R56 Glove Box Organizer doesn't seem to fit?
Old Jan 13, 2008 | 12:33 AM
ehart13169's Avatar
ehart13169
I just got a glove box organizer for my '07 MCS, and it doesn't seem to fit the glove box...a touch too wide. Is there a trick to putting this in, or am I missing something obvious?
Old Jan 13, 2008 | 12:55 AM
goaljnky's Avatar
goaljnky
Just force it in. Push hard.
Old Jan 13, 2008 | 01:11 AM
ehart13169's Avatar
ehart13169
I will try that tomorrow...would I be correct in assuming it goes in so that the short tabs are against the top of the glove box?
Old Jan 13, 2008 | 06:37 AM
Nimcosi's Avatar
Nimcosi
It fits, but in a very particular way. The easiest way I found was to open the glovebox and remove the stuff inside (duh). Holding the unit with the divider on top and the tapered end facing you, flip the unit vertically so the divider faces the glove box front of the car. Now move it forward into the glovebox. The unit should need to be tilted (45 degrees or so) down towards you as it is placed into the glove box. Once placed, when you let go of it , the unit will lay flat on the glove box door and you can close it. However, you will need to adjust the contents of the glove box forward and backward to ensure it closes corrrectly. Honestly, while it does do a good job of keeping the glove box organized, the odd shape causes a bit more space loss than most people will be willing to accept. Still it works well for me.
Old Jan 13, 2008 | 01:05 PM
kevshootz's Avatar
kevshootz
I found the item to be worthless and even the dealer couldn't figure out a sure fit.
Old Jan 13, 2008 | 02:08 PM
Minidrivr's Avatar
Minidrivr
Mine worked fine. Dropped right in.
Old Jan 13, 2008 | 02:16 PM
1QukMINI's Avatar
1QukMINI
The SA here at my local dealer advised against buying the R56 organizer, saying it was not a good fit at all, and was not the best purchase.
Old Jan 13, 2008 | 07:08 PM
ehart13169's Avatar
ehart13169
Still not able to get it to fit....push hard, or following the instructions from Nimcosi. Mine looks completely different than the one shown in the pic above though....looks like this:
This is not a pic of mine, it is a pic I found on the web....doesn't look anything like the one I ordered. Did they send me the wrong one?
Old Jan 13, 2008 | 07:20 PM
Minidrivr's Avatar
Minidrivr
That picture isn't a R56. The one in the pic I posted is the OEM model for a R56.
Old Jan 13, 2008 | 07:24 PM
TheBigNewt's Avatar
TheBigNewt
You guys actually paid money for that? I'm amazed.
Old Jan 13, 2008 | 07:27 PM
Nimcosi's Avatar
Nimcosi
Sorry my instructions were for the R56.
Old Jan 13, 2008 | 07:42 PM
T-Horn67's Avatar
T-Horn67
You should try the organizer from GoMiniGo. You can find them on the vendor list. I absolutely love mine!
Old Jan 13, 2008 | 08:56 PM
Minidrivr's Avatar
Minidrivr
Technically I had to buy the car to get it, so yes I guess so.
Old Jan 14, 2008 | 09:28 AM
Kelly Girl's Avatar
Kelly Girl
i cut mine down with a hacksaw... fits perfectly now!
Old Jan 14, 2008 | 04:00 PM
Minidrivr's Avatar
Minidrivr
How about posting a picture to see where you cut it?
Old Jan 14, 2008 | 10:12 PM
ehart13169's Avatar
ehart13169
Mine is an R56. However, after looking at the different ones available, I bought it from Minspeed (they sell the GoMiniGo organizer), but it looks like they mistakenly sent me the one for the R53 instead of for the R56. I'm in the process of working that out with them now. That would explain why it doesn't fit!
Old Jan 15, 2008 | 04:48 AM
Minidrivr's Avatar
Minidrivr
No wonder it didn't fit! I like the glovebox on the R53 better than the R56.
Old Jan 15, 2008 | 07:53 AM
The Meal's Avatar
The Meal
Stealing Minidrivr's picture, I make sure my OEM R56 organizer matches up with the indicated indentation prior to closing. That works for me. However, I'm not impressed with the OEM organizer, and think that T-horn's GoMiniGo suggestion is probably the better way to go.
~Neal
Old Jan 15, 2008 | 05:36 PM
Minidrivr's Avatar
Minidrivr
Originally Posted by The Meal
Stealing Minidrivr's picture, I make sure my OEM R56 organizer matches up with the indicated indentation prior to closing. That works for me. However, I'm not impressed with the OEM organizer, and think that T-horn's GoMiniGo suggestion is probably the better way to go.~Neal
Why kind of material is the GoMiniGo one? I just recently pulled my out due to all those tiny fibers getting all over everything I put in there...but then I'm a little OCD.
Old Jan 15, 2008 | 08:53 PM
mini-rolls's Avatar
mini-rolls
Our GbT is ABS plastic and the flat areas covered with felt. We can also match the felt to the color of your car. Yellow Felt would look nice.
Old Jan 15, 2008 | 09:55 PM
Minidrivr's Avatar
Minidrivr
Does the felt "shed" like the OEM one?
Old Jan 16, 2008 | 09:57 AM
mini-rolls's Avatar
mini-rolls
Have not had any shedding issues. We buy a quality felt.
Old Jan 16, 2008 | 10:14 AM
gokartride's Avatar
gokartride
My OEM glovebox organizers never had any shedding issues...this is my second (first on an '03, and now on my '07). I like the finished edges of the OEM unit and the elastic hold-downs are very useful given that the unit moves up and down with the glovebox door. That said, for me the secret of making it work was getting it centered. If mine wasn't centered it seemed to hit some internal part of the glovebox as I closed it. It's not a precision thing, but one I got it roughly centered it's worked great. I just use it all the time and never give it a second though which, afterall, is what you should do with a glovebox organizer.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
blackie
Jan 18, 2017 09:56 PM
blackie
Aug 23, 2015 08:44 PM
minipopkart
Aug 13, 2015 05:22 AM
