JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW 2013 JCW Upgrade Questions
Old Apr 4, 2016 | 07:08 PM
SCHerzig's Avatar
SCHerzig
Hi Everyone !
I just picked up a 2013 factory 2013 JCW Hardtop. I read the previous (2014) thread about about upgrades, all very good information.
I would like to get everyone's input on the mods I'm planning on doing, since it's been a couple of years, so any input given will sincerely be appreciated !
Motor: JB+ and a BMC (?) Air filter. What type of filter am I looking for ? Cone, Panel etc. ? If I can't find a BMC any other suggestions ?
Tires: My last mini had Michelin Pilots and I loved them, still good or what's better ?
Definite Maybe's: 19 mm sway bar - Intake - or ?????
As in the previous post from 2014, my JCW is a daily driver as well.
Thanks in advance for your input - Steve
Old Apr 5, 2016 | 11:01 AM
TheBigNewt's Avatar
TheBigNewt
If your car doesn't have the Sport Suspension option get the rear sway bar for sure. Most people like the JB+ or the similarly designed NM unit for performance. I don't have it myself, I'm pretty happy with the JCW's motor/turbo as it is. I came from a 2007 MCS and it's way faster than that. How bout a few pix?
Old Apr 5, 2016 | 02:06 PM
Mini Mania's Avatar
Congrats on the new JCW. We would love to see some pictures. We are partial to K&N, so here is a link to the air filter and other accessories.
http://new.minimania.com/mini-cooper-jcw
Also, here is an article about our 2012 JCW!
http://new.minimania.com/Close_Ratio...re_A__Gearbox_
Happy Mini Motoring!
Old Apr 5, 2016 | 08:16 PM
dube53's Avatar
dube53
I know very well the K&N air filters and they are excellent products. I have one for years with proper cleaning maintenance performed on a classic 240Z. This is a great product.
But, I read a few treads a long ago that they can damage a MINI sensor because of the oily content of their composite material.
It is the only reason I never installed one.
Old Apr 6, 2016 | 10:20 PM
Mini Mania's Avatar
Hi, Steve! You are correct. The 2013 JCW and all of the Gen2 Minis uses a Hot-Film Air Mass Meter just after the airbox. The film, or membrane in the HFAM, can be coated with excess oil from the filter and cause erratic readings affecting engine performance.
However, there are no issues if the oil on the K&N filter is used as per their instructions and applied sparingly. If you have any concerns regarding excess oil, then you can blow the filter with a 'light' compressed air source to make sure none of the oil will blow off. The filter only needs to be 'dampened' and not soaked. Hope this helps and happy Mini motoring!
Old Apr 7, 2016 | 01:19 AM
cerenkov's Avatar
cerenkov
Upgrades that I would do with a N18 JCW are:
1. Intercooler (Helix Version 2, Forge, Wagner)
2. High flow catalytic convertor Downpipe (not of fan of totally catless versions)
3. 22mm solid rear sway bar (NM or others) or the 25mm hollow from Hotchkis
4. Engine torque arm bushing insert (NM has a version for sale so does Powerflex)
5. Manic Tune - flashed via the OBD2 port at a Manic dealer
6. Methanol injection - Howerton/Aquamist, Snow, Devils Own
7. Not sure if you have the JCW sport suspension or not, but I like the car lowered a tad from stock, either coilovers or lowering springs.
Intakes are not power adders they are more for the sound. The stock intake on the MINI is actually very good. I have a DOS intake (no longer available and does use a KN cone filter) and I love the sound but I can't say that I noticed any additional power.
Get the Manic tune over the JB+. I've had both. It's more expensive but well worth it.
Old Apr 8, 2016 | 03:10 PM
Ovrclck's Avatar
Ovrclck
Peace of mind, I prefer none oiled dry filter. I'm using one by Afe. Also adds a bit of noise which I like.
Old Apr 8, 2016 | 07:15 PM
dube53's Avatar
dube53
I disagree with your comment. This is a wet filter and you never blow it out because it will be damaged forever. They are expensive and need regular maintenance with the recommended kit.
I used K&N for more than 15 years on classic cars. The air box gets dirty with oil residues.
It should be the same on a Mini and the reason it is recommended to avoid if sensors are at risk to fail.
Old Apr 9, 2016 | 10:50 AM
malibujoey's Avatar
malibujoey
Originally Posted by SCHerzig
Hi Everyone !
Old Apr 9, 2016 | 10:52 AM
malibujoey's Avatar
malibujoey
Old Apr 21, 2016 | 08:25 AM
Ovrclck's Avatar
Ovrclck
Originally Posted by malibujoey
I bought the K&N filter and after reading all the posts, never used it. Just use a stock paper replacement. FRAM, etc.
Why not a dry filter?
http://www.waymotorworks.com/dry-pan...-cooper-s.html
It's what I use. Cleaning is super easy, just a couple taps and vacuum, done.
Old Apr 21, 2016 | 03:12 PM
Mini Mania's Avatar
You don't get the performance benefits of the K&N but dry filters certainly are effective and inexpensive. Starting @ $19.59 less the 12% discount for this month.
http://new.minimania.com/part/G2NME1...57-58-59-60-61
http://new.minimania.com/part/G2NME1021/
Plus, here is a link to the application guide:
http://new.minimania.com/Mini_Cooper...lacement_guide
KYDan
Mar 13, 2018 06:18 PM
zipitydooda
Mar 29, 2016 12:42 PM
Feb 22, 2016 02:54 PM
kfmuller
Feb 21, 2016 07:49 PM
MidwayMountaineer
Feb 16, 2016 01:19 PM
