R56 Cant firgure out how to remove the tailights ???
Old Jan 15, 2008 | 05:10 PM
jfman's Avatar
jfman
I cant figure out how to remove the tailights from an 07 mini? I removed the trunk lining and I cant see and bolts back there... ??? Anybody knows how to do it?
Old Jan 15, 2008 | 05:42 PM
ghosthound's Avatar
ghosthound
if you remove the chrome trim around the taillight, it exposes some screws which i think hold the light in place... im not for sure though.
To remove the chrome trim, simply pry the piece off. Its held in by some clips.
Old Jan 15, 2008 | 05:51 PM
jfman's Avatar
jfman
Oh that makes sense. I'll try that. Thank you.
Old Jan 15, 2008 | 05:54 PM
spam.at.trash's Avatar
spam.at.trash
jfman,
By the way, is the car yours? what happened?
Old Jan 15, 2008 | 05:56 PM
jfman's Avatar
jfman
Originally Posted by spam.at.trash
jfman,
The car hit a pole on the pass side. It is mine now but I'm not the one who wrecked it.
Old Jan 15, 2008 | 08:37 PM
MiniJayhawk's Avatar
MiniJayhawk
Parts car!!!!!! Whatya offerin'?
Old Jan 15, 2008 | 11:37 PM
jfman's Avatar
jfman
What do you need? I am offering everything but the drivetrain.
Old Jan 16, 2008 | 05:48 AM
Creeve's Avatar
Creeve
i cant tell. do you have xenons? if you do i'll take em off you hands.
Old Jan 16, 2008 | 06:36 AM
MiniJayhawk
Can I take the hood scoop plastic grill insert off your hands? I have a project in mind.
Old Jan 16, 2008 | 08:09 AM
Msteadman's Avatar
Msteadman
Damn, that looks brutal, I hope no one was hurt! And it's my favorite color... Any plans for a replacement???
Old Mar 13, 2008 | 03:02 PM
dwbradley's Avatar
dwbradley
Is the steering column and tilt/telescoping assembly still available and if so what would you sell if for?
Dave Bradley
Old Mar 18, 2008 | 09:48 PM
jjshoe's Avatar
jjshoe
does it have the sirius module under the passenger seat? message me.
Old Mar 19, 2008 | 06:34 AM
condor27596's Avatar
condor27596
In the cubby below the AC controls.
There is a little plastic cover that pops out.
How much would you want for that?
Old Mar 19, 2008 | 06:35 AM
condor27596
You pop off the chrome trim carefully
with a screwdriver (does not take a lot of force
at all)
There are two torx screws that hold the light on.
Old Mar 19, 2008 | 02:02 PM
saturn's Avatar
saturn
at all)
Actually, there are three torx that hold the taillight in place. If you look carefully in between the trim and the body of the car you will see the actual slots where the tabs push into. Take a piece of electrical tape and put it over the tip of a skinny flat head screwdriver. This keeps from chipping the paint and the plastichrome. Place the screwdriver between two of the slots (top center of the trim is the first on I would do) then CAREFULLY start prying. You will hear a click when it starts to pop off. Do the same all the way around. After that's off there are three torx. After the torx are off, there is still a little bit of wiggling to do to get the tailling out. JUST BE PATIENT and remember, these things are made of plastic and will break if you rush or try to force it.
Old Mar 19, 2008 | 08:14 PM
<MINI>'s Avatar
<MINI>
Once the light is out, do you know if the clear plastic seperates from the red? I need to put an end to the orange circle! It looks like the red and orange are glued together, but some red translucent vinyl should fix it up.
Old Mar 20, 2008 | 04:30 AM
condor27596
Also (I remember now) when you go to pull it out
there are these (not sure of the word) clips you
need to pinch together from the backside by
reaching your hand in the boot/fenderwell.
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
