R56 Double Pull Doors
Old Sep 18, 2011 | 07:59 AM
AllWhite's Avatar
AllWhite
Double Pull Doors
I'm wondering whether anyone knows why BMW chose to require passengers/drivers to pull twice on the door release in order to open the doors from the inside. Also, is there any way to change this? I find that passengers are especially perplexed by this requirement and sometimes simply try to pull harder on the release, which of course doesn't help and may result in a broken release. I had an R53 and it did not require the double pull.
Old Sep 18, 2011 | 08:52 AM
vargasgal's Avatar
vargasgal
My R53 has the double pull. I think it is something that can be changed by the dealer.
Old Sep 18, 2011 | 09:09 AM
christomapher's Avatar
christomapher
You just have to program your auto lock turn off using your directional stalk in the settings section. The double pull is found in lots of cars. Think about it this way: if you were in a more "regular" car, you would have to find the lock/unlock button or find the little lock indicator to pull or push one way so you can then pull on the handle. So what would you rather do, pull twice or unlock the door by finding the means to do so and then go back to pulling again? If you turn off that auto lock, then you shouldn't have to deal with this as much.
Old Sep 18, 2011 | 09:27 AM
Neitherfanboy's Avatar
Neitherfanboy
I have had passengers try the single pull and find they can't open the door! I am now used to telling any new passenger "pull twice" as they go to get out. I thought about turning off the autolocks, but I like the doors being locked without me having to do it, so decided against it.
Old Sep 18, 2011 | 09:30 AM
oldsbear's Avatar
oldsbear
First pull to unlock, second pull to open. Is that a good way to say it?
Old Sep 18, 2011 | 09:32 AM
Porthos's Avatar
Porthos
I have my auto lock on because with it off I get a rattle from the locking stalk.
Old Sep 18, 2011 | 09:56 AM
automan21's Avatar
automan21
Originally Posted by christomapher
You just have to program your auto lock turn off using your directional stalk in the settings section. If you turn off that auto lock, then you shouldn't have to deal with this as much.
Then youre driving around in an unlocked car. I dont like that, its easier to get carjacked
I just tell my passengers its a state of the art locking system.
Old Sep 18, 2011 | 12:06 PM
christomapher
Thats a good idea! I wasn't exactly recommending to disable the auto lock feature, as I wouldn't do the same either being in Chicago, but maybe it is different in Arlington VA.
Old Sep 18, 2011 | 02:03 PM
rkw's Avatar
rkw
The R53 has a programmable option to auto-lock the doors when the car reaches 10 mph, and another option to auto-unlock when the engine is turned off. The default is no auto-unlock, which requires a double pull (if the door is locked).
My understanding is that the R56 only has an auto-lock option (no auto-unlock option like the R53). So if you disable auto-lock, it will be a single pull to open the door (unless you had manually locked using the toggle switch). But if you enable auto-lock, you'll be stuck with the double pull.
Old Sep 18, 2011 | 02:22 PM
Opeth's Avatar
Opeth
My R56 autounlocks when the ignition is turned off.
The problem is when dropping off a passenger without turning off the ignition.
Old Sep 18, 2011 | 02:33 PM
Blackbomber's Avatar
Blackbomber
If you love the autolock, then manually unlock from the toggle before exit. If the car didn't have double pull, that's what you would do anyway. I dislike autolock, and if I ever wanted to lock the doors while driving, I can do it manually.
Old Sep 18, 2011 | 02:35 PM
PatM's Avatar
PatM
Where is that programming option found?
Old Sep 18, 2011 | 02:37 PM
Porthos's Avatar
Porthos
+1 where is that programming?
Old Sep 18, 2011 | 02:53 PM
driverphil's Avatar
driverphil
We have ours set for autolock. I am trained to unlock the doors as soon as we are parked.
As to where the settings are - it is in your owner's manual.
Old Sep 18, 2011 | 03:00 PM
RJKimbell's Avatar
RJKimbell
This is one feature I hate on Non-MINIs...I can never find this STUPID Switch, is it...this one...NO...*window goes down* or maybe this ONE::!!
Old Sep 18, 2011 | 03:02 PM
RJKimbell's Avatar
RJKimbell
A great way OldsBear!!
Old Sep 18, 2011 | 04:29 PM
HOG-I's Avatar
HOG-I
Passenger makes first pull and looks confused. Smile and say "you didn't hold your mouth right - try again". Door opens and they really look confused!!!
Old Sep 18, 2011 | 05:50 PM
Speedin Bob's Avatar
Speedin Bob
Originally Posted by neitherfanboy
i have had passengers try the single pull and find they can't open the door! I am now used to telling any new passenger "pull twice" as they go to get out. I thought about turning off the autolocks, but i like the doors being locked without me having to do it, so decided against it.
+1
Old Sep 18, 2011 | 06:13 PM
Minidrivr's Avatar
Minidrivr
See the NCSExpert Threads.
https://www.northamericanmotoring.co...beginners.html
https://www.northamericanmotoring.co...-yourself.html
Not a simple DIY though.
Old Sep 18, 2011 | 06:24 PM
Gentlefury's Avatar
Gentlefury
turn off auto lock, or flip the unlock switch before your passenger tries to exit...not that hard.
Old Sep 18, 2011 | 07:03 PM
PatM's Avatar
PatM
So obviously this is not a standard user programming issue? I was thinking it was. If is isn't I'm really not interested. In this case I would have to agree with other posters. Turn off auto lock or unlock the doors before they exit.
Personally I like the way it is. In most cases it's just my wife and i in our cars most of the time and we know how they work.
Old Sep 18, 2011 | 11:44 PM
MI_MINI's Avatar
MI_MINI
I'm with you. Which is easier? Reprogramming your car or extending your righ arm an clicking the left middle toggle up before your passenger?
Cheers!
Chris
Old Sep 19, 2011 | 05:37 AM
AustinS's Avatar
AustinS
Old Sep 19, 2011 | 08:58 AM
rkw's Avatar
rkw
Opeth is in Norway. The option may be disabled in the US, like auto-up windows which was disabled for years in the US while being available overseas.
Old Sep 19, 2011 | 08:43 PM
theging's Avatar
theging
couldn't you just hit the unlock switch? but i don't see the big problem in 2 pulls.
