R56 Hoping for the Woosh.
*NOTE: I am in no way a mechanical type of person*
Question, and this may sound silly, but I'm getting an '08 MCSa which of course is turbo-charged. Now, when I rode in a firend's Subaru WRX (also turbo-charged) but manual, I heard this cool little "woosh" thing every time he let off the gas (and/or shifted...). He said my automatic wouldn't make that sound....is that right? Or maybe I won't hear the woosh as profoundly, but shouldn't it still woosh?
It should still wooosh as you described. what your talking about is a blow off valve or bov
the stock one is generaly pretty quiet
so if you can find a aftermarket one for your car thats all you need
im unsure if there is one made for your car right now but i suppose you can look into it.
Or you could see if you can modify your stock one.....
good luck
and btw the woosh or chrip gets cops attention better than a red car
good luck
Yikes! Oh well, I totally love the sound of it! So I guess there's not really a difference between the automatic and manual in that respect then. It would be very cool to have it be nice and loud, especially with the paddle shifting!
you are not going to hear the woosh anywhere near what you hear on a WRX. You really have to listen for it. I don't think that the MCS even has a BOV. I remember reading something about excess pressure being recirculated instead of being released.
try this
https://www.northamericanmotoring.co...ad.php?t=99615
Plenty of nice noises for around $60.00
It probably makes it more efficient or something that way. Well darn. Anyway, the WRX sounded amazing! I'll just have to drive with the music off and maybe I'll be able to hear a hint of a BOV., maybe..
there are two ways to get this sound... either get an aftermarket intake, or diy cai or get the forge bov.
Your friend probably has a BOV but they are not good for the car. BOV's vent to the atmosphere which causes the enging to run rich because of the air that was counted for then lost.
Most all turbo cars have stock BPV's even the WRX. I would just recommend goin with a DIY CAI, check the mods section.
As for the auto situation.... you may only get the noise in manual mode but im not for sure.
BTW: the exhaust note on a WRX is one of my favorites of all cars.
[quote=ghosthound;2164954]there are two ways to get this sound... either get an aftermarket intake, or diy cai or get the forge bov.
Most all turbo cars have stock BPV's even the WRX. I would just recommend goin with a DIY CAI, check the mods section... quote]
Wow thanks guys. I had know idea there was even a mod for anything like that *cough*notamechanicaltypegirl..*cough* But I do love the sights and the sounds of different cars. Now, to find someone to install one for me..
Guess I'm really screwed then, with my CAI and CR/W paint
(I've actually never been pulled over in this car)
whoosh
The only whoosh I get is from the air leak coming through the window seal
Maybe there is no whoosh 'cause I have a non-S, which I am beginning to love nonetheless. Although I have to admit I am growing more envious of the S torque and power on demand (like on the wifee's '06 S). Ah well, maybe we'll have to upgrade to another S down the road
Greg
. Maybe there is no whoosh 'cause I have a non-S, which I am beginning to love nonetheless. Although I have to admit I am growing more envious of the S torque and power on demand (like on the wifee's '06 S). Ah well, maybe we'll have to upgrade to another S down the road
Greg
If you want a little power and some more sound including the whoosh. Do what I did, put on a DDM Works Street CAI.
My MCSa makes wonderful sounds. Also, the automatic does get engine braking, that is why you slow down when you downshift using the paddles. At least as I understand engine braking.
even a foam panel filter will help give you a little of this noise, but not to the extent of a BOV.
Then you can also add the DDM strut tower brace/caps if they ever become available....
but anyways... why would a bov be bad for the car? or not good?
but i have a forge bov and it sounds beastly =]
googled this, pretty good explanation
http://www.streetracersonline.com/ar.../turbo/bov.php
read the other links too ....
Anyway, the reason it is bad is because when air enters the intake, the ecu accounts for that air and when you let off the gas with an atmospheric BOV, all that air is let free... This leads to the engine running rich because it thinks that air is still available. Thats how it is on a wrx, and for the most part the stock BPV does a more than adequate job at preventing turbo surge.
As for the MINI i think its the same situation... but i cant say for sure.
With my trueflow foam filter the noise is more than enough and its a cheap and easy mod.
yup, nothing beats the boxer rumble...
when i put it in.. it was a "sandwich" plate with holes you put in between... but i really dont know =/ hope its not bad, but i swear it makes it spool faster =]
elverado
Jan 18, 2022 02:51 AM
asmasm
Sep 21, 2015 08:23 AM
MiteyF
Sep 19, 2015 11:26 AM
