R56 2009 Mini Cooper s battery replacement
Old Mar 14, 2016 | 03:02 PM
lasher10's Avatar
lasher10
Looks like I need to change the battery in my S. Do I seriously need to get a factory battery and have it programmed by the dealer?
Old Mar 14, 2016 | 03:47 PM
enoe01's Avatar
enoe01
Can you take a picture of the battery terminals. Then we can answer that question better. If t has the intelligent battery device on it you can still replace with an aftermarket u may need to look deeper on here to explain the reprogramming.
Old Mar 14, 2016 | 04:18 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
If this is your car, http://www.realoem.com/bmw/enUS/show...diagId=12_1398. Yes it has IBS
Old Mar 14, 2016 | 04:45 PM
enoe01's Avatar
enoe01
Mini, isn't there a way to get ibs reset without going to the stealership? I thought I read somewhere on here about that.
Erik
Old Mar 14, 2016 | 04:48 PM
Minnie.the.Moocher
http://www.mycarly.com/product/bmw-app/
Old Mar 14, 2016 | 05:32 PM
Fly'n Brick's Avatar
Fly'n Brick
Again with the battery replacement.
1. Take it a big box auto parts store.
2. Tell 'em you need a new battery, here's the old one, would you please look it up to get the right one.
3. Tell 'em they need to hook it up to a stand by power source so it's little brain doesn't die.
4. Drive away - after paying the tab.
Old Mar 14, 2016 | 08:22 PM
cguzz's Avatar
cguzz
That was me with my 2009S pre LCI. All he did was put doohicky in my cigarette lighter...swapped and gone. $125 NAPA
Old Mar 14, 2016 | 08:25 PM
lasher10's Avatar
lasher10
Here's my battery
Old Mar 14, 2016 | 09:25 PM
Fly'n Brick
Originally Posted by lasher10
Here's my battery
Show it to the guy down at NAPA or Auto Zone or another of that ilk. You'll be back on the road in short order with much more cash in your pocket than from the dealer's shop.
Old Mar 15, 2016 | 05:19 AM
aviaator's Avatar
aviaator
That battery does not need programming.
Old Mar 15, 2016 | 07:24 AM
Kimolaoha's Avatar
Kimolaoha
Here's my battery
No IBS module on the negative cable, so no programming needed.
BTW, although it's not entirely clear from your picture, the numbers stamped on your negative terminal seem to say '08??!! - which would make sense for a 2009 model year car with its ORIGINAL BATTERY.
If so, you sure seem to have gotten your money's worth out of that one! Dispose of it with reverence.
And consider splurging for an Autocraft H6 (Group 48) AGM (760CCA / 950A) available at Advance Auto - taking advantage of all available discounts, and ASSUMING IT FITS YOUR 2009 MCS (it DID fit my 2011 MCS).
http://shop.advanceautoparts.com/p/a...agm/10210829-P
Old Mar 15, 2016 | 08:16 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Answered your question in the other thread. Your unit does not have the IBS module. Lots of info and pictures of batteries that do and do not have the unit HERE. Also, that thread gives info about our article that shows you how to register it yourself if you have the right tools.
888.280.7799 | 6am - 5pm PST
Old May 27, 2016 | 07:28 AM
Patrick Chaves's Avatar
Patrick Chaves
I have a 2010 Mini Cooper S and it has the odd group 140 battery, It appears that the group 47 battery will fit in its place, will the group 47 work as long as it will fit?
Old May 27, 2016 | 11:14 AM
nkfry's Avatar
nkfry
You will need to have the battery coded, but yes it will work.
We install the group 47s on every car that needs a battery.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jun 27, 2016 | 06:34 PM
Tallandmini's Avatar
Tallandmini
I replaced my battery with a larger AGM from advance auto, but even though I put 9 v battery thing in the cigarette lighter and turned ignition switch on without starting I lost clock time ( which I reset ) and now my windows don't auto up with a single long up on the switch. My drivers side seems to have relearned after a day, hoping the passenger side will soon also. Wonder what else I may have lost.
Edit: I read a thread. Just turn engine on and run window down all he way hold switch down for five seconds then run window all the way up and then hold switch up for five seconds. Now it has relearned auto up.
Old Jan 3, 2018 | 07:46 AM
Dreamcometrue's Avatar
Dreamcometrue
I recently had my battery replaced at Batteries Plus. Initially, they told me they couldn't replace the battery because their reference computer was telling them that my MINI had an IBS (intelligent battery sensor) that when replacing the battery, needed to be registered by the dealer (MINI) and if it wasn't the car would not go over 25mph. I immediately saw dollar signs!!! So, I returned home and looked here for any threads addressing the situation. I found this one and was able to determine that my car DOESN'T have the IBS on the negative battery cable. Information in this thread is correct and was a huge help in saving me $$$. I returned to Batteries Plus, showed them what I had found, along with pictures comparing IBS and non-IBS negative cables. They confirmed it on my MINI and then installed a new battery. I have had zero issues with the new battery.
DustinFennell
Feb 21, 2022 05:43 PM
l1qu1d993
Apr 29, 2016 05:46 PM
matt12mcs
Mar 18, 2016 07:11 AM
RocketUSA
14
Mar 16, 2016 10:38 AM
eliseo1981
Mar 13, 2016 10:30 AM
