R56 Queston about custom intake
Old Apr 10, 2016 | 12:04 AM
agordon1337's Avatar
agordon1337
I I know I can just buy a cai for 200-350 but I have seen people do custom ones where they get piping from autozone/pep boys and connect a cone filter to the end. Can someone shed some light on this as I am a little confused. What do you guys think of this option versus just buying a complete system like a K&N typhoon?
Old Apr 10, 2016 | 10:45 PM
agordon1337
bump
Old Apr 11, 2016 | 08:44 AM
miniuy's Avatar
miniuy
What MINI model and year?
Old Apr 11, 2016 | 11:31 AM
agordon1337
Originally Posted by miniuy
what mini model and year?
2011 mcs
Old Apr 11, 2016 | 11:57 AM
miniuy's Avatar
miniuy
I'm not a friend of the air intake upgrades that takes air from the engine bay (hot air):
For the S model, I only know that type of upgrade (air taken directly from the engine).
In the case of the Base model (my model), you can upgrade to a K&N model (in example) which allows you (through a hose) takes the air from the front grille (fresh and cold air):
All my friends running a S/JCW say that it is just a myth and that there is no difference between where you are taking the air.
It's just my opinion based on my limited knowledge of what kind of air the engine needs/expect for optimal function.
I hope others users can give you the best option for you !
Old Apr 11, 2016 | 09:39 PM
renchjeep's Avatar
renchjeep
Turbo engines are gonna heat the charge. No way around that besides a bigger more efficient IC and maybe some meth injection. A zip-tube under your hood may make a "better" sound, but will not increase power. I am running the stock airbox and intake, with a Pipercross foam air filter. I like the Pipercross over other drop-ins because it takes less air volume from the airbox, versus say a K&N, which projects further into the airbox. The Pipercross made a bigger "seat-of-the-pants" gain than the K&N did. Plus, it won't oil up your intake and MAF sensor. My opinion only.
Old Apr 12, 2016 | 11:46 AM
xSpartanCx's Avatar
xSpartanCx
I'm personally going to eventually get one of these: http://www.waymotorworks.com/ddmwork...ke-system.html
Old Apr 12, 2016 | 01:25 PM
miniuy's Avatar
miniuy
+1 (great air intake mod for the S model!)
Old Apr 12, 2016 | 09:26 PM
Pariah's Avatar
Pariah
Seems like a hydrolock waiting to happen, but probably perfect for track use.
Old Apr 12, 2016 | 10:31 PM
MarioKart's Avatar
MarioKart
Vendor
The intake is at the top of the motor so, it would have to be some very very deep water to hydrolock. At that depth, the car would just float away
mQubed Motorsport, Manic Tuning Dealer
Old Apr 12, 2016 | 10:39 PM
Pariah's Avatar
Pariah
I was thinking more along the lines of automatic car washes. I'd sure hope someone would avoid 3' deep water
Old Apr 12, 2016 | 11:34 PM
Mini Mania's Avatar
R56 Cold Air Intake
Hi agordon1337!
There are a number of great solutions available for what you are trying to accomplish. Here is a great deal on the K&N.
http://new.minimania.com/part/G2NME2...8-2011-R55-r61
There are also some helpful application guides on our website:
http://new.minimania.com/Search_Results/intake/default
Please let us know how we can help you and your Mini!
Old Apr 13, 2016 | 02:13 AM
BigBoost's Avatar
BigBoost
Yes go with the ddm works they are about the best you can get I think! Worth ever dollar !
Old Apr 18, 2016 | 09:54 PM
E36-E46-R56lifewhuuuh?'s Avatar
First post whuuuuuuuh?
Your wasting your money on a bolt on cai unless you have a list of mods your getting ready to do. You can clamp a filter on the end of your MAF if you want to get real hood with it. To each his own.
https://www.northamericanmotoring.co...e-made-29.html
I kept my stock airbox until the inlet wouldn't fit on a bigger turbo. After I had to do something I decided to go custom. Really the only reason you need to be messing with your intake is if your running into flow or fitment issues with a bigger turbo.
You can definitely go custom it just depends on how weird you want to get with it. I decided to eliminate all that piping and went MAFless. You'll need to speak to a tuner if you want to go this route. The tuner I use seemed think MAFless with shorter piping would reach peak efficiency much gooder n stuff. I'm no expert but I thought hmmm shorter piping is less restricting.
I moved the Rez to the firewall, U need a universal 2.5 foam filter, turbo inlet tube, 2.5 aluminum piping cut to desired length and waapow.
This would be a similar setup as mine moving the coolant Rez except I ran my pcv plumbing into the inlet that came with the turbo...
http://www.minitorque.com/forum/f847...-review-30937/
I'll post some pics if this is something you actually need help with
Old Apr 28, 2016 | 06:28 PM
agordon1337
So wait say I get a cone intake a attach it to the insert what are you supposed to do with the exposed stock filter ?
Old Apr 28, 2016 | 09:20 PM
agordon1337
Any one know or have any ideas ??
Old Apr 28, 2016 | 10:25 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
What are you trying to accomplish?
As has been said many times before - an intake isn't going to get you any more power, so what is your motivation? Noise? Underhood bling? Something different? Preparing for a tune? Or just because you want to? All valid reasons BTW.
The stock filter box comes out easily, see realoem.com or the install guide for any of the aftermarket intakes.
Old Apr 29, 2016 | 10:20 AM
miniuy's Avatar
miniuy
... an intake isn't going to get you any more power ...
Not directly, but yes
NorthWestEuro
May 7, 2019 05:35 AM
sirr6
Oct 29, 2017 05:36 PM
RHcoopers
Apr 9, 2016 01:32 PM
BXR
Apr 9, 2016 06:20 AM
Kevin@Integral Audio
Apr 6, 2016 11:45 AM
