R56 Two weeks of ownership, first issue arises!
Yeah, I bought pre-owned... which is something I have not done in more than 30 years. My 2011 MCS has been sitting in the garage all day, and there is a plate-sized puddle of what appears to be coolant (blue-green liquid) under the front end, just to the right of center (from the driver's seat).
Already made an appointment for Monday to have it diagnosed, and praying it is just something loose, not something broken.
The first two weeks of ownership had been a joy, until now. I'm not pleased...
Thanks for the replies guys. It appears to be more on the passenger side... Right side if I'm in the driver's seat. I'm going to put it up on jack-stands in the morning and see if I can determine for certain what the source is.
If I'm looking at the front end of the car, it is just to the left of center. There was a small puddle a few days ago that i first thought was AC condensation, but the car has been sitting all day today, and the puddle is now a good six to eight inches in diameter.
The water pump is on the far passenger side of the engine, near the back corner of the oil pan. If you can pull off the front wheel, it will be easier to see where the leak is coming from.
There is a pipe that runs behind the engine that connects the water pump to the thermostat housing (which is located on the driver side of the engine, just above the transmission). If the thermostat leaks, the coolant generally puddles on top of the transmission and rarely makes it down to the floor until the leak gets severe.
The only other place for a leak is in front of the engine, with a hose, the radiator, or the auxiliary water pump (if you have an S). I have read that some people have had their lower radiator hose come loose (it is held in place with a plastic clip) and develop a leak. This should be able to be easily spotted when you are under the car.
A previous comment indicated a plastic housing. Water pumps were originally built with a plastic housing, and the replacement parts are now with a metal housing. The plastic water pump housing can crack, just like the plastic thermostat housing.
Have fun,
Mike
Have fun,
Mike
Have fun,
Mike
Have fun,
Mike
I see the four jack points on the car. How do I use a floor jack to raise it up AND put it on a stand. On my Miata there was a cross-beam under the front end I could use to raise the entire front and put stands on both sides. Is there a safe place on an R56?
With the MINI, you can lift the entire side of the car by using the forward jack point. While the side is up, put a jack stand under the front subframe. Then jack up the other side at the front jack point and use another jack stand.
Honestly, I would just jack up the passenger side.
One thing that I didn't mention was that there is a oil cooler on the front of the engine block, near the oil filter. This is directly over the exhaust pipe, but I would not expect this to be the source of the leak. If you see coolant coming directly down the front of the block, this could be the source.
It is easy to over estimate the size of a leak. Ever knocked over a quart of oil? It flows out huge!
Have fun,
Mike
Have fun,
Mike
I'm stumped...
I've attached a picture of where the drops of fluid are leaving the engine bay... but I have no idea of the source. The fluid is dripping off of the transmission casing from that round casting point, right down onto the exhaust, and then onto the ground. I cannot seem to find a source at all, but it has to be higher up on the side of the block. Could it be residual fluid, left over from an earlier repair? That sounds silly, but the "puddle" this morning after i wiped it up last night was only about the size of a quarter. I have not driven the car today, except to back it out of the garage, and put it up on the ramps.
I completely dried everything I could see, and now 15 minutes later I see no trace of fluid. I'm going for a drive to warm the car up well, and then I'll pull back up on the ramps and see if the leaking commences.
Anyone have a clue?
Well this is weird. After my thorough drying, and my 30 minute drive, no additional leaks appear. Not a drop. I'm still taking it in tomorrow to have the service techs give it a once-over. SOMETHING was leaking... it is a matter of time before it leaks again.
I believe that leak is coming from the oil filter housing gasket on the front of the engine. Coolant drips straight down and leaves whitish deposits on the driver side of the exhaust downpipe. I had the same leak in my MINI.
I'm at the dealership service bay now. We'll see what they diagnose.
Your description sounds like it could be the issue, based on what I'm seeing. One hour down in service bay... we'll see.
Update. I'm in a loaner overnight, until my car is ready tomorrow afternoon. Diagnosed with two issues:
1) Oil filter seal/gasket
2) Water pump leak
Tech said both were "minor" but noticeable, and they are taking care of both issues, just couldn't get it done today.
On the bright side, I've got a Cooper Convertible with only 4k miles on it for the next 18 hours or so. On the down side... it's an automatic.
2) Water pump leak
Hopefully someone else is paying for this, not quick to change filter housing gaskets. Glad you got it figured out.
Just learn how to read the dipstick (stop laughing, it is an issue) and keep changing the oil at 5k miles, keep fixing leaks or odd sounds, and the MINI will be happy for a long time.
Mike
Mike
Mike
Mike
As for the repairs... their working with me on it. The dealer didn't like the fact it left the lot needing repairs, so we'll see where we land. After all, it's only money. Repairs just leave less for mods.
Hats off to Orlando MINI!
They also washed and detailed the car for me. I can't ask for more!
Oh yeah I can... I left my leather jacket in the loaner car, so I have to go back tomorrow and retrieve it.
Yeah its a good full days work to do both of those. Around 10/11 book hrs if I recall. Independent shop wanted 971 to do both so I can only imagine what the stealership would charge for this. Glad you got it all squared away though and it didnt cost you a thing.
MINI of Escondido, CA has treated me VERY well. No money out-of-pocket. Just got over the factory warranty, so we will see how the Hendrick extended warranty works out next time I have an issue. I left a Streamlight LED flashlight in my loaner car from them once, and they shipped it to me....2 days! They really went above and beyond for me, so far. Free loaner cars every time. I even got to talk to the tech who works on my car. The first time I went there, the tech asked if I had any mods, or tunes. I said no, because at that point I didn't. He was surprised, and said my MINI was the quickest stock 2011 MCS he had ever driven! I figure that as a good omen...she must have been a Wednesday car on the line. Monday=hung over. Friday=can't wait to get home. LOL! Real life, folks!
alistaircookie
Oct 8, 2015 10:52 AM
BennyF
17
Aug 13, 2015 06:29 AM
