R56 Looking for 12v Constant on OBD2 for gauge hookup...
Old Sep 11, 2011 | 01:13 PM
mini4tide's Avatar
mini4tide
does anyone know which wire it is. Alta's directions tell you everything BUT where the 12v constant wire is. I can figure everything else out. I have read and searched, but have not found this info. Your help is greatly appreciated!!!
Old Sep 11, 2011 | 01:32 PM
bluefox280's Avatar
bluefox280
Realized you're looking for power on the OBD serial connector...
Old Sep 11, 2011 | 01:51 PM
jeffm5150's Avatar
jeffm5150
Should be pin 16. Confirm with a DMM.
Old Sep 11, 2011 | 09:29 PM
mini4tide's Avatar
mini4tide
Got it, thanks! The gauges are hooked up just like Alta's instructions, but for some reason they only work when the lights are on. What gives? Any ideas. These are the prosport gauges. Thanks!
Old Sep 11, 2011 | 09:33 PM
bluefox280's Avatar
bluefox280
Originally Posted by mini4tide
...for some reason they only work when the lights are on. What gives?
Sounds like you landed a required constant 12v wire from the gauges to a switched, lights-on only wire on the vehicle.
- Erik
Old Sep 11, 2011 | 09:51 PM
mini4tide's Avatar
mini4tide
From the OBD2 you mean? I used the pin16 red wire with the blue stripe. My ground(black) wire went to the cig brown wire. The orange wire went to red cig (lights on?) and white wire to the DSC grey/red stripe (12v ignition on)? You think I need to swap the orange wire with white wire? I bet thats my issue. I bet I have confused the ignition on wire with the lights on wire. What do you think?
Old Sep 12, 2011 | 07:01 AM
evilc66's Avatar
evilc66
Your description sounds right, but you might want to double check that you actually hooked it up that way. I just installed this myself over the weekend and everything is working fine. I would check that you crimped the right extension wires onto the right wires on the gauge pigtail. While it looks like you have the wires connected to the right spot in the car, you might have swaped some wires higher up in the harness, giving you the trouble you are describing.
Old Sep 12, 2011 | 11:31 AM
mini4tide's Avatar
mini4tide
I'll check it out. I think you may be right. Thanks!
Old Sep 12, 2011 | 11:49 AM
mini4tide's Avatar
mini4tide
Just switched the 2 wires and its fixed. Thanks for all your help!!! I really appreciate it!
Old Sep 12, 2011 | 01:38 PM
evilc66's Avatar
evilc66
What exactly ended up being the problem?
Old Sep 12, 2011 | 06:41 PM
mini4tide's Avatar
mini4tide
I had the orange and white wires mixed up. The white should go to the cig red and the orange goes to the DSC grey red stripe.
Old Sep 13, 2011 | 07:53 AM
evilc66's Avatar
evilc66
That alone should not have stopped the gauge from working. That only changes the color of the gauge during day/night operation.
Old Sep 13, 2011 | 02:53 PM
mini4tide's Avatar
mini4tide
It does if you have to switch on the lights to get power to the gauge. I had the 12v switched wire hooked up wrong.
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
silence2-38554
Sep 28, 2015 12:19 PM
daviday
Sep 25, 2015 01:31 AM
