R56 Bio Ethanol fuel
Old Jan 16, 2009 | 08:27 AM
diplo's Avatar
diplo
Bio Ethanol fuel
anyone running bioethanol in the R56 yet? I have been reading that the performance is incredible, plus, eco-friendly.
Old Jan 16, 2009 | 08:35 AM
Engender's Avatar
Engender
Where would you be able to get bioethanol? Would the engine require modificiation?
Old Jan 16, 2009 | 08:37 AM
Mishka's Avatar
Mishka
Are you asking about the E85 fuels?
I'm not sure about the 2nd Gen MINIs, but the 1st Gen MINIs are not to be run on any fuel with higher than 10% ethanol. I've heard of it possibly causing engine problems, and that it would void the warranty. You may want to check with the dealer or in your owners manual before trying it.
Old Jan 16, 2009 | 08:40 AM
uzun's Avatar
uzun
Most gas sold these days already has 10% ethanol in it. Anything more than 10% ethanol would mess up the engine and the fuel system.
Old Jan 16, 2009 | 08:42 AM
Ryephile's Avatar
Ryephile
The MINI is not designed to run on E85. Nothing over E10, actually. Ethanol, besides being corrosive, has a different stoichiometric lambda than gasoline. The MINI is designed to handle the small 10% of Ethanol in our gasoline, but the ECU does not have any sensor to "see" fuel beyond 10% like FlexFuel cars [like most not-so-Big-3 cars], so it would end up running dangerously lean with E85 or E100.
Old Jan 16, 2009 | 11:32 AM
diplo's Avatar
diplo
okay, i figured there would be complications. I was thinking about e85, because i have heard of other cars, (especially in europe) that were tuned for that and the higher octane results in a large increase in power.
Old Jan 16, 2009 | 12:48 PM
Ryephile's Avatar
Ryephile
Ethanol has a lower energy content per unit volume. That said, stoich for ethanol is much more "rich" than gasoline. The net result is you can get approximately 10% more power with ethanol over gasoline. The downside is fuel consumption is massively increased, about 25% +/-5%.
Old Jan 16, 2009 | 01:54 PM
corcoranwtnet's Avatar
corcoranwtnet
I was in Brazil in the early 80s and they used a lot of ethanol then. It was great...Rio smelled like fried chicken or french fries, wherever you went; the heavier the traffic, the better the smell!
Old Jan 16, 2009 | 05:08 PM
miniclubman's Avatar
miniclubman
Ethanol may or may not be eco-friendly, depending upon how it's derived. Ethanol derived from corn is not sustainable, owing to the huge amounts of corn that would need to be planted each year to yield enough to power the cars in the U.S. As a subsidized boondoggle for farmers, it's a great success. Also, to generate a gallon of ethanol from corn you need to input almost the equivalant amount of energy. It's also a bad idea to use your food supply to fill your your gas tank.
Old Jan 16, 2009 | 06:01 PM
uzun's Avatar
uzun
Indeed, corn-based ethanol is a scam. I hate that crap. If my fuel gauge or fuel pump prematurely fails, I am going to blame it on this crap. I always fill up at Top Tier stations such as Chevron and Shell hoping that the ethanol content of the gas I am getting is not greater than 10%. It has been reported that some stations out there are selling gas with ethanol content greater than 10%.
Old Jan 18, 2009 | 03:26 AM
fm.illuminatus's Avatar
fm.illuminatus
Just running the standard 10% ethanol pushed in a lot of states already shortens the engine life... also, creating ethanol fuel is environmentally destructive, the consumption/waste impact is larger than gasoline, and growing of corn for ethanol contributes to global famine by depriving 3rd world countries of food. There really is no good reason to use ethanol fuels.
Old Jan 18, 2009 | 03:52 AM
glangford's Avatar
glangford
Celluosic ethanol is the way to go.
Also when I was in Germany last year my cousin showed me the hops fields. I thought it was for beer, he said no, bio-diesel.
Old Jan 18, 2009 | 04:00 AM
lhoboy's Avatar
lhoboy
+1.
Im curious about the use of the term bio-ethanol. At least 99% of all ethanol is produced from bio-mass. Small quantities of synthetic ethanol might be produced, but I am not aware of it.
Old Jan 18, 2009 | 04:11 AM
lhoboy's Avatar
lhoboy
Though modern fuel systems and engines are designed apprpriately and have not been shown to fail early as a result of the use of E10, I agree with your premise that the energy equation of enthanol production and the accompanying loss of food production make the use of ethanol as a fuel unviable over the long-term. The only reason it works today is tax credits for fuel manufacturers.
Old Jan 18, 2009 | 06:08 AM
grodenglaive's Avatar
grodenglaive
Yes, Iogen Corporation in Ottawa, ON has developed an enzymatic method to produce ethanol from corn stalks, so you can have your fuel and eat your corn too. Last I heards they were in the process of improving yields and ramping up production size.
Old Jan 18, 2009 | 08:17 AM
minimalistic's Avatar
minimalistic
in other words, I doesn't at all work.
Old Jan 19, 2009 | 05:08 AM
corcoranwtnet
You doesn't?
IQRaceworks
53
Jun 28, 2024 07:29 AM
OutMotoring
Mar 3, 2017 06:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
dutchhome
Sep 30, 2015 07:17 AM
