or down i get almost like a hick up ! are talking about that
Old May 17, 2016 | 08:51 PM
renchjeep's Avatar
renchjeep
I will work on getting a good vid and posting it here. Do I need to post to youtube, then link here?
Old May 17, 2016 | 10:32 PM
ayypeeemm's Avatar
ayypeeemm
@renchjeep does it sound like this?
If so that's normal.
Old May 18, 2016 | 08:30 PM
renchjeep's Avatar
renchjeep
That is almost exactly what it sounds like, ayypeeemm. Mine is a bit louder, but that's the general sound. Thanks!
Old May 20, 2016 | 05:13 AM
Nick Royer's Avatar
Nick Royer
Update: I installed the forge atmospheric BOV kit and have been driving for a week with no codes
Old May 20, 2016 | 07:03 AM
BigBoost's Avatar
BigBoost
good deal ! am not sure why people say they throw code's! ive never had s problem
Old May 20, 2016 | 10:37 PM
renchjeep's Avatar
renchjeep
Maybe the N14 had a problem with the Forge BOV, and not the N18? Mine has been fine with no CEL for a couple months now.
Old May 21, 2016 | 06:35 AM
BigBoost's Avatar
BigBoost
i think some people just have problem's in General when it comes to mini's!
Old May 21, 2016 | 08:52 AM
Nick Royer's Avatar
Nick Royer
My car is the n14 motor and mine is fine
quickcoop
Dec 4, 2020 09:05 AM
Mar 24, 2016 11:31 AM
MiniDad08
Mar 23, 2016 01:59 PM
AFN704
Mar 21, 2016 03:42 PM
johntotah94
Mar 18, 2016 12:34 AM
