R56 rpm idle problem
Old May 5, 2012 | 08:51 AM
yyj3869's Avatar
yyj3869
rpm idle problem
I have 07 justa hits 64k automatic transmission and when i run on the street and fully stopped the car, rpm goes down to 500 and slowly going up to normal which is 700. I feel like when coming to a full stop the RPM would go really low and then jump back up making the car surge forward. last time, when i post about this situation, other guy told me to reconnect the MAF sensor and tighten hoses but didn't work at all.. anybody knows how to fix it?
Old May 13, 2012 | 04:25 PM
yyj3869's Avatar
yyj3869
Old May 19, 2012 | 01:06 PM
yyj3869's Avatar
yyj3869
help !!
Old May 19, 2012 | 01:18 PM
Porthos's Avatar
Porthos
Disconnect the battery for a couple of hours and reset the ECU. Unless it is causing a serious danger don't worry about it. Also you can take it to a mechanic and ask.
Old May 26, 2012 | 07:16 PM
yyj3869's Avatar
yyj3869
this is what i'm suffering... but i'm little bit less than that..
http://www.youtube.com/watch?v=Gz61IuHsgM8
and difference between the guy on video and me is he got type-s and mine is justa..
Old May 26, 2012 | 09:04 PM
MisterClean's Avatar
MisterClean
Not sure if it's exactly what you're experiencing but there have been other Justas autos that have experienced the same RPM drop when coming to a stop. I'm one of them and I know someone else had it so bad that the car would stop.
Old May 27, 2012 | 05:52 AM
drsimmons's Avatar
drsimmons
Have you ever changed your spark plugs? Possiblilty.
Also, is the air cleaner clean?
Old May 27, 2012 | 09:53 AM
yyj3869's Avatar
yyj3869
spark plug not yet, you mean cabin air filter is clean? not bad.
Old May 27, 2012 | 10:43 AM
drsimmons's Avatar
drsimmons
Not cabin air filter, the engine air filter. Dirty plugs or dirty engine air filter can cause idle shift.
These are just the two first things I'd check or replace and see if that helps your idle issue.
Old May 27, 2012 | 06:09 PM
yyj3869's Avatar
yyj3869
actually justas replace spark plugs on 100k, doesn't it?
Old May 27, 2012 | 07:27 PM
drsimmons's Avatar
drsimmons
That may be there recommendation but they can get dirty or fail prior to the recommended change interval.
It's just like Mini's recommendation that oil changes be every 15K miles. Now they've changed that to 10K miles because of all the issues occuring from too long of oil change intervals (essentually for the S model though).
Pull a plug out and check it. If it's not toast, you're ok. If really blackened, I'd replace.
iggi
18
Feb 9, 2026 01:00 AM
mdutton11
14
Oct 26, 2015 01:47 PM
Marco Guardado
Sep 15, 2015 01:22 AM
Jacob Kenney
Sep 1, 2015 10:22 AM
Flying Sq
Aug 31, 2015 06:42 AM
