R56 alarm retro kit question
Old Oct 2, 2011 | 06:04 PM
bigbacon's Avatar
bigbacon
We just bought a 08 mini hardtop and we want to put an alarm in it. We found out about the retro fit kits from where but we have a question.
Our car has the auto wipers so the stalk is different than what we are seeing in the photos for the kit.
Is there a kit for car with auto wipers? anyone know the part number?
Old Oct 2, 2011 | 06:12 PM
Minidrivr's Avatar
Minidrivr
It sounds like your looking at a retrofit kit for the 1st Gen MINI since it used an LED on the end of the stalk. 2nd Gen MINI uses the red light on top of the tach and shouldn't have anything to do with the wiper stalk.
I don't remember which year but at some point it's been mentioned here that MINI stopped pre-wiring cars for the alarm if it wasn't shipped from the factory with it. Hopefully some one else here might know. Good luck!
You can put your VIN into RealOEM.com and find part numbers.
http://www.realoem.com/bmw/select.do
Old Oct 2, 2011 | 06:19 PM
rkw's Avatar
rkw
Your '08 is prewired for the alarm. Here are the instructions if you wanted to install it yourself: http://motoringfile.com/files/R56_alarm.pdf (you'll still need to have a dealer program it on the car).
Old Oct 2, 2011 | 06:23 PM
bigbacon's Avatar
bigbacon
Yes, I found those instructions but I think the stalk is labeled slightly differently because we have auto wipers, is that correct?
Old Oct 2, 2011 | 06:42 PM
rkw's Avatar
rkw
Look more carefully. You were looking at a set of instructions for older MINI's. The instructions I posted for 2007 and newer MINI does not involve the wiper stalk.
The alarm for older MINI involves the wiper stalk (2002-2004) or turn signal stalk (2005-2006).
Old Oct 2, 2011 | 06:47 PM
bigbacon's Avatar
bigbacon
oh, I did look at those instruction before and just didn't even notice after looking at the holder instructions as well. thanks for pointing that out.
Old Oct 2, 2011 | 07:18 PM
bigbacon's Avatar
bigbacon
so where is the best place to get accessories? any place cheaper than the dealer?
Old Oct 3, 2011 | 05:14 AM
richardsperry's Avatar
richardsperry
Morristown Mini.
Old Oct 3, 2011 | 05:30 AM
SooperCuperErik's Avatar
SooperCuperErik
Parts.com
Use the P/Ns from realoem.com
Old Oct 3, 2011 | 08:47 AM
SewellParts's Avatar
SewellParts
We feature these alarm kits online at: http://mini.sewellparts.com/accessor...2008/5034.html
Make sure to register and login to receive your NAM discount.
Old Oct 3, 2011 | 09:29 AM
Minidrivr's Avatar
Minidrivr
Pelican Parts
www.pelicanparts.com
ECS Tuning
www.ecstuning.com
Old Oct 3, 2011 | 11:11 AM
cesar418's Avatar
cesar418
i see you have also an alarm for a 2011 MCS, is it plug and play or does it need extensive rewiring?
Old Oct 3, 2011 | 11:54 AM
SewellParts
The alarm for a 2011 also requires extensive wiring and programming. Also on 2011, though very few need this, the fuse box may need to be replaced with an updated version (Low to High SPEG). We have only encountered this issue once.
We have one technician that does alarms here and it takes him a full day after installation and programming. I highly reccommend a dealer install on this particular accessory.
I will be more than happy to provide installation instructions for you.
Old Oct 3, 2011 | 12:32 PM
Minidrivr's Avatar
Minidrivr
Mike, how much discount do you offer NAM members?
Old Oct 3, 2011 | 12:40 PM
SewellParts
10% off for NAM members. Just select North American Motoring under the forum list during registration.
Alkaidovich
Jan 30, 2021 01:35 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
AZN Optics
Aug 16, 2015 11:52 PM
