R56 Charging Press Code of death p2096
Old Aug 8, 2013 | 05:45 PM
flakoR56's Avatar
flakoR56
hello guys
i dont know if any of you guys have experience the Charging press code of death that i cant seem to find the solution to this. i have pressured tested the car i have uninstalled my AP and installed it disconnected it the battery with the ap uninstalled and installed it again and it always comes up.
any help?
here is the Code
i have ALTA FMIC, ALTA Intake Filter and AP with Stage 1 tune
please helpp me
Old Aug 8, 2013 | 05:53 PM
danjreed's Avatar
danjreed
Check for a leak after the front O2.
Old Aug 8, 2013 | 05:59 PM
flakoR56's Avatar
flakoR56
the 02 sensor was replaced 1 month ago and still :(
Old Aug 8, 2013 | 06:10 PM
danjreed's Avatar
danjreed
Ok, but did you check for leaks?
Old Aug 8, 2013 | 06:18 PM
Braminator's Avatar
Braminator
You might still have a bad O2 sensor even though you replaced it. I would check to make sure it is good and tight. Also it could be your cat is going bad. How many miles on your MINI? Both of these could still be under warranty if you are less the 80k.
flakoR56's Avatar
flakoR56
i took it to the mechanic i was there personally when they pressured test it and nothing. the i told them i have an upgrade Front mount they checked that and nothing. idk what else to do.
i have read online that people hae taken it to MINI dealership and they have updated the ECU and that it self makes the code go away would that work?
Old Aug 8, 2013 | 08:02 PM
flakoR56's Avatar
flakoR56
well i just hit 99k yesterday and i have a 2 year extended warranty
Old Aug 8, 2013 | 08:14 PM
Braminator's Avatar
Braminator
Check your warranty to see if they are covered before you spend any money trying to fix it.
Old Aug 8, 2013 | 08:52 PM
flakoR56's Avatar
flakoR56
Yes that's what am doing I mean they covered my 02 sensor I'll take it back to the mechanic if anything I'll go to mini so they can update the ECU and see if that works
Old Aug 8, 2013 | 08:55 PM
Braminator's Avatar
Braminator
Good luck keep us posted.
Old Aug 8, 2013 | 08:56 PM
flakoR56's Avatar
flakoR56
thanks i will keep you guys posted
eliseo1981
Jan 28, 2021 02:45 PM
DeniseNY R52
May 17, 2016 05:16 AM
Zettinger
Aug 25, 2015 04:04 PM
polotska
Aug 23, 2015 03:03 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
