R56 Seat Loose?
Old Jun 16, 2008 | 02:47 PM
kevinminict's Avatar
kevinminict
Seat Loose?
Does anyone elses MINI's Drivers side seatback have some play in it, Like an inch or two....when sitting down the seatback moves back and forth. Mine does and its driving me nutz! Compared to my passenger seat which is solid as a rock.
I am curious if anyones has play in it, when your sitting in the seat the seatback is a little loose? just wish I could swap my two seats and I would be content. I'm contacting Mini to try and get this resolved.
Old Jun 16, 2008 | 02:50 PM
Goldilocks's Avatar
Goldilocks
nope - both my seats are solid. hope you get resolution! maybe you could get a new seat?????
Old Jun 17, 2008 | 06:55 PM
poidog's Avatar
poidog
I feel a little movement from my seat back when I stop. It's not much, but I do notice it. It is most certainly caused by the design of the seat being that it has to fold down to let someone into the back seat. Is that what you are feeling?
Old Jun 18, 2008 | 06:49 AM
Goldilocks's Avatar
Goldilocks
Are you all stopping suddenly or gently - I can see if you're coming to a sudden stop and you lurch forward and the seat back will 'give', but under normal circumstances..........?
Old Jun 18, 2008 | 02:03 PM
Oakland Raiders Mini's Avatar
Anyone over 250 lbs. ? I'm 190 and this doesn't happen.
Old Jun 18, 2008 | 10:04 PM
Smoogy's Avatar
Smoogy
Mine does a little but only under during hard braking. Haven't tried to fix it or anything I guess mine just isn't as annoying.
Old Jun 21, 2008 | 11:56 AM
poidog's Avatar
poidog
Yep, mine is only during hard braking too. I'm only 120lbs.
Old Jun 21, 2008 | 09:35 PM
Smoogy's Avatar
Smoogy
I'm about 140 lbs. I guess we're just to light.
Old Jun 22, 2008 | 05:03 AM
4xAAA's Avatar
4xAAA
165. Count me in the rocker group.
It isn't so bad unless I am braking hard, then I hardly notice it over the screaming.
Old Jun 22, 2008 | 07:52 AM
kevinminict
Yeah What I am trying to get at is, my passenger seat is very solid has no play whatsoever, and that seat even slides to let passengers in the rear just like the drivers side.
But I've been in alot of different cars ford, vw, landrover, honda toyota, and every seatback is solid and I just think that if the passenger seat is solid and has no give then the drivers seat should be the same, giving I paid alot of money for this car and its made by parent BMW, So I figured it would have quality to it.
Its been in the shop twice, both times replaced the upper seatback frame which also houses the recliners...... and they cant seem to fix the problem, it was never loose when I first got the car new last July, so I dont know what could be causing it.
By the way I usually stop nice and easy & occasionally would have to hit the brakes for a bad driver in front, and yeah I could really feel give when stopping quick, but its just the whole comfort quality issue that bugs me....when sitting in the seat its just the mental, "hmm this isnt right it shouldnt be dong this" feeling.
Old Aug 7, 2008 | 07:15 AM
cpayne's Avatar
cpayne
Anyone find a solution to this yet? It is driving me nutz. Happens under hard braking and acceleration. Not sure it is the seat back as much as the seat in the tracks itself.
Just noticed this is for the 07+ Mini's..mine is an 05'
Old Aug 7, 2008 | 07:18 AM
Winchm60's Avatar
Winchm60
I know this is the wrong section as well, but this happens with my '03.
Old Aug 7, 2008 | 07:26 AM
plymini's Avatar
plymini
I have the same problem, and already consult with local MINI dealer. Some of the early R56 does have same problem. Need to change the part inside.
Old Oct 13, 2008 | 07:01 AM
dparaho's Avatar
dparaho
I have the problem as well
I noticed play in my drivers' side back seat after a weekend trip where I had the seats folded down. The play was causing a rattle sound when I drove over bumps. Took the car into dealer on Friday to have it fixed. Another weekend trip with the seats down and the rattle is back. With only 5,000 miles on the car I'm starting to have concerns about reliability and build quality. Looks like I'm headed back to the dealer.
Old Oct 13, 2008 | 12:57 PM
corcoranwtnet's Avatar
corcoranwtnet
2009 MCSa...both seats are solid.
Old Oct 13, 2008 | 04:21 PM
MiniNova's Avatar
MiniNova
actually my passenger seat is starting to make noise, seems like is loose just a bit, it radles now..
Old Oct 26, 2008 | 08:33 AM
idickers's Avatar
idickers
CHeck the bolts that hold the seat to the sliders. In my '02 MCS the bolts backed out, causing what felt like a loose seat back. It was actually the whole seat rocking. Eventually the last bolt came out, and the seat flipped back. Quite an experience while driving . The bolts attach to #4 in this diagram at realoem:
http://www.realoem.com/bmw/showparts...58&hg=52&fg=10
You have to remove the side cover for the seat to get access to the bolts. When I looked around under the car I found the bolts in the carpeting under the seat. They did not have lock washers and had no signs of lock-tite, so it was only a matter of time before they backed out. I'm having a hard time aligning the feet with the slider to get the bolts back in; I'll probably have to take it to the dealer to get the correct adjustment.
Ian
'02 MCS
Filmy
15
Jun 6, 2023 06:27 AM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
sir5150
Oct 6, 2015 05:25 AM
Norton70
Sep 7, 2015 05:06 PM
SeattleF56
Sep 3, 2015 03:01 PM
