AZN Optics - Morimoto H8 HID kit + More!
Old Aug 21, 2015 | 02:02 PM
AZN Optics's Avatar
AZN Optics
AZN Optics brings you the best in aftermarket lighting! Available now for your fog light conversion are top end Morimoto H8 XB35 HID kits!
www.aznoptics.com/index.php?main_page=product_info&cPath=2_8&product s_id=97
Description
Renowned: The Morimoto Elite Systems have earned their reputation amongst many as the aftermarket's best set of HID's.
HID Ballasts: The all new XB ballasts feature relocated igniters like OEM units, putting them far closer to the HID bulb. The lack of high voltage transmitted through wiring drastically reduces EMI/RFI (radio interference). Total system reliability is also improved by shielding the main circuit board from the static produced by these high voltage bursts on start up.
HID Bulbs: At the heart of the XB H8 bulbs is their perfectly aligned 100% Philips Quartz glass that houses a capsule from APL-USA. Using high quality halide salts from German-supplier Messer; the bulbs produce nearly the same luminosity (intensity) as the amazing Osram CBI bulbs at 5500K.
Canbus Compatible: The Standalone Canbus harness substitute is recommended for European vehicles that display "bulb out" error messsages. They contain a series of capacitors and resistors to trick the car into thinking nothing has changed and help you avoid annoying lamp-out warnings on the dash.
Additionally, we here at AZN Optics can outfit your vehicle with matching plug and play canbus LEDs to complete the modernization look! Just PM with any questions!
Alkaidovich
Jan 30, 2021 01:35 AM
Gremothra
Sep 9, 2015 08:42 PM
Sean Pine
Massachusetts Motoring Club
Sep 2, 2015 08:16 PM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 16, 2015 11:52 PM
