R56 Using Torque to locate issues
Old Dec 21, 2014 | 07:37 AM
genik's Avatar
genik
How can i use Torque (smartphone app) to see if i have an issue with the HighPressureFuelPump and also see the errors that come up for my mini?
Old Dec 22, 2014 | 08:58 AM
u238's Avatar
u238
What symptoms does your car have?
Monitor "fuel rail" with Torque. Idle pressure should be about 700PSI. The pressure should peak at about 2200PSI under full load. Pressure will drop to around 250 occasionally when you let off the throttle. Unfortunately, everything might look great with a dying HPFP because the pump fails in strange ways. Mine acted up a couple of times, then worked great for several hundred more miles before dying completely.
If your car is in limp mode or has a check engine light, scan for codes with Torque. A bad HPFP will be indicated by a few different codes. You will probably see misfire codes on all cylinders, a random misfire code, and one or more fuel pressure codes. In limp mode, fuel pressure will drop to about 60PSI, but that alone does not mean the pump is bad.
Old Dec 23, 2014 | 07:42 AM
nkfry's Avatar
nkfry
Torque will only give you generic codes, no manufacturer specific codes, and I'm not entirely sure you can monitor fuel rail pressure on it. You may have to find a shop that has access to a quality scan tool such as; Auto Enginuity, Autologic, etc. to read the manufacturer codes and fuel pressure.
But the above stated symptoms are what you will be looking for, misfires, erratic idle, hard/no start conditions, lean conditions under certain engine loads, manufacturer codes pertaining to the HPFP, half engine power accompanied by the CEL and limp mode.
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 23, 2014 | 09:52 AM
u238's Avatar
u238
Nick
Detroit Tuned
Torque is perfectly able to monitor the fuel rail. It shouldn't matter that Torque can't read manufacturer specific codes because a failing HPFP will trigger generic codes.
Old Dec 26, 2014 | 04:45 AM
genik's Avatar
genik
Ive set Torque up on my Android smartphone. I've plugged in the OBD2adapter, enabled GPS and BLUETooth, but i don't get a positive message regarding the adapter or the ECU connection! Could there be some other setting i've neglected?
Old Dec 26, 2014 | 08:41 AM
u238's Avatar
u238
Turn on bluetooth, set it to discoverable, connect to the OBD adapter. The pin will be 1234 or 1111 probably.
Old Dec 26, 2014 | 10:11 AM
genik's Avatar
genik
The pin to what?
Old Dec 26, 2014 | 11:52 AM
ZippyNH's Avatar
ZippyNH
Originally Posted by genik
The pin to what?
Bluetooth USUALLY has a built-in security PIN code when pairing the first time....so random folks cannot pair stuff accidentally to your phone...
The Bluetooth device usually says on the setup the pin code...then you enter it when pairing into your phone,if present....just like doing a headset..
Old Jan 1, 2015 | 12:14 PM
genik's Avatar
genik
Ok i managed to fix it... so where do i Monitor "fuel rail" with Torque? And also, if there is a HPFP issue will it be seen even when the problem is not present? Before a few days, i had the symptom when starting the car but no CEL came up, nor did Torque find any fault codes to log!
Old Jan 1, 2015 | 05:03 PM
mininewbnorthwest's Avatar
mininewbnorthwest
which obd plug are you guys using?
Amazon.com: Vgate Bluetooth Scan Tool OBD2 OBDII Scanner for TORQUE APP ANDROID: Automotive Amazon.com: Vgate Bluetooth Scan Tool OBD2 OBDII Scanner for TORQUE APP ANDROID: Automotive
i went cheap, and im not really happy about it
Old Jan 1, 2015 | 05:14 PM
genik's Avatar
genik
this is the one im using
Old Jan 1, 2015 | 10:39 PM
Gearheadaddy's Avatar
Gearheadaddy
Originally Posted by mininewbnorthwest
I'm using Torque Pro and a $15 Amazon.com bt obd2 adapter with an old Evo3d Sprint phone ...everything works including Track plug-in
Old Jan 1, 2015 | 10:40 PM
Gearheadaddy
Me too...
Old Jan 1, 2015 | 11:25 PM
genik's Avatar
genik
Nice Gearheadaddy, but where do i Monitor "fuel rail" with Torque?
Old Jan 2, 2015 | 02:17 AM
Gearheadaddy
I can't read fuel pressure on mine, l think fuel rail reading is unavailable (N14 as far as I know...if I do find I can I'll let you know)
Old Jan 4, 2015 | 12:56 PM
u238's Avatar
u238
Add a new gauge and select fuel rail from the list of sensors. Torque will probably not show any abnormalities until the HPFP actually fails. The car should throw a CEL when there are HPFP problems. Read the code and act accordingly.
Old Jan 10, 2015 | 12:12 PM
Seaswood's Avatar
Seaswood
Phone cradle
What is a good phone cradle?Using iPhone & other app.
Old Jan 13, 2015 | 01:35 PM
Gearheadaddy
Fuel rail...
Attached Thumbnails Using Torque to locate issues-forumrunner_20150113_133425.jpg
Markbett
Jul 3, 2016 04:28 PM
Bruce/Fl
Aug 28, 2015 11:59 AM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
joelcseymour
Aug 7, 2015 12:43 PM
