R56 Using “MINI” logo tire valve stem Covers with TPS
Old Jun 30, 2008 | 03:07 PM
OkieSnake's Avatar
OkieSnake
I lost two of the large gray valve stem covers on my 08 MCS. I have run flats. My daughter had bought me a set of the chrome one with the "Mini" logo from the dealership. However some one (hopefully missinformed) told me that you can not use valve stem covers that are metallic because it interfers with the TPS monitor on the 08's.
Can any one confirm or debunk this rumor?
Old Jun 30, 2008 | 04:03 PM
x SPUD x's Avatar
x SPUD x
i have a set of those on my 07 with tpms and i have no problems. and if i remember correctly, arent the stock ones metal as well?? (cant remember since i changed them right when i got the car)
Old Jun 30, 2008 | 04:33 PM
wbarnhill's Avatar
wbarnhill
Coordinator :: Upstate MINIs
I've heard from multiple MAs that the metal valve stem covers will mess with the TPMS system, and that MINI has come out with a new set that doesn't. I'm sure the MINI parts dept at your dealer will swap out the covers if there's a problem.
Old Jun 30, 2008 | 04:38 PM
Apple's Avatar
Apple
you need to lube them, the problem you will have if you cant get it off, all my cars had theTMPS, use lube or get them stuck ")the do not hurt the readings , they just get fused on the valve
Old Jun 30, 2008 | 06:09 PM
RJKimbell's Avatar
RJKimbell
We purchased a set of the Union Jack VSC's when we picked up Molly (19/04/08)...Funny the Parts Guy never mentioned a problem. And we haven't had any issues to date.
Old Jun 30, 2008 | 06:14 PM
Partsman's Avatar
Partsman
Legion_of_Doom
https://www.northamericanmotoring.co...d.php?t=140987
Old Jun 30, 2008 | 09:23 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
I picked up my 08 MCS today and had the checkered valve stem caps, TPS seems to be fine. They were redesigned.
Old Jul 1, 2008 | 04:37 AM
OkieSnake's Avatar
OkieSnake
PARTSMAN - Thank you for the thread link. And your listing of the correct PLASTIC part numbers
Original MINI ABS/Plastic valve stem caps...
MINI wings logo-part number-36 11 0 429 651
"S" logo-part number-36 11 0 429 652
Checkerboard-part number-36 11 0 429 945
Union Jack-part number-36 11 0 429 946
Old Jul 1, 2008 | 05:13 AM
andrewholmes's Avatar
andrewholmes
i use them on mine...no worries here.
Old Jul 1, 2008 | 06:43 AM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
Partsman is correct, there are two different styles to the valve stem caps, one is plastic the other is metal. If you have the older style TPMS that doesn't have the sensors in the wheels you can use any valve stem cap you want. If you have the newer TPMS (indicated by a metal valve stem) that you need to use the plastic cap.
At least that is what the parts department at my dealership told me. The price for the caps are the same whether or not they are metal or plastic.
Old Jul 1, 2008 | 05:36 PM
Partsman's Avatar
Partsman
Legion_of_Doom
You're welcome, glad I could help.
The "shank" part of the two caps are actually different lengths, the plastic ones are shorter and don't fit all the way to the rubber on a regular valve stem.
David.R53
Sep 1, 2015 06:49 PM
SunnySideUp
11
Aug 26, 2015 06:42 AM
PaulWalliDumali
Aug 21, 2015 04:46 PM
eliseo1981
Aug 6, 2015 05:00 AM
