R56 Washer pump not pumping fluid
Old Jan 6, 2015 | 11:58 AM
imncrxtc's Avatar
imncrxtc
Anybody else have this issue? I can here the motor working when i activate it, but no fluid coming out. And yes, there is fluid in the tank.
thanks guys
Old Jan 6, 2015 | 01:19 PM
Slave to Felines's Avatar
Slave to Felines
How cold is it where you are? Could be that the fluid is frozen in the lines. Does it work after a nice long drive? Can you feel the lines to tell if the fluid is frozen?
Another possibility, especially with cheap fluid that sits for a long time, is that the nozzles are gummed up. I've had success in other cars at cleaning them out with a sewing needle.
Old Jan 7, 2015 | 08:24 AM
imncrxtc's Avatar
imncrxtc
Il give it a shot.
Old Jan 13, 2015 | 07:22 AM
imncrxtc's Avatar
imncrxtc
yup....they were frozen. I guiess -16 will do that.
Old Jan 14, 2015 | 08:45 AM
Slave to Felines
BTW, I dig the screen name. Are/were you on the Community BBS?
Old Jan 18, 2015 | 06:09 AM
afarias's Avatar
afarias
Just had dealer replace front washer pump - apparently frozen, so they replaced under warranty. Ticked me off that only after I showed up for service did they tell me that maintenance plan would not cover cost if lines or nozzles were frozen, or had a rock in the line.
Old Jan 18, 2015 | 07:24 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Not a maintenance issue really, operator error. Probably can't code it to make it apply which prohibits them from being paid for the work.
Old Jan 18, 2015 | 08:01 AM
ZippyNH's Avatar
ZippyNH
Lol...
I would get fired if I worked in a dealer...warrenty does not mean ZERO COST OWNERSHIP...
A warrenty is to cover the owner from an FACTORY defect in design or quality, not from a owners improper servicing with the wrong fluids!! as Homer Simpson said "dohhhhh!!!!".
To the op...many of us have been there, done that...that a why many of us use the more $$$ fluid...works better, and if I did refill with the cheap stuff, I use it up then refill before a cold spell....
The more $$$ purple/red/orange/yellow -30 or -40° f stuff also works better....
One tip...
Noticed wallyworld is selling watered down low freeze point yellow Preston's washer fluid (now only -25°f) stuff to lower the price...so look before you buy...
Old Jan 18, 2015 | 09:48 AM
nicsmini's Avatar
nicsmini
I use winter washer fluid all year....don't bother with the summer stuff, you'll forget it's in there and it will freeze, especially in canada
patsum
26
May 29, 2021 06:29 PM
dinomaniac
Sep 18, 2018 04:19 AM
Hobine
Oct 7, 2015 04:52 PM
cdemarco4
Sep 10, 2015 10:14 AM
