R56 wheel spacers and autocross
Old Jul 31, 2014 | 03:29 PM
SPDinNY's Avatar
SPDinNY
We are converting to studs and I was thinking this is the time to add wheel spacers. These are the specs on her 2012 Cooper S wheels.
Offset: 45mm
Backspacing: 5.47" Bolt Pattern: 4-100
Weight: 12.8lbs.
16X6.5
we are running 205/50/16 Direzza Z2's. What is the most spacer we can use without going out of stock class?
Old Jul 31, 2014 | 03:44 PM
hsautocrosser's Avatar
hsautocrosser
Offset change is limited to +/- 6.35mm.
For more information:
13.4 Wheels on Page 72
http://scca.cdn.racersites.com/prod/...nd%20links.pdf
Old Jul 31, 2014 | 03:57 PM
SPDinNY's Avatar
SPDinNY
so 5mm spacers is a go!
Old Jul 31, 2014 | 11:24 PM
Btwyx's Avatar
Btwyx
The allowance is +/-7mm for next year.
I'm pretty sure the stock wheel offset is 48mm, so you've already got 3mm extra offset. You could only use 3mm this year, or 4mm next year.
You'd probably be better off going with 16x7" wheels rather than fiddling with spacers. You're allowed +/-1" diameter from this year, so I went -1" from 17x7.
Old Aug 1, 2014 | 11:02 AM
SPDinNY's Avatar
SPDinNY
the stock offset for a 16X6.5 is 40mm so I think I am maxed out already :(
Old Aug 1, 2014 | 12:30 PM
cristo's Avatar
cristo
Alliance Member
I'm pretty sure the stock offset on 16x6.5 wheels is +48mm.
Old Aug 1, 2014 | 04:02 PM
hsautocrosser
A spacer reduces the offset number. The site linked below shows OEM ET's of 42 to 48. I don't know of a source for what wheels were factory fitted in what years.
http://minicooper.wikia.com/wiki/OEM_Wheels_and_Tires
Old Aug 1, 2014 | 05:00 PM
SPDinNY's Avatar
SPDinNY
so if OEM 16X6.5's are 48mm and my new rims are 16X6.5 45mm what size spacer can I use this year legally if +/- 6.35mm is the allowance from stock? I want to get these wheels out to the corners as much as possible. Thanks for all your help guys
Old Aug 1, 2014 | 05:07 PM
SPDinNY's Avatar
SPDinNY
I am thinking 3mm is the most I could go legally this year
Old Aug 1, 2014 | 06:15 PM
Btwyx's Avatar
Btwyx
Does this answer your question?
Old Aug 3, 2014 | 06:20 AM
SPDinNY's Avatar
SPDinNY
do you think a 3mm spacer on each side is going to make much of a difference?
Old Aug 3, 2014 | 11:00 PM
Btwyx's Avatar
Btwyx
I don't think it'll make much of a difference. I do think it'll make a small difference, I was considering doing it myself until I got wheels with a small offset (43mm).
eatsleepautox
Oct 30, 2015 06:46 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:50 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
ti22fjc
Aug 9, 2015 05:49 PM
