R56 topside oil changer
Old Mar 31, 2012 | 05:35 PM
yyj3869's Avatar
yyj3869
topside oil changer
I bought that item few months ago and today I decided to change oil with that. but... I pumped about 30-40 times and place the tube in the dipstick hole and it sucked up only few and stopped. I think air leaks everytime I pump.. I checked everything but there is nothing wrong...anybody has same problem?
Old Mar 31, 2012 | 06:02 PM
Tarheel27410's Avatar
Tarheel27410
Topsider woes
Yep. Exact same problem. Poor quality fit on the screw-on caps, very light construction that bends easily. It never worked satisfactorily. They must have been made better years ago to earn the reputation they have ... Make that HAD.
Old Mar 31, 2012 | 06:15 PM
yyj3869's Avatar
yyj3869
omg... what am i supposed to do... i've been pumping like over 300 times.. my shoulder is sore.....so... did you return it?
Old Mar 31, 2012 | 06:19 PM
dpcompt's Avatar
dpcompt
Topsider problem
Isn't there a warranty with your purchase?
Old Mar 31, 2012 | 06:34 PM
Blackbomber's Avatar
Blackbomber
I just remove that plug on the bottom of the pan, and let gravity do the work. I'm guessing my Rhino ramps cost less than that device, too.
Old Mar 31, 2012 | 07:12 PM
adrive7's Avatar
adrive7
Try warranty for a replacement. Mine works fine.
Old Mar 31, 2012 | 09:48 PM
Juppers's Avatar
Juppers
Mine works great as well, also bought a few months ago.
Old Mar 31, 2012 | 10:04 PM
yyj3869's Avatar
yyj3869
how many times do you pump? as manual says 30-40 times, which I did.
it works only few seconds.. and stop sucking up.. How long does it go?
Old Mar 31, 2012 | 10:06 PM
adrive7's Avatar
adrive7
30 pumps drained almost all of it. Just had to pump some more to get the last of it. The vacuum runs out quickly sucking air.
Old Apr 1, 2012 | 05:36 AM
richardsperry's Avatar
richardsperry
Look, if you are serious about doing your own maintenance, buy decent tools.
For $100 you could have bought http://www.northerntool.com/shop/too...Product%20Page which really works and is well made.
Juppers's Avatar
Juppers
Same here, do the 30 pumps, then i add another 10 pumps or so near the end of the change to build the vacuum back up to get the last bits.
Old Apr 1, 2012 | 05:46 AM
killerfox's Avatar
killerfox
I have that exact pump except buy the neumatic version, just hook up to air compressor and let it suck. works great.
Old Apr 1, 2012 | 06:26 AM
dpcompt's Avatar
dpcompt
oil disposal?
This may be a dumb question, but what do you guys do with the used oil?
Old Apr 1, 2012 | 06:41 AM
adrive7's Avatar
adrive7
Take it to Advance Auto Parts.
Old Apr 1, 2012 | 07:38 AM
cct1's Avatar
cct1
Just buy a fumoto valve, and do it properly from below.....
It's faster, and you'll get every last bit out.
Old Apr 1, 2012 | 12:35 PM
Ch28Kid's Avatar
Ch28Kid
There's the possibility of muck accumulating in the pan that you wouldn't get out topside that may just drain out when drained from the bottom.
Old Apr 1, 2012 | 12:42 PM
cheapdanny's Avatar
cheapdanny
Mine works great too, just becareful not to over pump.
Old Apr 1, 2012 | 01:12 PM
someguyfromMaryland's Avatar
someguyfromMaryland
CCT1 wrote,
Good idea for R50/R53, bad idea for R56. The newer engines have a vertical opening, which would result in the valve being the lowpoint on the engine. One ding and you're out of oil, possibly without even knowing it. The older engines had horizontal drain plug openings, making for a great spot to put a valve.
HTH someone avoid a painful experience.
Old Apr 2, 2012 | 10:26 AM
Michael Hayes's Avatar
Michael Hayes
I had a similar problem this weekend. The first 2 or three times that I had used it it worked like a charm. This weekend was a bit cool about 46 degres F. I noticed that I could not develop suction. It should be perfect at about 35 pumps. So, it had to be the sealing of the rubber gaskets on one of the fittings or the other. It was, the large gasket, below the pump itself had got in the wrong location. It must be set up so that it goes against the can's metal. I think they made the diameters a little too small, and the gaskets have a tendency to move . Check this very carefully. On each spout, the large and the small, a rubber seal must align on its rim when screwing on the fittings. Once I sorted this out, it worked well.
I've been meaning to nip the end of the thin tube to make sure that a flat end can't seal itself off by pressing against a flat surface, either the bottom of the oil pan or a side wall. Better to have a tiny bit left behind. Remember that the oil itself and the filter are designed to suspend particles. I think it's doing a fine job, if you can get the seals to be air-tight.
I bring the old oil to a re-cycling center near by, but I understand that most gas stations will take the old oil. Best to check ahead of time.
Now can anybody tell me how to bet an easier to read dip stick? This thing's bloody awful on my 2010 Cooper.
Old Apr 3, 2012 | 05:58 AM
terpsred's Avatar
terpsred
+1 on the Mityvac. I have the smaller version without the pump on the side, the pump is built into the main chamber. I've used it since 1999 with no issues at all. I keep finding more uses for it.
One word of warning, warm oil is easier to extract, but if it is too warm the plastic tube you insert down the dipstick pipe will expand and can get stuck in the dipstick pipe. The trick if this happens is to let it cool. Don't panic and try to force it out. (Ask me how I know......).
I feel it gets every bit of oil and grit out of the bottom of the oil pan, just as draining from the plug does. I've measured the oil taken out both ways and they are the same. It is nice not having to crawl under the car to drain the oil. I hate ramps myself. I'm always worried about rolling over the top.
Old Apr 3, 2012 | 07:58 AM
strobeyprobey's Avatar
strobeyprobey
I have an ebay electric oil pump that I used to suck the oil out this weekend. And since I changed the transmission fluid as well, I wanted to see how much oil was left in the pan.
THREE DROPS came out (with the car jacked at angle so the drain plug was the lowest point)!
Awesome! So quick and easy to change the oil this way.
Old Apr 3, 2012 | 09:32 AM
Fastlane's Avatar
Fastlane
I bought a Pela 6000 oil extractor about 10 yrs ago when I owned a VW TDI and have been using it ever since. I use it on the MINI about every-other oil change and it comes in handy. The extraction tube is actually a plastic covered metal coil construction...very sturdy and handles hot oil fine....and the suction pump is quite strong. Has never let me down and you don't have to pump it til your arm goes numb.
http://www.pelaproducts.com/
Old Apr 3, 2012 | 12:45 PM
richardsperry
That's why I have a lift in my garage... I'll never have to crawl under a car on jack stands unless I WANT to.
Old Apr 3, 2012 | 01:48 PM
BoostMe's Avatar
BoostMe
Never been a fan of not using the drain plug, all the sediment won't come out through a hose, how many do 3k mile changes? I do... There is just not a large enough sump for too long
Old Apr 3, 2012 | 02:15 PM
rum4's Avatar
rum4
WHat brand of lift and how much?
