R56 Joey Mod Feedback needed
Old Jan 20, 2009 | 08:05 AM
Red Bull's Avatar
Red Bull
Hey guys...
I am not shy about taking our cars apart to do mods however, I like to fully understand what I am getting myself into. Never took apart a headlight assy so looking for feedback from those who have done theirs and any tips or instructions that would help from the DIY'er.
I just priced a new set in case I destroy the headlights....over 1K for a set!!!! So this is no small matter if I screw them up...thats 1K of future mods throw away.
I saw some time ago a thread with good instructions for the R56 but can't find it. We have the Zenon's.....feedback would be appreciated.
After I get the project done I will do a full detailed write up with pictures
Old Jan 20, 2009 | 08:11 AM
pillar's Avatar
pillar
https://www.northamericanmotoring.co...y-mod-r56.html
which method are you doing... heat gun or oven?
It seems that people have been successful with plastidip without chipping. I used primer and krylon fusion and found that there is some chipping.
Old Jan 20, 2009 | 08:33 AM
Red Bull's Avatar
Red Bull
Want to do the method that works best...
I will be etch priming and then base coat then clear for the finish. I have some ideas on how I am going to tie in the DS and black...subtle but should look really nice when I am done. Got to get over the fear of the oven bake or heat gun process. Really want to hear from someone who did the R56 Xenon lights.
Please keep feedback coming.....Thanks all...
Old Jan 20, 2009 | 09:35 AM
SidSwiftsteel's Avatar
SidSwiftsteel
Red Bull: Based on everything else you've done, I'd be willing to bet that whichever method you use, it will come out looking great.
Old Jan 20, 2009 | 10:24 AM
Red Bull's Avatar
Red Bull
Thanks Man....want to do something a little diffrent. Trying to figure that out is half the fun for me.
My biggest concers besides throwing them in the oven is how much heat the light throws on the plastic bucket. Dont care for rattle can paint and plan on spraying them but have to check what temp it can hold up to.
Old Jan 20, 2009 | 10:42 AM
Noegel's Avatar
Noegel
Haha, crazy Red Bull. You speak of fears, or act frightened about what might happen, but we all know it is going to turn out fantastic!
Good luck!
Old Jan 20, 2009 | 11:48 AM
Red Bull's Avatar
Red Bull
Good luck!
Yes yes...I have issues.. Going to start the joey mod in the morning. Hope for no surprises..
Old Jan 20, 2009 | 12:01 PM
MInI___Gz's Avatar
MInI___Gz
If i remember correctly u smoke tinted your like me and well .. i think it looks better like that...even tho i am sure you can do a perfect joey mod
Old Jan 20, 2009 | 12:25 PM
Red Bull's Avatar
Red Bull
I like the laminex a lot but, if I have the choice I would much rather have an item painted instead of covered. It is just more finished to me. The Laminex on the rear lights and side markers are perfect but there is something about the headlights. When I see a good joey mod I love it.
Old Jan 20, 2009 | 01:36 PM
Ryephile's Avatar
Ryephile
This is my post from the Joey-Mod thread. Overall it's much easier than I expected, even the 1st time doing it.
I did the Joey Mod today on my R56! Thanks to everyone in this thread for sharing their experiences, it was super easy to do it and the result looks fantastic!
Tools needed:
*10mm hex socket and ratchet [to remove headlights from car]
*T-10 torx to remove turn signal lens from headlight housing
*T-20 torx to remove headlight washer and bezel from housing
*large slotted screwdriver to pry off retainer clips and pry apart housing
*#00 steel wool
*spray paint for plastic [I used textured black finish]
Step 1: Remove headlights from car. 4 bolts per headlight, piece of cake
Step 2: Tear apart the headlight bits. Remove headlight and turn signal access panels, take out turn signal bulb, remove washer
Step 3: Remove two retaining clips [one on top, one behind headlight washer]
Step 4: Preheat kitchen oven. Put headlight into oven [I have a natural gas oven] at 250F for 5 minutes.
Step 5: Remove headlight with oven mitts and immediately pry apart polycarbonate lens from ABS housing, remembering to unclip the handful of plastic retainer clips. The RTV [sic] is super gooey. If you don't get the headlight warm enough the RTV will be very stringy. Don't get the headlight too hot as the polycarbonate will start to melt!
Step 6: Remove bezel from lens
Step 7: Remove turn signal housing from bezel
Step 8: Use steel wool to roughen chrome on bezel, wash with soapy water when finished. Repeat for headlight washer chrome.
Step 9: Paint bezels and headlight washers. Use 3 light coats as this type of paint loves to run when applies even slightly too thick. Let it all dry.
Step 10: Reassemble the bezel and turn signal and lens.
Step 11: Squish lens to housing and compress the RTV as much as possible
Step 12: Put assembly back into oven @ 250F for 4 minutes to reheat RTV.
Step 13: Remove with oven mitts and immediately compress the RTV as much as possible.
Step 14: Snap on the two retaining clips and bolt on the headlight washers
Step 15: Bolt headlights back into the car and perform headlight alignment with both headlight pattern and fitment against bonnet.
Taa Daa!
Here is my old setup: Lamin-X "gunsmoke" tint. Looked great but blocked WAY too much light. It looked like I had old dingy halogen headlights at night.
Now the new Joey-Mod!
Cheers!
Ryan
Old Jan 20, 2009 | 01:43 PM
pillar's Avatar
pillar
i used heatgun method. Lots of prying required. just heat, pry, heat, pry and eventually, the whole thing just popped off.
just be careful when you pry because my edges arent as smooth as it used to be...this is due to trying to pry using a flat head
Old Jan 20, 2009 | 02:08 PM
wandrur's Avatar
wandrur
Moderator
Ryephile,
Fan-freakin'-tastic step-by-step with pics!!! I have wondered about this for a long time, and now you've cleared up the mystery. Excellent work.
Old Jan 20, 2009 | 03:23 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
Here is my Joey Mod "how to" thread. Have fun!
https://www.northamericanmotoring.co...-to-do-it.html
Old Jan 20, 2009 | 04:36 PM
Red Bull's Avatar
Red Bull
Just did the first side...took about 1 1/2 hours. I used a heat gun...really easy mod...The longest part was the paint drying. I will do a step by step in a couple of days. Here is a rough shot..
Old Jan 20, 2009 | 05:51 PM
MInI___Gz's Avatar
MInI___Gz
LOOKS GREAT!
Old Jan 20, 2009 | 05:56 PM
IzzyG's Avatar
IzzyG
Er, let me get this straight, you guys painted the WHOLE inner surface black? Even the reflective part? I thought you had to leave that alone? I taped the shiny parts and plasti diped the long tube(turn signal) and painted the other "eye" red. I'll definitely redo them if I can paint the whole thing black though. Although since I have halogens(aka very low beam), I'm not sure if this will further dim things.
Old Jan 20, 2009 | 06:01 PM
Red Bull's Avatar
Red Bull
Yes I painted the entire bucket....Dont know if it will dim your lights but from the guys who did the mod with xenons they said they saw no diffrence....I will be able to tell you better in about an hour.
Teh
Aug 22, 2022 04:37 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
minipopkart
Aug 13, 2015 05:22 AM
bc219
Aug 10, 2015 11:22 AM
