R56 Engine and Cabin Filter - Before / After
Old Apr 25, 2016 | 12:33 PM
Flyinace2000's Avatar
Flyinace2000
I've owned this car since late 2013 and purchased with about 22k miles on the clock. Today i replaced the engine and cabin filters. Take a look at these before and after.
Old Apr 25, 2016 | 01:24 PM
miniuy's Avatar
miniuy
It seems that the filters did the job properly!
Old Apr 25, 2016 | 01:51 PM
Capt_bj's Avatar
Capt_bj
THAT'S NUTHIN'
Here's what I found first time I pulled my cabin filter when pre-paid maintenance had run out (and the dealer had been checking and replacing as needed . . . )
GEN1 cabin filter from my 2002 S, 2005
Old Apr 25, 2016 | 04:44 PM
Flyinace2000
Originally Posted by Capt_bj
THAT'S NUTHIN'
Holy smokes....where do you live? Do you smoke?
PS
Capt BJ, do you use the same handle over at MiniMania?
Old Apr 25, 2016 | 07:23 PM
pkunk's Avatar
pkunk
When I bought my '08 used the PO gave me receipts that showed the cabin air & engine air filters replaced 1k mi ago. Cabin air was filthy and cloged with leaves and the engine filter was literally black. I gained 5mpg on the next tank of mid grade.
Old Apr 26, 2016 | 05:06 AM
Flyinace2000
Wow. My airbox had some debris in there too, but did a quick hit with the shop vac.
I just re-checked my records and the cabin filter was replaced around 26k miles.
Old Apr 26, 2016 | 05:59 AM
miniuy's Avatar
miniuy
THAT'S NUTHIN'
Old Apr 26, 2016 | 06:09 AM
1004ron's Avatar
1004ron
My 2012 Cooper Hardtop has 26K miles and just did the engine filter and found the cabin filter still like new.
I pulled the cabin filter to check it, but then learnt that you can view it from the battery compartment.
Attached Thumbnails Engine and Cabin Filter - Before / After-2016-04-24-11.31.23.jpg   Engine and Cabin Filter - Before / After-2016-04-24-11.31.35.jpg
Old Apr 26, 2016 | 06:12 AM
Capt_bj's Avatar
Capt_bj
PS
don't smoke - no one ever smoked in the car .... and the area wasn't 'heavy' industrial but Norfolk being a port city there were a lot of trucks on the roads . . . I changed once a year from then on and never saw another like this . . .
I use the same name on most boards I frequent .... I'm not sure I've ever made a post over on MiniMania altho I buy from them, mostly for my 79.
Old Apr 26, 2016 | 12:51 PM
Mini Mania's Avatar
Air Filter
Thanks Capt.! Let us know if we can be of further help!
Old Apr 28, 2016 | 02:17 PM
eR1c's Avatar
eR1c
Brought my 2008 S in for service today,
I almost always do everything myself, yet I hadn't taken it in for at least 3 or 4 years and the service light was on ...so figured id just bring it in and have Mini check it out.
All is well,
BUT They wanted $697 to change oil, replace air filter, rotate tires, flush brake fluid and replace cabin filter. I was like $700!!!! are they insane!! (granted I do live in SF, CA ..everything is ridiculously expensive here ...but still).
So I told him to forget it i'll do it all myself for a fraction of the cost. But looking at what they spec'd out , the in cabin filter was $150 for the part and $50 for labor!!! I have changed my in cabin filter myself many times, ..it takes 4 minutes and cost about $35 for the part. They wanted $200 for that!!!!!
all maintenance will continue to be done myself!
Old Apr 29, 2016 | 08:58 AM
miniuy's Avatar
miniuy
$ 700 ???
Maybe there is a clutch replacement included : /
Old Apr 29, 2016 | 09:24 AM
ColoCoug's Avatar
ColoCoug
All is well,
And that may be your last trip to the dealer.
Their bill should have included a jar of Vaseline.
Old May 8, 2016 | 09:15 AM
grussell's Avatar
grussell
PS
The cabin filter only filters air coming from outside the Mini...
Old May 9, 2016 | 12:12 PM
miniuy's Avatar
miniuy
Not exactly.
Cabin filter filters air recirculating inside the cabin too (when you are using it in recirculation mode).
Old May 10, 2016 | 09:42 AM
Mine was pretty dirty :
R56 cabin filter : https://www.northamericanmotoring.co...bad-smell.html
Have you seen a cabin filter like this ? Gen 1
https://www.northamericanmotoring.co...ter-gross.html
or
Gen 1
https://www.northamericanmotoring.co...c-problem.html
mini562
May 30, 2016 06:01 PM
SCHerzig
Apr 21, 2016 03:12 PM
thelawson
Apr 13, 2016 11:04 AM
Pariah
Apr 12, 2016 10:51 AM
thelawson
Apr 11, 2016 12:20 PM
