R56 Rims from R53??
Old Oct 24, 2007 | 08:42 AM
johnlam321's Avatar
johnlam321
Rims from R53??
hi, i got a quick question. Can rims from the previous gen, r53 fitted on to the R56. I heard that the center bore of the rims are different. Is this true, can anybody pls confirm??
Old Oct 24, 2007 | 09:42 AM
Rastven's Avatar
Rastven
Depends on whether the older generation rims will accept the new larger bolts the R56 has and whether or not you have the new TPMS in your R56.
Old Oct 24, 2007 | 10:22 AM
johnlam321's Avatar
johnlam321
but is the center bore the same??
Old May 25, 2009 | 04:27 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Anyone know if S-lites from an R53 will fit a clubman ?
Old May 25, 2009 | 04:38 PM
miniconcarne's Avatar
miniconcarne
Bore sizes are the same 56.1mm. Only limiting factor for wheel fitment is brake size vs. wheel size:
Can all OEM wheels be fitted to either generation MINI?On July 12, 2006 the size of wheel bolts was changed from M12x1.5 to M14x1.25. There exists a misconception that this change in wheel bolt size precludes fitting early OEM wheels on later model cars. This is simply not true as all OEM wheels have holes large enough for either size wheel bolt.
http://www.mini2.com/forum/faq.php?f...wheel_fitments
Old May 25, 2009 | 05:04 PM
-=gRaY rAvEn=-
Moderator
Thank you miniconcarne .......Some Great Info here.
I wll be saving this thread for future reference
I just sold my old set of nice S-lites to a chap in a new Clubman. He was referred to me thru our SA. Afterwards I remembered something about the different sized bolts, but by then he had already left. I left him a message but have not heard back yet, so guess it all worked out. No news is good news !
Old May 26, 2009 | 10:40 AM
kukaepe's Avatar
kukaepe
If the only problem is the bolt diameter, TSW sells stud conversions that will convert the size from 14mm to 12mm and go from bolts to studs.
Old May 26, 2009 | 12:54 PM
dens's Avatar
dens
Yes here is pic of the R53's rims on my 08 R56. They are R84 X-lite 17.6lb (from Mini2.com), very close fit to the brake, just b careful w the balance weights, they may rub if too thick.
Old Nov 22, 2010 | 07:38 PM
JRussellT's Avatar
JRussellT
Hi, fairly new to Mini's here but is that an 08 MCS? The R-84 is the same wheel I would like to put on my 07 MCS for winter. I can deal with the wheel weight issue but I've received conflicting info on them working at all...
Thanks, in advance, for your indulgence with an old thread!
Mark
Old Nov 29, 2010 | 10:29 AM
spurvis's Avatar
spurvis
Yes.
I have a set of 16in X-Lites and a set of 17in S-Lites, both from the Mark 1 R53 series MINIs and they both fit my 10/07 build R56S. I have no issues with the bolts, holes, or the brakes calipers clearing. My MINI was built with the 17in Crown Spoke rims from the factory. Good luck!
Old Nov 29, 2010 | 10:43 AM
CMG's Avatar
CMG
Thanks been wondering if I could use 16" rims on my 08 S that came with 17"
Old Nov 29, 2010 | 07:14 PM
JRussellT's Avatar
JRussellT
R-84's
Thanks for the confirmation!
Cheers!,
Mark
ki7hy
Suspension
Mar 13, 2016 08:45 PM
FLYM1N1
Oct 13, 2015 04:33 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
TOMSR53
Aug 26, 2015 10:18 AM
