R56 One thing that drives you nuts about your MINI!
Old Jun 9, 2009 | 09:11 PM
  #401
daffodildeb's Avatar
daffodildeb
Originally Posted by r56cooper
my 07 cooper has auto down but not auto up windows
i wish there was a beep or some sound when i lock the doors
They added auto up windows for '08. I've heard there is/is not an aftermarket program to convert the '07s.
I don't need a beep--the locks are the loudest of any car I've ever owned. I can hear them from inside the house!
Old Jun 9, 2009 | 09:57 PM
  #402
r56cooper's Avatar
r56cooper
yes i heard about this too, its just annoying to hold the up switches while shifting gears.
i agree about the loud locks but for some reason my brain doesn't always register this noise. I find myself questioning whether i locked my car and having to go back and check. My past cars beeped upon lock and I liked it better that way.
Old Jun 9, 2009 | 10:00 PM
  #403
daffodildeb
What you're experiencing is your MINI's call to you. It's sort of like the "are you sure you want to delete this?" question you get on the computer. S/he just wants to make you take another look...
Old Jun 10, 2009 | 10:23 AM
  #404
r56cooper's Avatar
r56cooper
haha
Old Jun 10, 2009 | 06:13 PM
  #405
coreygo's Avatar
coreygo
Things that annoy me after about a month in the MCS:
1. Rattles, there are so many it's not even funny.
2. Not sure I'm doing something wrong but the comfort access doesn't seem to open both doors only the one the key is near. This kind of sucks for my gf since I never press the remote, just walk up and get in. Would be nice if it would for her.
3. The iPod cable thing doesn't seem to like my iPhone 3G very much, am guessing I need some other thing installed or something. Tips would be appreciated.
4. There doesn't seem to be a volume indicator and while each source seems to have its own volume not sure what levels they are at (kind of wish I bought the navi since I'm guessing it gives more details).
5. Radio reception sucks, even worse than the outgoing GTI.
Old Jun 10, 2009 | 06:29 PM
  #406
r56cooper's Avatar
r56cooper
i agree with ^ #1 & #4
i like it when there is a volume indicator, not having one is hard to get used to
Old Jun 10, 2009 | 06:36 PM
  #407
carsncars's Avatar
carsncars
1. If they're fairly regular, they should be easy for the dealer to spot and fix. It should be under warranty (within reason... it's never going to be dead silent over double speed-bumps).
2. I know for the non-comfort access, you can program this through the car's computer. Check your manual.
3. Symptoms? I know some people have an "older" revision of the iPod cable that doesn't charge the iPhone 3G.
4. Nope, no volume indicator...
5. Radio reception just sucks in general where I live so I can't really comment on that. Hasn't been noticeably worse than any other car though.
Old Jun 10, 2009 | 06:46 PM
  #408
coreygo's Avatar
coreygo
They're going to try and fix them for sure since they still owe me a new brake caliper. But no kidding, I can be driving in 2nd at 30mph and the rattles are non stop. It comes from around all the cheap plastic bits, like the outside air vents especially, plus the plastic housing the speaker near the handle. Applying just a bit more pressure with your hand kills the rattles.
Didn't see anything specific, tried going through the computer and didn't see anything special.
I get the warning that the accessory isn't compatible. Then randomly the head unit will refuse to list any of the songs. I don't quite know what I do to fix it, but typically the next time I get in the car and plug it all in it'll read fine. Charging works fine.
Bummer.
Listening to KEXP 90.3 I got perfect reception all the way down to the dealer in the GTI. In the MCS it's dead static half way there. Kind of weird.
Not too big of a deal since I don't really listen to the radio. I use a 16GB SanDisk Cruzer Micro loaded with a bunch of music usually since it works perfectly it's always plugged in and I leave the iPhone in my pocket.
What I wouldn't mind doing is having a way to split the USB to do the memory stick plus charge the phone...
Old Jun 10, 2009 | 07:21 PM
  #409
blackjackmark's Avatar
blackjackmark
RE: the unlocking of the doors with Comfort Access...it's definitely a setting in the OBD on whether the unlock switch on the fob unlocks both or just the driver's side....
Old Jun 10, 2009 | 08:24 PM
  #410
coreygo's Avatar
coreygo
Yep, just saw that and now it's unlocking both sides. I guess I was assuming the button on the handle worked like the actual key fob remote. Press it once for drivers and twice for both. Apparently not, at least it didn't seem to .
