R56 quick spark plug question - with picts...
Old Mar 17, 2012 | 04:01 PM
bksmith76's Avatar
bksmith76
I purchased my 2007 MCS in fall 2010 with 12k miles on it. It now has 35k miles and what i believe are it's original spark plugs. Here is a shot of one of the plugs i just pulled from the engine, and would you all say everything looks good?
yes i have knocking issues, usually running 91 octane gas, lots of carbon buildup at the exhaust tips...
Old Mar 17, 2012 | 05:33 PM
repeater8's Avatar
repeater8
That plug looks fine. You want a nice brown color on the plug. White and fluffy, you're running lean...black and you're running rich. I believe these plugs have an iridium electrode and sometimes it's tough to tell whether the electrode has worn any...the only way you'd know is to know what the stock gap is (I don't) and check where you are with a feeler gauge. Personally, anything over the stock gap, either re-gap the plug or change them. Also...I think you mean carbon build-up on the intake valves, not exhaust.
Old Mar 17, 2012 | 10:46 PM
kukaepe's Avatar
kukaepe
I replaced mine at about 40K miles and found one of them with a portion of the white insulator missing. I assume it left through the exhaust without damaging anything as the car still runs great and doesn't use oil. I have read of other folks that have had these types of plug insulator failures that didn't end so well. I'm not sure but I think the change interval on the "S" is 60K miles not 100K miles. The original NGK iridium tipped plugs can be purchased for about $12 ea at Amazon.com, http://www.amazon.com/NGK-ILZKBR7A-8...2007&carId=001
Old Mar 18, 2012 | 10:38 AM
bksmith76's Avatar
bksmith76
thanks for replies. I did mean exhaust tips (at bumper) not valves. - my exhaust has a thick buildup of carbon on them. trying to keep them clean is impossible.
Old Mar 18, 2012 | 10:49 AM
drsimmons's Avatar
drsimmons
Plugs look fine and the black soot at exhaust tips is normal for these
direct injection engines. Futile to try and keep them clean.
Old Mar 18, 2012 | 05:49 PM
countryboyshane's Avatar
countryboyshane
Looking good!
Old Mar 18, 2012 | 06:50 PM
Ronin82's Avatar
Ronin82
If your worried about carbon build up try a light sea foam treatment or look in the direction of you A/F ratio. thick build up on your bumper sounds like you might not be burning fuel right.
Old Mar 19, 2012 | 09:55 AM
Spridget's Avatar
Spridget
I don't think he was referring to carbon on the bumper... just on the chrome exhaust extensions. As mentioned above, that's pretty much normal, and my personal theory is that it's caused by the intentionally enriched mixture on startup.
Spridget
Old Mar 19, 2012 | 12:09 PM
Porthos's Avatar
Porthos
I really need to get new plugs. I think I am going to go with the JCW cooler plugs.
Old Mar 19, 2012 | 01:24 PM
pheatton's Avatar
pheatton
Try wheel cleaner on the tips. I used it when I had mine worked pretty good. I used the Meguier's Hot Rims cleaner. Just make sure the tips are cold just like when doing the wheels.
They get dirty again but makes cleaning easier.
Old Mar 19, 2012 | 07:01 PM
05Greenie's Avatar
05Greenie
I have a quick question.... I recently replaced my NGK Iridium plugs with Bosch Platinum +4 plugs and when I listen to the radio when driving I have what I can best describe as a high resistance noise that increases and decrease when throttling up to idle. Why would this be a result of changing out the plugs?
Thanks,
Mark
Old Mar 19, 2012 | 07:29 PM
lwbaldep's Avatar
lwbaldep
The plugs may not have the necessary resistor in them to prevent radio interference. Just my two cents.
Old Mar 19, 2012 | 07:35 PM
05Greenie's Avatar
05Greenie
How would I know if they have the proper resistor?
Old Mar 20, 2012 | 06:38 AM
czar's Avatar
czar
The JCW spark plugs, are NOT a cooler heat range spark plug, they are exactly the same heat range: heat range 7.
The letter "R" denotes resistor, you have obviously purchased spark plugs without the letter "R" in the reference part number, this is why you have radio interference noise!
Bublik
Feb 18, 2023 11:09 AM
maniacalmorgan
Jan 1, 2020 11:20 AM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
maniacalmorgan
Aug 19, 2015 08:44 AM
yashmack
Aug 15, 2015 10:16 AM
