R56 Alta CAI = Check Engine Light ?
Old Jul 20, 2011 | 05:19 PM
WindstarMini's Avatar
WindstarMini
Just installed the ALTA CAI on my 2011 Mini Cooper S and on the third drive out the check engine light came on. This is an otherwise stock car with 1500 miles on it. I bought the ALTA because I was led to believe that the CEL wouldn't be an issue. Any thoughts on this ? Anything I can do to remedy the problem ?
Thank You Guys !
Old Jul 20, 2011 | 05:22 PM
minimike21's Avatar
minimike21
Hmm hopefully someone will chime in. Haven't heard anything about this before?? Go to an autozone to see what the code is??
Old Jul 20, 2011 | 06:12 PM
yetti96's Avatar
yetti96
Did any sensor or hoses get knocked loose or left off in the install? Double check all connections.
Old Jul 20, 2011 | 06:32 PM
Scooter09's Avatar
Scooter09
+1, if ANY hose is loose or not connected properly you WILL get a CEL.
Old Jul 20, 2011 | 06:51 PM
WindstarMini
Double checked connections...
Double checked all connections... Everything appears to be connected properly ? I guess my next step is to hace the CEL code diagnosed ? Any other ideas ?
Old Jul 20, 2011 | 07:05 PM
slinger688's Avatar
slinger688
Replace the Alta CAI with stock to see if you still get the CEL. If it goes away, the problem is with the Alta CAI. If it stays on, the problem is somewhere else.
Old Jul 20, 2011 | 07:20 PM
6speedwtneed's Avatar
6speedwtneed
Go to auto zone and reinstall stock after you go to auto zone.
Old Jul 21, 2011 | 07:18 AM
OPC's Avatar
OPC
RATTUS Deserticus
A couple of check points:
Did you remove the excess oil off the foam filter? If not, your MAF sensor could be dirty.
Double check the air intake into the turbo to make sure it didn't wiggle loose when you installed the CAI. These are a little notorious for slipping off. IPA and a real hose clamp are your best friends here.
Regardless of the fix, you'll still need to have the code read and reset. I'd expect it to be a P2188 if it is CAI related.
Old Jul 21, 2011 | 07:52 AM
AXO's Avatar
AXO
I second checking the MAF sensor. It probably has oil on it from the new foam filter.
Old Jul 21, 2011 | 09:00 AM
scoopdaloop's Avatar
scoopdaloop
CEL parameters.
I would check your hose connections to make sure they are sealed and then make sure you installed the MAF sensor correctly.. did you detach the battery before doing the install?
Old Jul 21, 2011 | 02:44 PM
automan21's Avatar
automan21
If you removed the maf then put it back on I would check to make sure its the right way, theres an arrow showing directon of flow. Then check all plugs and hoses.
Old Jul 21, 2011 | 03:06 PM
6speedwtneed
YES, direction of flow arrow.. very good point. and clean your MAF sensor with MAF sensor cleaner or elctronic cleaner (can be bought at your local auto parts store). and my Intake came slightly loose from my turbo before, so i wouldnt doubt it would happen to someone else.
Teh
Aug 22, 2022 04:37 AM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
