R56 Sport Mode Default to On?
Old Aug 2, 2012 | 06:18 AM
spikfrank's Avatar
spikfrank
Is there a way to configure Sport Mode to default to On? I like having it on always and it would be cool to have the option to turn it off rather than the other way around.
Any ideas?
Old Aug 2, 2012 | 06:26 AM
RobMuntean's Avatar
RobMuntean
Yeah if you call a MINI specialist they can help you because I know a guy here in the Metro-Detroit area and he has that on his MCS.
http://www.outmotoring.com/mini-coop...mode_plus.html
Good luck!
Old Aug 2, 2012 | 08:03 AM
jcauseyfd's Avatar
jcauseyfd
Here is a thread on how to DIY the auto sport button on mod. There is another thread somewhere that compares the DIY method with a couple of the other solutions that are available (like the FES solution).
Old Aug 2, 2012 | 02:07 PM
blitzed310's Avatar
blitzed310
This is what I did, wife hates driving w/o Sport mode on.
Old Aug 2, 2012 | 03:35 PM
Capt_bj's Avatar
Capt_bj
what's the sport button?
Old Aug 2, 2012 | 06:49 PM
Mickey1928's Avatar
Mickey1928
I'm curious; how much does sport mode cost around town, MPG-wise?
Old Aug 2, 2012 | 06:57 PM
jcauseyfd's Avatar
jcauseyfd
If you have an automatic it will cost you a little bit due to the transmission holding gears a little bit longer. I don't think it is much though - maybe 1 mpg?
Old Aug 2, 2012 | 06:58 PM
jcauseyfd's Avatar
jcauseyfd
A clever marketing ploy installed by BMW?
Old Aug 2, 2012 | 07:08 PM
Mickey1928's Avatar
Mickey1928
and for those of us with a Manual tranny - does it really do anything?
Old Aug 2, 2012 | 07:29 PM
jcauseyfd's Avatar
jcauseyfd
It changes the steering input mapping and the throttle mapping. Both "feel" issues, so really a personal thing as to whether one wants to use it or not.
Old Aug 2, 2012 | 08:58 PM
dpcompt's Avatar
dpcompt
sport button
I have a 2012 s manual. I love the sport setting, but I have found that my mileage is better in the non-sport setting. I enjoy the sport setting in spirited driving with some of my mini friends ( heel toe downshifts are easier to match ).
Old Aug 4, 2012 | 06:06 AM
richardsperry's Avatar
richardsperry
If you drive the car the same way, (speed, gear), there should be no difference in mileage.
I've got the FES Auto Sport module. (sport mode always on), and can bearly drive in normal. I'll almost stall it taking off from a stop...lol
Old Aug 4, 2012 | 12:21 PM
dpcompt's Avatar
dpcompt
mileage
The whole point is that I don't drive the same way in "sport mode". The regular mode keeps me honest. I agree with your statement, but in sport I find myself driving faster especially on freeways.
Old Aug 5, 2012 | 04:23 AM
richardsperry
Say what? All sport mode does is change the throttle response from laggy to almost linear. (along with slightly heavier steering feel, ie, less boost from the power steering) How fast you drive is controlled by your right foot. Unless you have wired the sport button directly to your brain. lol
Old Aug 8, 2012 | 11:59 AM
walk0080's Avatar
walk0080
Old Aug 8, 2012 | 12:22 PM
SoundMessage's Avatar
SoundMessage
What is the "FES" solution?
Old Aug 8, 2012 | 12:23 PM
walk0080's Avatar
walk0080
Old Aug 8, 2012 | 05:56 PM
ra2fanatic's Avatar
ra2fanatic
Originally Posted by walk0080
First link in Google search:
https://www.google.com/search?q=FES+...ient=firefox-a
I bought mine at OutMotoring. Pretty easy self-install.
+1
My kit didn't come with a fuse tap, so I had to run out to Autozone and buy one. The metal tap was much larger than the 7.5 amp hole, so it took a bit of cutting and bending, but got it to go in along with the original fuse.
Great mod though!
Old Aug 8, 2012 | 08:00 PM
dpcompt's Avatar
dpcompt
Rocket Scientist
You seem to be an expert on all things Mini. Can you explain how BMW has been able to get better MPG in the normal mode vs. sport mode? Here's your chance big man.
Old Aug 8, 2012 | 08:20 PM
jcauseyfd's Avatar
jcauseyfd
Are you talking about MINI as a whole/in general has produced different MPG numbers for sport mode vs non-sport mode? If so, do you have a link or something for that?
As noted in the thread thus far, for automatics sport mode will produce worse gas mileage because it changes the shift points to not be as fuel efficient. For new models (2011+ I think) that have the pop and burble added back in, there is a tiny bit of loss due to the fuel used for that even for manual transmission vehicles (though I'm not sure anyone has been able to show the difference is measurable).
Or are you talking about your case specifically based on your own experience? If so, the difference in gas mileage would be attributed to you as indicated by your statement, "I don't drive the same way".
Old Aug 8, 2012 | 08:36 PM
dpcompt's Avatar
dpcompt
mpg in normal mode
Ask BMW. The BS expertise of the internet forums and blogs are not the real deal. How about all the add-on intakes and exhaust tweeks. A lot of BS going on. Bottom line, you want to go faster, learn how to drive, ditch the runflats, and get a 19mm rear swaybar. As far as the sport/normal question, you would have to be very careful to attain the same mpg driving in sport vs normal. Sure it possible, but not probable.
Old Aug 9, 2012 | 04:21 AM
richardsperry
In day to day driving, I, (notice the I part), wouldn't see any mileage difference between the two modes. 2000-3000 rpm is the same no matter how quickly you press the throttle.
My car is a 2010 manual MCS. lifetime average economy is 30.7 mpg. It gets more on a long highway trip, and less when I drive like a hoon... Sorry I know nothing about automatics, but it wouldn't surprise me if sport mode changed shift points, that could very well result in a change of mileage. Basically, I was talking about manual cars. Your mileage is controlled by how you drive...
I really doubt that BMW/MINI would ever publish mileage figures for sport mode, but I'm sure they know...
Drcompt, I'm not a rocket scientist, but I am an old engineer, and have seen a few things...
Old Aug 9, 2012 | 05:29 AM
jcauseyfd's Avatar
jcauseyfd
I don't find it hard at all. Just shift at the same point as you go up through the gears.
My own theory is that better gas mileage can be achieved in sport mode because the additional sensitivity of the throttle provides better control for the driver. This reduces the instances of lagging the motor (which seems to be a common complaint of numerous people when using non-sport mode) and then having to compensate by providing more throttle input. Basically, it provides a smoother driving experience which leads to better gas mileage.
Old Aug 9, 2012 | 12:03 PM
MiniCoopOH's Avatar
MiniCoopOH
Sport mode increases your boost psi on a Cooper S from 11.6 to 14.5, which decreases your gas mileage. And the estimated gas mileage for the Cooper s is based on shifting at around 2000 rpm before the turbo kicks in. I have a 2012 Cooper s and I get about 19mpg or so in the city. Less if I'm driving more aggressively.
Old Aug 9, 2012 | 01:06 PM
jcauseyfd's Avatar
jcauseyfd
Overboost is available in non-sport mode as well.