Old Jun 10, 2009 | 08:32 PM
  #411
daffodildeb
In the "For What It's Worth Department," I personally wouldn't want both sides to unlock at the same time. When I'm at the grocery store I can toss my purse onto the floor of the passenger side so I can load my groceries into the truck. Also, there's considerably less chance for carjacking with that door locked.
Yes, I realize most men don't carry purses. Yes, I realize the chances of a carjacking are miniscule, even in urban areas. Still...
Old Jun 10, 2009 | 09:02 PM
  #412
22of37's Avatar
22of37
the one speed noise of the front window defroster
Old Jun 10, 2009 | 11:57 PM
  #413
coreygo's Avatar
coreygo
Makes sense and for me I really just wanted the drivers to unlock by itself. Just wish I could press that door handle button twice to unlock both sides.
Haven't had to use my defroster yet but I could see that being annoying.
Old Jun 11, 2009 | 05:13 AM
  #414
galoki's Avatar
galoki
Where does the rattle noise come from? My 09 MCS has a rattle under the front floor board. Turned out to be a loose sway bar. Easy fix. I have no other rattles or weird sounds now...it's a little tank.
Old Jun 11, 2009 | 07:14 AM
  #415
toolazyforalogin's Avatar
toolazyforalogin
most of my rattles come from sunroof / b pillars
Old Jun 11, 2009 | 12:03 PM
  #416
daffodildeb
Funny, a friend of mine had the same rattle with the same cause. I think his was an older model, though (he has 2).
Old Aug 19, 2009 | 12:37 PM
  #417
TRL's Avatar
TRL
Most insistent chimes of any car I've ever owned.
Every button or **** on dashboard.
Top half of tach blocked by steering wheel (at least if you are 6' 3")
Old Aug 19, 2009 | 01:43 PM
  #418
PatM's Avatar
PatM
You can turn the chimes down. See the owners manual.
Didn't you drive the car before you bought it? That could have solved numbers 2 and 3.
Old Aug 19, 2009 | 02:26 PM
  #419
daffodildeb
Do you mean the idiotic "key in, door open" and "Dude, wear your f'g seatbelt!" chimes?
I rode in a friend's '08--his were much more muted. PatM--I'm lazy, and away from the book--do you mean you can tone down these, too? We just finished a long trip (MITM and beyond), and TRL's right--they're loud enough to drive you nuts!
Old Aug 19, 2009 | 03:33 PM
  #420
PatM's Avatar
PatM
You can in the 2009 cars.
Old Aug 19, 2009 | 08:55 PM
  #421
daffodildeb
PatM, I looked for it in the manual tonight, but either it's not there, or I picked the wrong search word. Where is it? I have an '07.
Old Aug 19, 2009 | 09:39 PM
  #422
PatM's Avatar
PatM
In my car which is an 09 it is not in the main manual but in the radio manual which is a separate document from the owners manual. It is under the section called "Radio Settings". I have the Uplevel Stereo system and to change the chime level I have to press the music note, then press another button that gets me to Bass/Treble/Balance/Fader/PDC*/Chime settings. I turn the volume control to adjust then hit the return symbol to exit.
Anyway, not having your vehicle nor the documents that came with it I'm not sure that you can even change it. Maybe someone with an 07 and your particular radio type can help you. Sorry.
Old Aug 19, 2009 | 09:49 PM
  #423
r56cooper's Avatar
r56cooper
i agree on not being able to see the top half of the tach cuz its blocked by the steering wheel
i wish it was above the wheel, possibly right on the dashboard, kinda like the Si
also, the throttle response feels a bit delayed to me, even in sport mode
also, the revs dont climb as fast as i'd like, after driving an Si it feels slow
would a lightened flywheel do the trick?
i know there is a mod (supersprint booster?) for the throttle response,
but i dont feel like shelling out 300+ for it
Old Aug 19, 2009 | 09:51 PM
  #424
Canoehead's Avatar
Canoehead
Speedometer(s) reading 2 to 3 mph under the actual speed when above 70 mph (or as we say in Canada: 5 km/h above 120 km/h) Test it with as many GPS units as you can...
Old Aug 19, 2009 | 10:04 PM
  #425
daffodildeb
Thanks, PatM--never thought of looking in the radio manual. I'll try it tomorrow.
r56cooper, you might solve your problem by adjusting the height of the steering wheel, along with the height of the seat. Also, the steering wheel can be adjusted in and out, and there will probably a combination that will allow you to see what you need. I'm particularly sensitive to warning lights, so I've spent a little time working it all out. I think this is a problem with all cars to some extent.
Canoehead, I've had lots of cars over the years (I sound like an old lady!), and all speedometers are inaccurate to some degree. Two or three miles doesn't seem like a big deal to me.
