R56 What is a "cold-climate version"?
Old Aug 21, 2009 | 07:08 PM
Yossarian's Avatar
Yossarian
This was on the option sheet the dealer sent to me today on my 2010 order. It isn't the cold weather package. The dealer rep didn't know what it was, he just said that some MINIs are equipped this way regardless of the climate they're sent to.
Old Aug 21, 2009 | 07:27 PM
RJKimbell's Avatar
RJKimbell
Maybe it has the wiring for a Block Heater already??!!
Old Aug 22, 2009 | 02:47 AM
Sabes's Avatar
Sabes
Yea mine said that too! It was annoying because at first we thought it was cold weather package and spent like 10 minutes looking for the heated seat button.... Still have no idea what it means tho
Old Aug 22, 2009 | 03:49 AM
mattsenpai's Avatar
mattsenpai
Maybe it's something techie-wacky-mechanical under the hood that had to be rubberized or insulated to endure our "cold" climate here?
just a guess. i wish i knew these parts under the hood, i dont even know which of those metal pieces is the turbo. My friend said the turbo in the mini coopers looked small.. which didnt help. but dude, everything about the dang car is small except the central speed-o-mememeter
Old Aug 22, 2009 | 04:22 AM
jbewley's Avatar
jbewley
I saw this on MotoringFile about the new Clubman. Perhaps this has something to do with it:
In addition the car can either come with : A) summer configuration: 17” Black Web-Spoke w Performance Tires (2RW) or B) winter configuration: 17” Black Crown Spoke (2RP, 2RV) w All-Season Tires (927) and Cold Weather Package (CWP)
Jim
Old May 17, 2015 | 07:55 PM
yeslikethewhiskey's Avatar
yeslikethewhiskey
Was searching for the same thing. Same boat as you all.
Maybe this: http://www.ecstuning.com/Mini-2009-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/ES1875402/
Old May 17, 2015 | 09:24 PM
Slave to Felines's Avatar
Slave to Felines
Could it have anything to do with the revised intake that helps combat icing inside the manifold? We have members here that have had those retrofitted onto their cars by dealers up north.
Old May 18, 2015 | 09:13 AM
http://www.ecstuning.com/Search/SiteSearch/11614584240/
Factory for some people up north and a add on for some cold climate.
https://www.northamericanmotoring.co...ding-part.html
Old Feb 3, 2016 | 07:54 PM
alka1ine's Avatar
alka1ine
Maybe this: http://www.ecstuning.com/Mini-2009-C...16A/ES1875402/
I know this is old, but my 2007 MCS has the "842 Cold Climate Version" and didn't come with that newer design intake(also because it wasn't out yet), so I have no idea what is different besides Realoem saying that the injector harness is different for 842-optioned cars
I did buy the cold climate version anyways because I was rebuilding the engine and it was only $40 and came with all new gaskets. I am planning on making some sort of high pressure misting system to run in-line with that direct port pcv setup so I can clean my valves automatically or at least with a push of a button every other day. There will be a build thread when I finally get around to it. Not sure if I'll mist something like seafoam, water, or some other concoction, but I'm confident I can eventually create a permanent fix for carbon without any walnuts
Old Feb 4, 2016 | 08:03 AM
Yea, I believe it was not out in 2007 but later on as a repair fix and certain northern locations as a option.
Sounds like a great project. Some people have through of using it for just that , a easy carbon cleaner injector location.
Old Feb 4, 2016 | 09:17 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1
11-61-7-595-078 part number for normal and 11-61-4-584-240 HERE for cold climate. Includes intake manifold gaskets and throttle housing gasket.
888.280.7799 | 6am - 5pm PST
Old Feb 4, 2016 | 02:25 PM
alka1ine's Avatar
alka1ine
Yeah, I definitely need to get a catch can or something on there in the meantime. Not sure if my recent stumbling idle was HPFP jitters first couple minutes after starting, or if it's sucking in "normal" amounts of oil now with the new valve cover. It would be real bad in non-sport mode with the old cover. I vented the rear port to atmosphere until the new cover came in and all was fine again...
Soooo nobody knows what it includes and why something like the injector harness would be different?
Old Feb 4, 2016 | 02:30 PM
The harness might be different per your car , but the intake is the same in the US and Canada version whom had this update for that part number. All I can think of on the harness its the same but with more insulation and wire wrap fro colder areas or maybe it pre warms the coils with a low voltage before start up.
Zettinger
Aug 25, 2015 04:04 PM
Sassenach
Apr 21, 2015 05:47 AM
Kaywinnet Lee Frye
Oct 1, 2014 07:26 AM
RichSz
Jul 19, 2014 09:22 AM
Papote
Nov 28, 2012 05:27 AM
